Old 07-25-2021, 11:55 PM   #1
popsicle
Drives: 2013 86 GTS
AUS 2013 86 GTS Speedo Inaccurate
hi all,
ive got an 2013 86 gts in aus w the digital speedo.
for a while i have thought the speedo is incorrect, so today i did a test with a gps speed tester.
EDITED (i had them around the wrong way)
when i do 100kmh on the speedo, the GPS shows 96kmh.
when i do 60kmh on the speedo, the GPS shows 56kmh.
seems its about 4kmh out.
the speed needle on the dash matches the digital dash readout speed.
anyone else noticed this with their car?
anyone know how to calibrate the speedo?
thanks, pop.
popsicle is offline   Reply With Quote
Old 07-26-2021, 12:14 AM   #2
Enigmeerkat
Enigmeerkat
Enigmeerkat's Avatar
Drives: 2015 Toyota 86 GTS
This is normal. If you look at car specs you'll see there's a figure for "speed when 100kph indicated" or similar. All cars are designed to be slightly slower than indicated, usually about 3%. If you really want to fix it, you can get diferent tires that have a slightly different overall diameter. Also the GPS unit is likely not strictly 100% accurate either, there are tolerances there too.
2015 Toyota 86 GTS
- Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch
- PSR UEL Header, Invidia R400 Catback
- Whiteline Swaybars, 18" ROH Blue Evo R
Enigmeerkat is offline   Reply With Quote
Old 07-26-2021, 01:08 AM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Switch over to mph and difference will be smaller ^^
HKz is offline   Reply With Quote
Old 07-26-2021, 01:41 AM   #4
Sasquachulator
Pavement Grey
aftermarket tires or oem?
Tire size could affect it too.
The Following User Says Thank You to Sasquachulator For This Useful Post:
x808drifter (07-26-2021)
Old 07-26-2021, 07:06 PM   #5
popsicle
Drives: 2013 86 GTS
thanks for the replies guys.
yes i thought of tyres. would love a hack to remove the intentional incorrect reporting of speed. guess ill just have to "add four" to know my real speed.
thanks, pops
Old 07-26-2021, 07:32 PM   #6
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
It should change proportionally ie, If it reads 100 and your doing 96 at a 50 reading you should be doing 48. It`s just how it works and is normal operation.
Old 07-27-2021, 02:01 PM   #7
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
I'm in Australia and get the same speedo error vs GPS in every car I've driven, our 86, Tucson, Cruze, Aurion, Camry, Commodore, RAV4 the list goes on and on. completely normal and nothing to be concerned about.
sneaky_pete is offline   Reply With Quote
Old 07-27-2021, 07:07 PM   #8
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Seems backwards. The manufacturers do not want to be liable for you going over the speed limit. When stock tires are new tires, the speedometer should read 2-3% higher than actual. When I put new 225/45R17 tires on my car, the speedo was then pretty accurate at 60mph
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
HKz (07-28-2021)
Old 07-28-2021, 01:00 AM   #9
HKz
Reformed
HKz's Avatar
You're right, it should be the other way around. OP has not confirmed wheel/tire size, if he has bigger diameter tires vs stock that would cause his issue of car speedo being lower than gps speedo.
Old 07-28-2021, 02:05 AM   #10
popsicle
Drives: 2013 86 GTS
tyres are pilot spot 4's, 215/45 ZR17, about 6 months old.
Old 07-28-2021, 02:08 AM   #11
popsicle
Drives: 2013 86 GTS
you're right, i typed it out incorrectly. i have corrected the original post. thx.
Old 07-28-2021, 02:10 AM   #12
popsicle
Drives: 2013 86 GTS
thats also what i was expecting, but not what was shown on the gps. i tested on long stretches of 100 and 60 -- and it was 4kmh out both times, weird right.
GPS inaccurate after new battery BassGhost Electronics | Audio | NAV | Infotainment 4 10-06-2018 05:14 AM
Fuel Gauge is Inaccurate Surakusa Issues | Warranty | Recalls / TSB 13 09-02-2017 11:26 PM
Perrin Boost gauge reading inaccurate? oliverc Forced Induction 0 10-21-2015 12:26 AM
Inaccurate outside temperature display WolfpackS2k Issues | Warranty | Recalls / TSB 62 06-19-2014 11:01 PM
Southeast Toyota FR-S recall for inaccurate load carrying capacity labeling Dadhawk Issues | Warranty | Recalls / TSB 6 04-24-2013 12:19 PM
