Old 07-26-2021, 12:22 PM   #15
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Originally Posted by ayau View Post
throttle mapping confirmed to be different by the subaru/toyota engineers?
i feel like toyota CEO pressured their engineers to differentiate the GR86 from the BRZ simply for the sake of being different, therefore, they can market their car as being unique.
steel vs aluminum knuckle? come on...
If there is a steel knuckle, i would buy it
Stonehorsw is offline   Reply With Quote
Old 07-26-2021, 12:34 PM   #16
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Iron, not steel apparently.
Old 07-26-2021, 01:40 PM   #17
ayau
Drives: Some rust bucket
yeah my bad. not sure why i typed steel lol.
The Following User Says Thank You to ayau For This Useful Post:
Yoshoobaroo (07-26-2021)
Old 07-26-2021, 01:43 PM   #18
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
This video clearly shows the difference in rear sway bar mounting. Interesting that they'd make this change, since it complicates manufacturing.
Another advantage for the Subaru method, is that if the sway bar mount/bracket ever rusts, you can replace that separately from the subframe. On my 2015 BRZ, the front sway bar mount/frame is getting rusty (It saw a few salty Iowa winters) but the sub frame is fine.
This advantage would also apply to the aluminum knuckles; they're going to hold up to salt better that ferrous knuckles.
C4RBON is offline   Reply With Quote
The Following 2 Users Say Thank You to C4RBON For This Useful Post:
Pete (07-26-2021), Yoshoobaroo (07-26-2021)
Old 07-26-2021, 02:28 PM   #19
Pete
Pete's Avatar
Drives: 22 BRZ
So, if I am understanding correctly, it is looking like the BRZ is more what I am looking for mechanically: driftable but not prone to drift, more stable in the rear end for corner exits, maybe a few pounds lighter.
Now, that's a problem because I like the look of the GR86 a lot more from the front, and I like the neptune blue more than any of the colors subaru is offering. Really wish one of the two would offer a bright orange color, I want mine to look like the toy it is.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following User Says Thank You to Pete For This Useful Post:
Old 07-26-2021, 02:34 PM   #20
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Exactly my thoughts.
I'm half-seriously considering buying the BRZ and then doing a bumper swap
The Following User Says Thank You to timurrrr For This Useful Post:
Pete (07-26-2021)
Old 07-26-2021, 02:50 PM   #21
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Can someone explain how different mounting of the rear ARB will affect handling?
I guess attaching it to the car body makes it act like an additional bridge between the suspension/subframe and the body, increasing the overall stiffness?
Whereas if the ARB brackets are mounted on the subframe, the flex in the subframe/frame bushings is basically a spring in series with the effective anti-roll spring of the suspension mounted on the subframe?
Also, wtf is this supposed to mean: (from English subtitles of the DK video at 3:30)
- From Toyota, Subaru adopted an aluminum knuckle, but Toyota did not. I'm asking why.
- Toyota explainer: This is so that the performance of the front tires can be demonstrated accurately.
Everybody nods.
How on Earth is the aluminum knuckle going to demonstrate the performance of the front tires inaccurately?
Old 07-26-2021, 02:53 PM   #22
Yoshoobaroo
TRACKBREAD
GR86/BRZ Comparison Articles
I think that means they wanted more feedback; as in ‘demonstrate tire performance to the driver’
So the knuckles are stiffer
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
JesseG (07-26-2021)
Old 07-26-2021, 02:57 PM   #23
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I think that means they wanted more feedback; ie the knuckles are stiffer
That would make some sense, but does it truly make a difference, given that there's a bunch of bushings in the suspension that also affect the mechanics of how the steering system works?
Also, wouldn't a lighter aluminum knuckle make the rotational inertia of the system lower, thus improving responsiveness?
Old 07-26-2021, 02:59 PM   #24
C4RBON
C4RBON's Avatar
I'm also in the camp that prefers the look of the GR86; both the bumper and the silver/gray interior accents. But I prefer the BRZ mechanically.
Given the knuckles are approximately the same dimensions/geometry, the iron knuckle would be stronger. That could result in better wheel control, but it isn't like Aluminum is flimsy or anything. The compliance in the bushings are going to make far more difference than the knuckle material. The Aluminum knuckle will be lighter and more resistant to salt, that's why I want it. I think drifters prefer iron because it more durable and cheaper.
Pete (07-26-2021), scuzzy (07-26-2021)
Old 07-26-2021, 03:07 PM   #25
Yoshoobaroo
TRACKBREAD
I agree.
I think this is mostly Toyota’s marketing putting a cool spin on it. I think the real reason Toyota doesn’t want aluminum knuckles is because they’re afraid that a less experienced tech would mangle them when doing wheel bearings and suspension arms.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
timurrrr (07-26-2021), ZDan (07-26-2021)
Old 07-26-2021, 04:00 PM   #26
racingfool
racingfool's Avatar
Drives: Miata
I could live with just switching the 86 headlights into a BRZ.
reason Toyota doesn’t want aluminum knuckles...
Perhaps iron knuckles will be easier to get the extreme steering angle that drifters want.
Or maybe that extreme steering angle puts more stress on the knuckle...so aluminum is not such a good idea.
racingfool is offline   Reply With Quote
The Following User Says Thank You to racingfool For This Useful Post:
Old 07-26-2021, 04:24 PM   #27
Pete
Pete's Avatar
Drives: 22 BRZ
Hmmm...Maybe a bumper swap and then a bright orange wrap.
I would never get the colors exactly matched if I just swapped the bumper.
In general I am excited about these cars though, I just loved my first one. Looking forward to western reviewers getting some seat time.
JesseG (07-26-2021)
Old 07-26-2021, 08:47 PM   #28
simpleisbest
Senior Citizen
Drives: Scion FR-S
I wonder about the real benefits of the brz rear arb mounts as well.
It seems like the design would have the arb mount plate basically sandwich the subframe bushing metal inserts to the chassis??? Hard to tell without seeing it on the car.
simpleisbest is offline   Reply With Quote
GR86/BRZ Track Comparison (Japanese) Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 95 12-24-2021 06:36 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
Scanned articles Netherlands Scooby EUROPE 6 05-16-2014 04:04 AM
Scanned articles Finland Scooby EUROPE 1 05-05-2012 08:07 AM
How come there are so many articles about the BRZ and not the FRS? SevenTenSplit BRZ First-Gen (2012+) — General Topics 13 03-31-2012 01:20 PM
