Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 08-05-2021, 03:27 PM   #1
scionhobokenD
Drives: 2013 scion frs 6 speed manual
2013 frs burned out clutch? or something related
Holy Crow.
havent been on the forum in a long time cause my car has been awesome.
I have a 2013 scion frs 65000 miles on it.
all fluids good. drives great till just now
Today coming home from an hour drive , my clutch pedal suddenly felt spongey weird and then the smell of burning clutch began . just made it into my parking spot and turned off engine. phew.
started the car again and in neutral, when pressing clutch pedal in, cars stalls , not even in gear, something very wrong
and idea guys and gals?
doug
scionhobokenD is offline   Reply With Quote
Old 08-05-2021, 05:12 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i assume TOB? i wouldnt drive and tow it to shop and bring down Transmission to check
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
scionhobokenD (08-05-2021), ScoobsMcGee (08-06-2021)
Old 08-05-2021, 07:11 PM   #3
scionhobokenD
2013 frs, clutch issues
im in hudson county. i have a mechanic in union city, but not specifically for this car. any suggestions?/ thanks!!
Old 08-05-2021, 10:16 PM   #4
zc06_kisstherain
Drives: SWP BRZ
I already suggested it. or you can DIY dropping transmission if you can
if not you need to tow it.
dont try to save small $$$$ and spend $$$$$$$$$$$$$$$$ money after you learn your lesson
try to search local reputable shop to do it
scionhobokenD (08-07-2021), ScoobsMcGee (08-06-2021)
Old 08-06-2021, 10:44 AM   #5
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
To further iterate on this, it is common for the TOB to go bad around 60k miles on the 2013-2016 models. There is a revised OEM one you can get from Subaru used in the 2017+ for $50-$100, or you can get one from Verus for $35. While the transmission is out I also suggest replacing the clutch fork and fork pivot as they're cheap parts with expensive labor to replace.
That said we're going off an assumption and it could be something different entirely. If it was the TOB it should have been making a sort of wailing sound prior to getting that bad. Specifically when cold with the clutch out and car in neutral, and less noisy once warmed up. If that was the case and things got so bad it did completely fail, there is a decent chance the clutch is damaged as a result. Still, if you're going to drop the trans, consider replacing that stuff I mentioned to prevent having to drop it again soon.
edit: revised TOB from Subaru or Toyota... one make mindset.
Old 08-06-2021, 11:01 AM   #6
zc06_kisstherain
Drives: SWP BRZ
Here's my experience on my 13 BRZ
I thought my TOB was bad and bought Southbend stage 2 clutch, Verus clutch fork and pivot to replace whole thing. (i was at only 30K mileage)
when Transmission was out, TOB was fine it was just regular normal sound but i end up changing anyway since transmission was out
so, buy all clutch,flywheel (if needed), clutch fork, pivot and TOB (revised one) to replace
even new revised TOB makes same original TOB sound but should be fine
Old 08-06-2021, 11:10 AM   #7
ScoobsMcGee
Drives: 15 BRZ
Exact same mentality I had with a TOB going bad at 59k. Only difference is that it took the ACT clutch I bought 3 months to show up, and after 1.5 months I just had everything else replaced. Thankfully for me it was the TOB, and the stock clutch still looked fine.
zc06_kisstherain (08-06-2021)
Old 08-06-2021, 11:42 AM   #8
zc06_kisstherain
Drives: SWP BRZ
I end up spending money that i didnt need to spend but i didnt want to risk having whole transmission to replace if TOB is shattered inside so i just took transmission down
Old 08-07-2021, 03:07 PM   #9
scionhobokenD
THANK YOU EVERYONE!!!
Im copying all coments and will proceed this coming week.
Much Appreciated
doug
The Following User Says Thank You to scionhobokenD For This Useful Post:
ScoobsMcGee (08-07-2021)
Old 08-09-2021, 11:33 AM   #10
scionhobokenD
Hi Folks/ any comment on this source for clutch package? https://86speed.com/exedy-oem-clutch-kit-frs-brz-86
Old 08-09-2021, 12:23 PM   #11
zc06_kisstherain
Drives: SWP BRZ
I dont know what your goal is but you can get little bit more aggressive clutch kit
depends on your mileage you may need to get new flywheel too
Old 08-09-2021, 02:36 PM   #12
scionhobokenD
kisstherain/ its been a great car for 5 years. little money into it beyond new tires and oil , filter etc. If its going on the lift, I might as well do all i can when up there.
got 65,000 miles on it.
reccomendations?
Old 08-10-2021, 10:33 AM   #13
zc06_kisstherain
Drives: SWP BRZ
reccomendations?
Since transmission is going to be down, get whiteline transmission bushing and Shifter bushing and Mtec shift spring
these will help you on firm shifting
https://www.ftspeed.com/part/fr-s-br...g#.YRJ_tIhKhyE
https://www.ftspeed.com/part/fr-s-br...7#.YRJ_1YhKhyE
https://www.ftspeed.com/part/fr-s-br...s#.YRKACIhKhyE
yes. i have all these installed in my car lol
2013 fr-s, clutch, frs, repair, scion
Check Engine Burned Into ECU? mo4sho Issues | Warranty | Recalls / TSB 32 12-06-2020 02:39 PM
Squeaking Clutch Noises NOT Related to the Throw Out Bearing BigTuna Issues | Warranty | Recalls / TSB 13 09-27-2018 03:32 AM
Valenti Revo LED burned out already BirdTRD Cosmetic Modification (Interior/Exterior/Lighting) 15 12-26-2017 11:08 AM
Question regarding a pulsation related to clutch pedal Frs x3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-01-2014 02:41 AM
Has the seatbelt 'burned' you yet? Rob_g Scion FR-S / Toyota 86 GT86 General Forum 22 07-17-2012 03:01 PM
