Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-05-2021, 02:58 PM   #15
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by ~el~jefe~ View Post
Uh. Well. brembo's are lighter but bigger.
They are definitely heavier than the standard brakes.
Old 08-05-2021, 03:04 PM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Uh. Well. brembo's are lighter but bigger. So that's a real thing. .
I don't have numbers in front of me, but my understanding was the PP brembos are heavier vs. standard non-PP brakes. For sure the rotors are. I swapped out my 23 lb. stock PP front rotors for 17 lb. Girodisc 2-piece. That was a lotta $$ per pound saved...
Old 08-05-2021, 03:27 PM   #17
~el~jefe~
Drives: 2019 MX-5 RF
at the time i bought them, people on here said you save weight and gain better braking. i guess that information shifted. Is there any lighter + 4 piston very good heat dissipating systems that arent too expensive? 4 piston front 2 back.
~el~jefe~ is offline   Reply With Quote
Old 08-05-2021, 03:44 PM   #18
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
One of the biggest benefits of a BBK is the added weight of the rotor, and thus thermal capacity.
Once the rotor has enough thermal capacity, the more expensive kits do weight savings by using lighter hats.
Same with calipers/pads. I don't know about base FT86 pads,
but on ND Miatas the Brembos have significantly bigger pads than
base brakes. Or "Little Big Brake Kit", God forbid.
Admittedly, you need to be driving pretty hard (e.g. at the track) for all that to make a difference.
The biggest benefit of the PP on '17-'20 BRZ was the amazing value-for-money on those Brembos.
And better dampers were included?!
Sure, you can get a better aftermarket BBK, but it will probably set you back double or event triple
the amount you'd pay for the PP option. One of the components here is that if you're buying base
brakes you still have to pay for them, even if you're not going to use them. And there's not much
demand on the second-hand market to buy those base brakes from you.
And for sure Brembos look way better
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
WolfpackS2k (09-03-2021), ~el~jefe~ (08-05-2021)
Old 08-05-2021, 03:50 PM   #19
Code Monkey
Drives: Subaru BRZ
If anything, PP Brembos make changing brake pads a breeze. No more unbolting calipers and fucking around with a spreader tool.
Code Monkey is offline   Reply With Quote
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
dowroa (08-25-2021), Gearhead23 (08-06-2021), timurrrr (08-05-2021), ZDan (08-05-2021)
Old 08-05-2021, 03:52 PM   #20
Jordanwolf
Rice King
Jordanwolf's Avatar
Brembo doesn't do anything to daily or mountain drive performance. Pads & tires do more performance.
I was going to say this, but figured it may not be worth the effort. Good thing you've got patience enough for the two of us.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following 3 Users Say Thank You to Jordanwolf For This Useful Post:
ichitaka05 (08-05-2021), NoHaveMSG (08-05-2021), Ultramaroon (08-08-2021)
Old 08-05-2021, 03:58 PM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
That was my #1 reason. *Hate* swapping pads on sliding calipers and having to use that little cube-tool to screw the rear piston back in...
Old 08-05-2021, 04:01 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You guys change pads?
The Following User Says Thank You to timurrrr For This Useful Post:
Yoshoobaroo (08-05-2021)
Old 08-05-2021, 04:10 PM   #23
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
No need to use the cube in a DIH (Drum in hat) setup. Brz does not have a IPB (integrated parking brake) version
Stonehorsw is offline   Reply With Quote
The Following User Says Thank You to Stonehorsw For This Useful Post:
ZDan (08-05-2021)
Old 08-05-2021, 04:15 PM   #24
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
lol 200hp with Brembo unnecessary
Old 08-05-2021, 04:33 PM   #25
Jordanwolf
Rice King
Jordanwolf's Avatar
What relation does 200 hp have to Brembos?
Glorious Honda.
Old 08-05-2021, 04:43 PM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
At the track, a lot... How much energy you have to dissipate in the braking zone is directly related to how fast you're going, which is directly related to how much power you have. More power = faster = more energy for the brakes to take and reject as heat.
I got a chuckle out of it when they added the big Brembos as an option. After years and years of "could use more power", they give it massive brakes sized for 300+ hp, and +5hp...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Blighty (09-08-2021), WolfpackS2k (09-03-2021)
Old 08-05-2021, 04:47 PM   #27
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I've certainly cooked even Brembos at the track with stock power, even with dedicated track pads.
If you've never driven the car hard enough it doesn't mean the brakes are sufficient :P
The Following 5 Users Say Thank You to timurrrr For This Useful Post:
Jdmjunkie (08-06-2021), Jordanwolf (08-05-2021), Stephen W. (08-07-2021), weederr33 (08-05-2021), WolfpackS2k (09-03-2021)
Old 08-05-2021, 05:03 PM   #28
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm just mad I can't see my pads! Every car I've ever had, you can see them!!
MS, CSCS, TSAC-F, CPT
The Following 6 Users Say Thank You to weederr33 For This Useful Post:
Jdmjunkie (08-06-2021), ng-86 (08-06-2021), NoHaveMSG (08-05-2021), Ultramaroon (08-08-2021), WolfpackS2k (09-03-2021), Yoshoobaroo (08-05-2021)
Black Brembos or Red Brembos? Mike_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-30-2021 11:44 PM
Other Enthusiasts Suck ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 23 06-01-2018 07:15 PM
American Drivers Suck ogrowup Other Vehicles & General Automotive Discussions 144 07-11-2016 10:30 AM
All my LED's installed, they suck. Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 26 04-14-2013 07:23 PM
well this may suck. Mikes86 Scion FR-S / Toyota 86 GT86 General Forum 33 12-29-2012 02:35 PM
