Old 07-14-2021, 01:20 AM   #15
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by gpvecchi View Post
Thanks for the suggestion!
Just to be sure, do you have the JDM TRD and not STi, right?
They are the same shifter, but yes, I have the JDM TRD shifter.
Old 07-14-2021, 07:35 AM   #16
Ohio Enthusiast
Drives: 2018 BRZ
The JDM TRD and STI short shifters are the same. It is the US TRD shifter that is different (and worse, according to all opinions).
Old 07-14-2021, 11:51 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by blsfrs View Post
I have oem shifter with an aluminum Drive Shaft Shop shaft and have no problems. My U joints were bad and it seemed the logical to go with an upgrade. IMHO I did not see a huge advantage in going with carbon fiber.
Originally Posted by FrickingReallySlow View Post
I have a DSS aluminum 3" as well. How long did it take for the U-joints to fail? did you just replace them yourself with a U-joint remover fixture
How did you guys to get yours to stop vibrating? I have a DSS Aluminum as well and it is a hunk of shit. Has been balanced twice, vibrates terribly above 100mph. So bad I can't even see out of the rear view mirror. As far as I am aware, the light weight along with the thickness of the shaft material make it to where the critical speed is too low and it is not possible to resolve. Went back to stock. I won't even give this thing away, I will cut it up and toss it in the scrap dumpster.
Ultramaroon (07-15-2021)
Old 07-14-2021, 12:43 PM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
What did DSS say about it?
Old 07-14-2021, 12:43 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Rebalance it.
Old 07-14-2021, 05:20 PM   #20
gpvecchi
gpvecchi's Avatar
Many people think they are the same, but it's not. STi is 4 mm longer, TRD 8 mm.
Check comparison with stock one.
gpvecchi is online now   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
Ohio Enthusiast (07-14-2021)
Old 07-14-2021, 05:59 PM   #21
Ohio Enthusiast
Drives: 2018 BRZ
Whoa, cool! Meaning that the TRD is the bottom one and the STI is the middle one?
Do you happen to have the part numbers both them?
Old 07-14-2021, 06:42 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The two I had in my hands were identical. Doesn't matter. Any of them will work with a C.F. driveshaft.
Old 07-14-2021, 07:41 PM   #23
StraightOuttaCanadaEh
Wes
Rebalance it.
Mine also vibrates at that exact speed. Will get a carbon one eventually cause I like having a 1 piece ds
Instagram: @gt86ws
Old 07-15-2021, 01:03 AM   #24
gpvecchi
gpvecchi's Avatar
Exactly!
STi ST35010AS000
TRD MS205-18001
Ohio Enthusiast (07-15-2021)
Old 07-15-2021, 10:39 AM   #25
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Exactly!
STi ST35010AS000
TRD MS205-18001
And neither one of them make enough of a difference in shifting to justify the price.
Old 07-15-2021, 10:50 AM   #26
FrickingReallySlow
Drives: 2015 FR-S
Rebalance it.
guessing you checked the U-joint on both sides were solid? I haven't taken mine above 100 mph yet the road/hwy around me have too many potholes if that's where you start to see vibrations. Nothing below 95mph?
FrickingReallySlow is offline   Reply With Quote
Old 07-15-2021, 12:02 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It has done it since new, but yes, both shops checked and inspected it when rebalancing.
I can move it around between 100-105mph but that is about it.
Old 07-15-2021, 12:14 PM   #28
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Just dug up the receipt and verified I have the JDM TRD 8mm short shifter, and the DSS carbon shaft. No issues.
gpvecchi (07-15-2021)
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft Brzzee Transmission and Driveline 1 09-14-2018 09:22 AM
Driveshaft Shop Carbon Driveshaft for Manual Transmission for Sale!! (SOLD) GT86Asia Transmission and Driveline 3 07-30-2018 04:06 PM
I don't know anything about short shifters but... StraightOuttaCanadaEh Engine, Exhaust, Transmission 5 10-24-2017 11:55 AM
