Old 07-27-2021, 01:45 PM   #29
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by dragoontwo View Post
@ichitaka05 In that blitz video, are the rear LCA shown stock, or did blitz do those? Also if all the other press release stuff is to be believed, that looks like a BRZ chassis with a GR86 body on top.
LCA they had is a stock, but they used Low Magic by the knuckle to help lower 30mm. Well, GR86/new BRZ chassis is same chassis w current gen. They just reinforced the bottom and lighten the top. It's pretty much same thing as 400Z & 370Z.
Old 07-27-2021, 02:08 PM   #30
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Originally Posted by timurrrr View Post
Curious if BBKs for 1st gen will fit and work correctly (wrt brake bias, etc.).
I believe they've changed the front knuckles to be aluminum?
I got up close and personal with one of the new cars on display at the track this weekend and the front and rear brakes look identical to stock. Maybe they have a different mounting but I'm doubting it.
So I'm thinking aftermarket bbk will be just fine.
Exhaust is identical too. Only question is still the header.
No spare tire. Just the foam tray to fit where a spare would go with tire goop kit, and a fewer trunk tools.
Engine bay looks pretty identical too. Small aftermarket parts like hood struts, master cylinder brace, strut brace, etc will likely swap over.
Suspension definitely looks the same. I'm thinking everything will swap over as far as coilovers, RLCA's, and front swaybar is probably the same too. Rear is questionable, but I think it may fit also.
Personal opinion, they changed a Lot with the styling, electronics, and engine. The remainder of the mechanical parts seem nearly identical.
Kelse92 is offline   Reply With Quote
Old 07-27-2021, 07:04 PM   #31
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Right. But, at 40:39 in the video it shows the rear ARB as the BRZ has it installed. Earlier in the video you can see the aluminum steering knuckles in the front also. I'm going to take a wag and say that the GR86 they have is a very early production model that went out before Toyota made their changes.
Old 07-27-2021, 07:06 PM   #32
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Pretty sure that's the case.
Old 07-28-2021, 12:15 AM   #33
ichitaka05
Site Moderator
ichitaka05's Avatar
Oh sorry, idk why but somehow I thought everyone knew all 6 brands (including Blitz) got was prototype GR86 & not a final production GR86. They got em in Nov last year and was going to present TAS, but that never happened, so they show it off in 86 Style. Several things have changed & even Blitz guy stated that they’ll have to do final adjust for the aftermarket production when final version comes out.
Old 07-28-2021, 01:12 PM   #34
DAEMANO
Time Traveller
Originally Posted by CatDaddysBBQ View Post
Ha! That's my article. Thanks for sharing!!!
Great article. So would you expect the same HP/TQ bump from an E85 tune on the new engine as the old one? To me this is the big question as it puts the new car just a few HP away from the output of a low psi F.I.FA20 but with more linear power delivery.
Looking to see about 250-260BHP/240BTQ (230WHP/220WTQ)with e85 on the FA24. In my eyes, that would definitely make the new car worth the upgrade for anyone that doesn't have F.I. already installed in the old car.
Old 07-29-2021, 10:04 AM   #35
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Do they confirm in the Blitz video anywhere that suspension pickup points are the same? Looking to get some coilovers ordered for my 22
trippinbillies40 is offline   Reply With Quote
Old 07-29-2021, 11:50 AM   #36
ichitaka05
Site Moderator
ichitaka05's Avatar
They just said, they're almost same... so I'm assuming they're fraction different.
Old 07-30-2021, 07:45 AM   #37
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Chassis looks similar to me with some small revisions.
Old 07-30-2021, 09:32 AM   #38
"Similar" unfortunately is not same as. The small revisions can really mess with things. Like the 2013 to 17 exhausts that almost fit the post facelift cars. They can be altered to work but don't quite do it off the shelf. This of course can be amplified in things like suspension where a number of small changes can start to add up.
Swap Compatible parts BXRCHTR DIY (Do-It-Yourself) Guides 10 05-14-2019 04:47 PM
Is this a good idea?.. Chimera Scion FR-S / Toyota 86 GT86 General Forum 69 08-18-2016 05:51 PM
Is it a good idea.. Droid BRZ First-Gen (2012+) — General Topics 64 11-08-2014 05:14 PM
Is it a good idea to have both DRL and Headlights on at night? Weeber BRZ First-Gen (2012+) — General Topics 7 11-13-2013 07:31 PM
