Old 07-12-2021, 05:31 PM   #1
noodle
Drives: 2016 BRZ Limited
Keyfob randomly stops working?
Hi all! Long time lurker. First time really posting anything but these forums have helped me out a bunch before so fingers crossed!
2016 BRZ limited manual. This issue started happening sometime earlier this year. My keyfob has no issues locking/unlocking the car when I grab the handle but occasionally the keyless start wont function properly.
I'll press down the clutch but the car doesn't recognize that the key is present (the green key icon stays off, doesn't flash or anything). What's weird is that if I press the start button, the car will go into accessory mode and the key icon will start flashing green (the icon is flashing, not solid). If I press the start button again, I can turn on the AC unit but the engine wont start.
I've replaced the keyfob battery once already and it seemed to fix the issue for about a month, then it started happening again. I've also tried holding the key fob next to the start button but the car will still fail to start.
This happens very randomly. It'll be good for 2 weeks, then randomly have issues for 2 days straight, then goes back to normal for another few weeks.
Car is pretty much stock, only thing I've changed out are some of the LED bulbs in the car (switched out about 3 years ago) and the head unit (kenwood DMX9706S) was swapped out 2 years ago.
If anyone has this issue or has run into it, any help would be greatly appreciated!
Been awhile :3.
I replaced the clutch switch and haven't had any issues since!
noodle is offline   Reply With Quote
The Following User Says Thank You to noodle For This Useful Post:
humfrz (07-12-2021)
Old 07-12-2021, 06:12 PM   #2
Hello noodle and welcome to posting -
I would suggest you purchase and install another new battery (just to eliminate that possibility). Also, while you have the FOB opened up, I suggest you clean the battery contacts (like with alcohol).
If that doesn't do it it most likely have something to do with the keyless start system, which my car doesn't have - so, bout that thing.
Let us know if you get figured out or don't.
Capt Spaulding (07-12-2021), Ultramaroon (07-13-2021)
Old 07-13-2021, 08:46 AM   #3
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Hi,
I kinda had the same issue, but car started with key near 'start' button.
I changed the battery twice because it would not recognize the fob as I walked up
to the car. So, try that, again. So far no issue but it's only been about 2 weeks
i since I changed the battery for a second time this yr.
CB750F is offline   Reply With Quote
Old 07-13-2021, 10:52 AM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Is it the correct battery? IIRC there’s a battery that is the same diameter but not as thick, so if it’s not the correct size it may not be making contact reliably.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 07-13-2021, 11:04 AM   #5
I once had to go through four batteries in my wife's fob before I found one that actually worked. I think these things sometimes sit on racks for a long long time.
bcj (07-13-2021), g e (07-19-2021), soundman98 (07-13-2021), Ultramaroon (07-13-2021), Yoshoobaroo (07-13-2021)
Old 07-15-2021, 01:51 AM   #6
noodle
Thanks for everyone's input! The issue has stopped for now, but next time it happens I'll try swapping out the battery.
When this happens, the car wont start even with the key pressed against the start button.
I've found some potential info about the clutch switch, so I'll try targeting that next.
Old 07-15-2021, 03:30 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
Yeah,sounding more like the clutch switch. Another test is that a quick press on the start button with the clutch at rest(or a broken switch), and the key present is that the car should turn on the accessory circuit with the radio.
OFT Pops and Crackle Tune just stops working after a while? stig_iv Software Tuning 12 08-21-2018 06:30 PM
2016 key fob randomly not working... Da Brz Issues | Warranty | Recalls / TSB 12 08-19-2018 07:24 PM
Subaru keyfob paired to an FRS? post_break Scion FR-S / Toyota 86 GT86 General Forum 6 04-09-2014 03:57 PM
Does the Toyota Corolla keyfob cover fit the FRS keyfob? FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 6 07-25-2013 06:04 PM
Tired of your prius keyfob? WillBRZ BRZ First-Gen (2012+) — General Topics 41 01-25-2013 12:15 AM
