Old 07-23-2021, 09:27 AM   #1
trinidadj
Drives: '16 FRS-MT Ablaze Red
Replace Flywheel Bolts
Hi
I'm preparing to install a southbend stage 3 daily clutch with oem flywheel for an upcoming turbo build. Would you recommend replacing the flywheel bolts? Or is re using the oem bolts okay?
Thanks
trinidadj is offline   Reply With Quote
Old 07-23-2021, 09:44 AM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by trinidadj View Post
Hi
Thanks
Most flywheel bolts are one time use only. Fresh ones should only be like 30$at the dealer. Get new ones and use lock tite
Sent from my ONEPLUS A5010 using Tapatalk
Old 07-23-2021, 10:16 PM   #3
fableluke
Drives: BLue 2013 frs
Hi
Thanks
https://86speed.com/subaru-2-0l-fa20...wheel-bolt-kit
ARP flywheel bolts. you can re use them.
fableluke is offline   Reply With Quote
Old 07-24-2021, 02:44 AM   #4
They're reusable
https://gt86stuff.onrender.com/t3Por...01EY5008X.html
humfrz (07-24-2021), mb_ (07-25-2021), trinidadj (07-28-2021)
replace flywheel? Jeong Engine, Exhaust, Transmission 41 05-19-2022 11:08 AM
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 03:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
