Old 08-05-2021, 01:26 AM   #1
Quanle1022
Drives: 2013 Scion FR-S Base
Unhappy Converting 5x100 bolt pattern to 5x114.3 w
I’m running 225/50/r17 + 35 offset on wheels and tires . I bought wheel adapters converting 5x100 to 5x114.3 bolt pattern with 25mm adapters but when I put them on it sticks out way too much. I have stock suspensions and I was wondering if I should get smaller adapters like an 11mm. Or is there any other option that I can do, I’m trying to tuck, or sit flush to finder .
Quanle1022 is offline   Reply With Quote
Old 08-05-2021, 02:40 AM   #2
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
When you use bolt pattern adapters they have to come in a certain width to accommodate the nuts that bolt them to the stock hub. Any thinner than that and you are putting yourself in danger. I would recommend selling your adapters and wheels and getting wheels with the proper bolt pattern and offset.
Google wheel adapter failures to see what kind of gamble you take everyday.
mrha is offline   Reply With Quote
Old 08-05-2021, 12:15 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
+35 offset w 25mm spacer, will make +10 offset. You gotta do 1 of 2 things.
1. Get higher offset wheels. If you want to keep the 25mm spacer, you need minimum of +60 offset to get good flushed. Maybe +58~+56 will work, but might be pushing w the wheel design.
2. Get lower spacer. Even 11mm will put the wheel offset to +24, even putting 3 camber will poke out.
Sweet spot for the wheel offset is +32~38 depending on the wheel design AND tire specs. So keep that in mind when you buy the wheels & spacers.
Thefalls (08-10-2021)
Can I fit rims with 5x114 bolt pattern? Veeoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-14-2017 06:06 PM
Converting 5x100 to 5x114.3? Danny Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-06-2014 10:23 PM
FS NYC: Set of 17x9+22 Multibolt pattern 5x100/5x114.3 STR 518 Matte Black Vic Wheels and Tires 26 01-19-2014 08:31 PM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 02:58 AM
