Old 06-25-2021, 01:43 PM   #15
jflogerzi
jflogerzi's Avatar
Hit up zach at csg. He tuned my 210 with e85 and the 69mm pulley. Ran like OEM and with the IC I never had heat soak except on track
2013 Series 10 FRS #553
Old 07-02-2021, 06:17 PM   #16
amirnew
Drives: 2013 BRZ sprintex SC
Originally Posted by 86TOYO2k17 View Post
On 93 the 335 will be questionable. You’ll need to consult your tuner really. Personally I wouldn’t go beyond 72.5mm pulley on 210 if I only had 93. With 92 I wouldn’t even do that and stick to 75mm.
WMI is pretty simple really. And in my opinion is a big piece to the puzzle of solving the biggest flaw/issue with the sprintex kits. Heat.
Hi!,
Can you or someone here show picture of your wmi kit install? Where dod you install it?
Im having the heat soak issues with my 210 and 75 mm pulley on 98 octane(ita like 93 i guess in the us)
Did someone tested water sparing the cooler like in old days stis?
Does hood vents change dramatically the heatsoak issue?
It's not only heat soak, in gemerally my charge temps are high after few geara pull and take a lot of time to cool.
amirnew is offline   Reply With Quote
Old 07-02-2021, 06:20 PM   #17
jflogerzi
jflogerzi's Avatar
Originally Posted by amirnew View Post
Hi!,
IC or no IC?
Old 07-02-2021, 06:23 PM   #18
amirnew
Another question ,
Has anyone found,saw, bigger cooler with the same piping like the sprintex one?
Bigger cooler will just kill the heatsoak issue
Old 07-03-2021, 01:32 AM   #19
amirnew
Originally Posted by jflogerzi View Post
IC or no IC?
Im with the ic version.
I really just think we need to find thicker cooler.
Anyone knows what to look for in ebay for example?
Old 07-03-2021, 01:34 AM   #20
jflogerzi
jflogerzi's Avatar
Remember this is a air to liquid cooler. You still have the stock plastic intake pipe or you running metal?
Old 07-03-2021, 09:58 AM   #21
amirnew
Stock plastic one for oem look... Cops issues here... Though today to gold plate the bottom half of it that gets a lot of radiated heat
Old 07-03-2021, 10:29 AM   #22
jflogerzi
jflogerzi's Avatar
What do your IATs look like? Is your sensor in the stock location? And how do you know your heat soaking?
Old 07-04-2021, 06:43 AM   #23
86TOYO2k17
Drives: 2017 toyota 86
Hi!,
I trunk mounted tank and pump, controller in glove box, thread tapped the map plate to run a boost reference, and injected into throttle body spacer.
I have also done on other builds just thread tapping windshield washer reservoir and mounting pump right next to it, that is the simplest and most cost effective method.
Frozen boost has a larger heat exchanger, you can also run a bigger pump with more flow.
Hood vents/scoops will help a little bit.
You could T off a wmi line and run a nozzle aimed at heat exchanger.
killer chiller/inter chiller also would help tremendously
Old 07-09-2021, 02:40 PM   #24
amirnew
I have on boost when "spiritual driving" of around op to 75 dec Celsius.
On 2-4 gears pull i can see even 86 dec Celsius or a bit higher.
My iat are on the intake manifold after the sc ...
Did someone tried bigger cooler?
Old 07-09-2021, 04:18 PM   #25
86TOYO2k17
WMI is a tried and true god send for IATs and heat soak.
Killer Chiller does wonders for IATs as well.
Larger HE will help a bit as well
Lots of options.
Not sure how much people on this platform with the sprintex 210 have done beyond the standard IC setup.
One user did make a full jacket for the SC unit that seemed to help but that was a one off.
I had WMI and it did wonders for IATs/heatsoak.
Air to Water HE/IC setups are common practice, principles that work and apply to any platform will work and apply to this.
Killer Chiller can make intercoolers frost over they get so cold.
You would need to figure out your own mounting solution but frozen boost has larger HE that would be easy to incorporate.
you could also get a larger reservoir and/or relocate it. larger capacity prolongs heat seek and moving the reservoir further from the engine / SC unit will prevent reservoir heat soaking removing one source of heat.
So many options.
Not many that people on this platform have done, but all have been done by many on other platforms and are proven to work.
You'll have to figure out your own solutions for this platform if you want to take it beyond the typical setup.
Old 07-12-2021, 08:31 PM   #26
amirnew
Lots of options.
So many options.
Thank you for your response! I guess the solution for must be the water injection to reduce the temps.... Didn't actually wanted to go that way, really preferred something passive that will help but I'm starting to understand there isn't such thing, and if i want to enjoy the car with this kit i must do it...
Any photos from your car? The meth install?
Old 07-15-2021, 05:26 AM   #27
amirnew
Lots of options.
So many options.
And do you have pictures or something to explain how you tapped the map sprintex plate?
Old 09-04-2021, 07:49 AM   #28
amirnew
Update.
Installed wmi kit aem v3. I see abot 20dec Celsius under flat foot acceleration ,few gears puls. Chaned my life.
[FS] Sprintex Intercooler Kit brybot Engine, Exhaust, Bolt-Ons 8 03-26-2020 11:31 AM
sprintex 335 kit in TX blown Engine, Exhaust, Bolt-Ons 10 07-25-2019 11:45 PM
Sprintex 210, E85 and ACE 350? sqd Forced Induction 28 06-18-2019 02:55 PM
Sprintex Questions Cross Forced Induction 5 07-23-2015 04:09 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
