Old 07-08-2021, 08:30 AM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
Pirelli - P ZERO All Season Plus
Anyone running these? Reviews/opinions?
https://www.tirerack.com/tires/tires...ll+Season+Plus
Old 07-08-2021, 10:05 AM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
No, but there are better options for cheaper, if you're asking for a comparison that is.
https://www.tirerack.com/tires/surve...jsp?type=UHPAS
Dzmitry is offline   Reply With Quote
Old 07-08-2021, 08:16 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
I've had them on my Focus ST (they were the OEM tires). Decent in the dry, not so good in the wet, decent enough in mild Ohio winters with a bit of snow on the ground and mostly salted/ploughed roads.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Calum (07-09-2021)
Old 07-21-2021, 11:58 PM   #4
Israel Moore
Drives: 2015 Subaru BRZ Limited
They have decent reviews online, people usually compare this tire to Michelin Pilot Sport 4S. You can check out 4wheelonline if you are planning to avail of a set.
Israel Moore is offline   Reply With Quote
Old 07-26-2021, 05:16 PM   #5
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I'm running them in 225/45R17 size on the stock Performance Pack wheels. I swapped them over from my previous car since they were only a few months old. I swapped them a couple of days after taking delivery of the car, so can't really compare them to the stock rubber or anything else on this platform.
In comparison to the Michelin Pilot Sport AS3's I ran before them on my old car, though, they felt a bit less responsive and a bit less grippy both dry and wet, but they had MUCH improved ride quality and road noise. In Tire Rack's testing, they found almost no difference in lap time between the two, IIRC.
Compared to the Continental DWS's I ran before those, the Michelin's were night and day better in terms of grip and about the same for ride and road noise, so I'd say the Pirelli's are probably a touch better than the Continentals.
FWIW, I'll be switching back to Michelin's (the Pilot Sport All Season 4) when it's time for new rubber to get a bit more responsive feel.
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
Calum (07-26-2021)
Pirelli SottoZero 3 - so far really great ~el~jefe~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-19-2017 05:03 AM
FS: YVR only Pirelli Winter 210 Sottozero Serie II $450 Kit523 Canada Classifieds 4 12-05-2016 08:39 PM
Pirelli P Zero Run Flats speeddemon Wheels and Tires 12 04-11-2016 07:26 AM
Pirelli P Zero Trofeo R reviews? Sleepless Tracking / Autocross / HPDE / Drifting 2 02-04-2016 11:24 PM
Pirelli P Zero Nero. Any thoughts? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-26-2013 02:50 PM
