Old 07-20-2021, 01:25 PM   #253
Originally Posted by Capt Spaulding View Post
I'm curious to see where Bezos and Branson go from here. At this point both are, I think ego driven vanity projects. No new ground is being plowed. Musk seems to be operating from a plan. Perhaps a megalomaniacal plan, but a plan nonetheless.
Branson is doing about as much as he plans to do, suborbital flights for space tourism. The Unity design isn't a spaceplane like the shuttle, although I suppose long term he could get there, but like you say I think it's more a vanity project for him from what I've seen.
Blue Origin has a plan and are more SpaceX than V-Galactic. They are capable of going into low earth orbit, and probably higher. They are building "New Glenn" now which is their orbital ship, and they had been participating in the lunar lander project for Artemis, but that has gone to SpaceX in a last minute twist. Blue Origin has filed a complaint on it.
I think now that Bezos is no longer focused as much on Amazon you will see them catch up to SpaceX, but I'm not sure it will be enough.
Spuds (07-20-2021)
Old 07-20-2021, 01:39 PM   #254
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
So no very far up really.
Neil deGrasse Tyson was on the Cuomo show last night and put it into perspective a bit.
He related the measurements in 'Muricun finger counting units there.
Here's a link to the french fry metrics
"Using a globe to show what he meant, deGrasse Tyson explained that the International Space Station and a spacecraft orbit would be 1 cm away from Earth while the moon would be as far away as 10 metres. As per this scale, Richard Branson went up till around 2 mm from the surface."
Ultramaroon (07-20-2021)
Old 07-20-2021, 01:58 PM   #255
Well, when you get right down to it, there have only been 27 astronauts (the 9 Apollo moon missions) and one space dummy in a convertible that are really space travelers. Pretty much everyone else has just taken a stroll around the block. Whether you walked next door and came back, or went all the way around the block a few times, you really aren't travelling in space.
bcj (07-20-2021), Spuds (07-20-2021), Ultramaroon (07-20-2021)
Old 08-03-2021, 02:07 PM   #256
brewloc
brewloc's Avatar
Drives: '20 86 MT
Super Heavy Booster is being rolled out. Wow, 29 raptors!
brewloc is offline   Reply With Quote
Old 08-03-2021, 02:20 PM   #257
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
When does that one blow up?
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (08-04-2021)
Old 08-03-2021, 02:59 PM   #258
That is one big Pringles can.
Don't worry, you'll see the flash outside your window when it happens. Sounds like they don't plan on lighting this one up, it's primarily for fuel load testing.
Spuds (08-03-2021)
Old 08-03-2021, 03:18 PM   #259
Turns out the raptor engines aren't installed in this tube as they would stick out the bottom and would be visible, at least according to the stream I was watching.
Old 08-03-2021, 09:32 PM   #260
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The Following User Says Thank You to x808drifter For This Useful Post:
Dadhawk (08-04-2021)
Old 08-06-2021, 03:03 PM   #261
Speaking of space things, I really want one of these tags, but just can't justify the price.
It is a tag made from metal from the Mobile Launch Platform (Saturn/Shuttle). The part is the vertical hold that attached to the Shuttle and has been blasted by the rocket exhaust.
Spuds (08-08-2021)
Old 08-07-2021, 02:38 PM   #262
JD001
JD001's Avatar
Drives: Subaru BRZ
Okay, so I've read somewhere an asteroid is heading towards Earth carrying so much precious metal that it could make everyone a billionaire.. What does that mean? What happens to the economy, does the value of currency drop to nothing... Does it mean everything is free? People walk around doing jack, and when their time is up they are reincarnated for another blissful life cycle....
Old 08-08-2021, 10:59 AM   #263
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Saw that SpaceX has stacked a starship prototype on the super-heavy. I may have to run down there tomorrow and check it out.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Dadhawk (08-08-2021), Ultramaroon (08-08-2021)
Old 08-08-2021, 11:06 AM   #264
Capt Spaulding
Persona Non Grata
Okay, so I've read somewhere an asteroid is heading towards Earth carrying so much precious metal that it could make everyone a billionaire.. What does that mean? What happens to the economy, does the value of currency drop to nothing... Does it mean everything is free? People walk around doing jack, and when their time us up they are reincarnated for another blissful life cycle....
If everyone is uber-wealthy who is going to do the actual work required so we can all survive? Wouldn't all that formerly scarce metal and the wealth it "created" become worthless. Something scarce would come along to take its place. I'm thinking Dairy Queen Blizzards. With everyone wanting DQ blizzards and no one to make them, the DQ Blizzard maker(s) will be king/queen.
JD001 (08-08-2021), Ultramaroon (08-08-2021)
Old 08-08-2021, 03:17 PM   #265
Her Majesty's Blizzard becomes the coin of the realm. You read it here first, folks.
Capt Spaulding (08-08-2021), Dadhawk (08-08-2021)
Old 08-08-2021, 04:18 PM   #266
Spuds
The Dictater
Spuds's Avatar
If we were to mine the asteroid in one go, it would make a few already rich investors more rich, and/or would decrease the value of that material drastically since we would have more than we can use.
JD001 (08-08-2021)
Which Space Saver will fit? Andrew666 AUSTRALIA 25 06-18-2020 09:07 AM
Cockpit Space Chad86 Scion FR-S / Toyota 86 GT86 General Forum 7 03-15-2014 03:24 PM
First run 86's (Space Saver question) DriftEightSix AUSTRALIA 11 01-10-2013 07:25 AM
FR-S space saver sierra Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2012 12:18 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 12:29 PM
