Drives: White FR-S kosei k4r 17x8
Accidentally cleared cel without getting the code
Hi all. Got a check engine light when I started my frs today.
I got my OFT to read the cel code. I think I might have accidentally mis-pressed buttons and cleared the code before I had a chance to remember and check the code(I can’t be sure I cleared it because it was bright outside and the oft screen was hard to see). I then retightened the gas cap. And turned the car on again the cel light was off. I tried to pull the code again from OFT. And there was no code. I have a few questions related to the clearing of code. 1. If the problem is resolved(ie. gas cap loose). Does the cel go away by itself without manually clearing codes? 2. If a code is cleared does the CEL come back on if problem persists? 3. Is it still possible to Read the code after the CEL has been cleared(ie does the ecu keep a log of codes somewhere? Thanks in advance! |
#2 |
ProCrastinationConsultant
I wouldn't worry about it unless it pops up again. Sounds emission/gas cap related, as you don't mention any drivability issues.
Normally for me at least, if there's something seriously wrong, I'll hear it in the engine note before it pops a code.
#3 |
Not sure about drivability issues as I didn’t drive it since I was worried It might be something serious. I will drive it around tomorrow and see if I notice anything is off.
Hopefully it was just gas cap. The previous day when I filled e85 I gave the gas cap an extra twist after I heard the click. I wonder if that somehow caused the cel to come on. |
#4 |
Also Lasy night I was chasing a Evora in the back roads and pushed the car hard. Hope it’s not something serious.
| The Following User Says Thank You to jiffyjhn For This Useful Post: | humfrz (07-12-2021) |
#5 |
i doubt it. computers aren't that smart.
#6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If it's a serious issue, it will be back and you can check it then.
"Cosmic rays man"
"I gotta rock." -- Charley Brown |
#7 |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
Which tune are you running and what mods does the engine have?
#8 |
Drives: 17 86
#9 | |
2. sometimes 3. sometimes That's all I know about it - ![]() PS - if the CEL doesn't come back, I wouldn't worry about it - |
| The Following User Says Thank You to humfrz For This Useful Post: | jiffyjhn (07-17-2021) |
#10 |
| The Following User Says Thank You to humfrz For This Useful Post: | MuseChaser (07-12-2021) |
#11 |
Pavement Grey
the cel came on one time in my BMW and i suspected it was the gas cap since it came on after i filled it with gas.
I retightened it and then just ignored the CEL and eventually it went away on its own. I couldnt tell you how long it took before it went away cuz it took awhile. |
| The Following User Says Thank You to Sasquachulator For This Useful Post: | jiffyjhn (07-17-2021) |
#12 |
Thanks for replies. Car is fine. I drove it around last week and CEL never came back. All data looks normal.
I'm running OFT Stage 2 E85 with catless headers |
| The Following User Says Thank You to jiffyjhn For This Useful Post: | humfrz (07-17-2021) |
#13 |
| Car running poorly after check engine light cleared | AlexK | Engine, Exhaust, Transmission | 4 | 07-07-2015 03:16 AM |
| MV Designz: OEM professionally Sprayed candy red and cleared $220 OBO | DomoSpeed | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-25-2015 04:28 PM |
| 17x9 or 9.5 that cleared Sti brembo | Vten | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-22-2014 10:10 PM |
| Cleared out reverse taillight housing | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-10-2014 01:28 PM |
| Just need to get something cleared up | MarkMash | AUSTRALIA | 9 | 11-11-2012 09:24 AM |
