Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-22-2021, 11:18 PM   #29
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
"New for 2022, the standard Tire Pressure Monitoring System (TPMS) now allows two sets of
wheels to be ID registered. This allows the owner to switch to seasonal tires without the need of
changing the tires on the original wheels."
Seasonal tires, of course.
Old 07-22-2021, 11:24 PM   #30
itschris
Drives: '14
Flexible flywheel... that's new right?
Always learning.
itschris is offline   Reply With Quote
Old 07-22-2021, 11:48 PM   #31
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
Originally Posted by timurrrr View Post
"4-wheel disc with Electric vacuum pump power assist"
Is this different from what it was before?
I think OG AT BRZ has an electric vacuum pump but the MT should be just using intake vacuum. Not quite sure about the benefit for switching to a electric model? More stable brake pressure when doing heel toe?
zeroomega is offline   Reply With Quote
Old 07-23-2021, 01:02 AM   #32
Jianlun
Drives: GR86 RC
Originally Posted by Yoshoobaroo View Post
Aww no more spare tire..
and yet it is already 20kg heavier than 2012 (i couldnt help myself, had to compare the 2012 and 2022 specs line by line muahahah). which means the extra 75kg that they gained due to crash regs etc which are "almost negated by the alu roof and fenders" is really only offset by say 45kg.
other comparisons:
1. same MT gear ratios
2. same brake rotor diameters! so that means AP Essex Sprint again!
3. slightly steering angle ? (f you multiply the steering lock with the rack ratio and compare, new lock > old lock ie. 13.5 x 2.5 > 13.12 x 2.48). i probably reading too much into it here haha.
4. slightly narrower front track? new vs old = 1519mm vs 1520mm. doesnt matter cos et42 is going onto mine muahaha.
5. wider rear track. new vs old = 1549mm vs 1540mm. same et42 going on muahahaha.
Jianlun is offline   Reply With Quote
The Following 2 Users Say Thank You to Jianlun For This Useful Post:
JRitt (08-10-2021), Yoshoobaroo (07-23-2021)
Old 07-23-2021, 01:12 AM   #33
Jianlun
Drives: GR86 RC
Found the below from here https://motor--fan-jp.translate.goog...o=ajax,nv,elem
Aluminum front fender: -3.0kg
Aluminum front housing: -3.0kg
Aluminum roof panel: -2.0kg
Hollow front stabilizer: -0.5kg
Weight reduction of muffler: -1.6kg
Weight reduction of front seat: -2.6kg
Weight reduction of propeller shaft: -1.1kg
DAEMANO (07-28-2021), ToySub1946 (07-23-2021)
Old 07-23-2021, 09:22 AM   #34
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Honestly gaining 75kg due to crash structure and shaving that back down to 20kg is impressive. I don't think many of us will notice a 20kg increase.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 07-23-2021, 09:58 AM   #35
Sasquachulator
Pavement Grey
If people can notice the torque dip in every speed condition, the 5hp increase, and any other butt dyno statistics, then they will notice 20kg difference EASY!!1
everyone's an internet vehicle R&D expert.
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
Tcoat (07-26-2021), Yoshoobaroo (07-23-2021)
Old 07-23-2021, 10:40 AM   #36
mazeroni
Drives: 2013 Scion FR-S Series 10
If that's the case, then that partly explains the weight loss.
From https://www.ft86club.com/forums/showthread.php?t=7881
OEM spare tire with liner foam= 25.8 lbs.
OEM trunk tools, jack, tow hook= 5.8 lbs.
That is 31.6 lbs alone.
mazeroni is offline   Reply With Quote
Old 07-23-2021, 10:47 AM   #37
Yoshoobaroo
TRACKBREAD
Yea the tire repair kit is way lighter. Looks like they’ve pulled out all the stops to keep it light.
That said, I can’t think of a single car that came out in the last 10 years that I know comes with a spare. The inflator kit is standard now, if you even get anything at all besides runflats.
Old 07-23-2021, 11:03 AM   #38
GraysonGreene
GraysonGreene's Avatar
Drives: 2014 Scion FR-S
Hope they have an accessory subwoofer again! I love my Subaru Accessory 10" Kicker.
Also kinda miffed about the lack of the spare tire. I'd rather have a slightly heavier car and remove the spare at the track . I know barely anyone has to use their spare, however, when you loose a tire 100+ miles away from home and the tow bill is $100+ you'll be wishing you had that spare.
Charlotte, NC
14 Firestorm Red FR-S
GraysonGreene is offline   Reply With Quote
The Following User Says Thank You to GraysonGreene For This Useful Post:
g e (07-26-2021)
Old 07-23-2021, 11:27 AM   #39
Sasquachulator
Pavement Grey
surprised they didnt increase the cargo space with the removal of the spare tire.
Typical of manufacturers though, they just fill the spare tire well with a foam block with tools and a fix-a-flat kit.
Old 07-23-2021, 11:31 AM   #40
Jianlun
Drives: GR86 RC
saw in one of the vids that the spare tyre well is still there. a circular shape that seems to suggest one can put in a say 17x7 wheel there if needed? or the spare tyre from the previous gen (how will that sound in an interview Q and A! "because we know many owners would have had a 2012/2016 before").
Old 07-23-2021, 11:50 AM   #41
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
What about Brembos and Sachs ?
And no fuel economy figures so far ?
Is the brake booster being electric a similar design as Ford's idea for the Bronco Sport ?
See: 16mins, 34 sec above.
ToySub1946 is offline   Reply With Quote
Old 07-23-2021, 11:50 AM   #42
GraysonGreene
One can only hope they left enough space for one! I meant more of the stock donut which is around 16x4 I think. I definitely am going to try to make it work regardless .
Charlotte, NC
HKS Supercharger Power and Pricing Released! ZC6BRZ Forced Induction 128 05-29-2019 02:14 PM
**Echelon Autosports** AFE Takeda Air Intake .... Low Intro Pricing on all Pre-Orders Echelon Autosports Engine, Exhaust, Bolt-Ons 0 07-26-2012 12:58 PM
New Zealand BRZ Pricing released lazyluka AUSTRALIA 30 04-25-2012 05:54 AM
Canadian pricing released 25,990 Mather CANADA 1 03-31-2012 12:01 PM
