Old 07-03-2021, 12:32 AM   #19181
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
No pics, but got alignment and brake fluid flush done today.
Alignment - Completely stock PP except for SPC camber bolts (bottom hole) and OEM 14mm bolts on the top hole up front. My shop was able to get -2.2 deg on each side up front. Rear is completely stock, so it's stuck at -1.5 both sides with 1/16" total toe in. Outside shoulders on the front tires were taking a beating from the past couple Auto-X events, so hope this will help.
Brake fluid flush - Flushed with ATE Type 200 in prep for track events in the near future.
NaturallyAspirated is offline   Reply With Quote
Old 07-03-2021, 04:47 PM   #19182
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Perrin Intake Tube
Clearing a little bit of the engine bay + sound tube delete. Liked!
Stonehorsw is offline   Reply With Quote
Old 07-05-2021, 09:46 PM   #19183
in_sherman
Drives: 2017 BRZ Performance Package
uhh swapped out front lca assemblies and didn't solve noise/vibration problem
ordered $400 more parts to throw at the issue
THANKS for asking</stress post>
in_sherman is offline   Reply With Quote
Old 07-06-2021, 05:21 PM   #19184
Zad1000
Zad1000's Avatar
Drives: 2017 Subaru BRZ PP
Rotors Turned, bled the brakes, new pads, and *drumroll* ...changed the spark plugs! All in one day. I am a man now. I am also dirty, bruised, scraped, and slightly poorer. I am so happy I was able to do the plugs!
Zad1000 is offline   Reply With Quote
Old 07-06-2021, 07:12 PM   #19185
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Killed a few mosquitoes/grasshoppers/dragonflies etc...
Good thing I like detailing
wolffbite is offline   Reply With Quote
Old 07-07-2021, 06:51 PM   #19186
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Good stuff Jr
Old 07-07-2021, 07:07 PM   #19187
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Added some more scars to the bumper (and probably the under carriage, haven't looked yet)
BirdTRD is offline   Reply With Quote
Old 07-07-2021, 07:16 PM   #19188
soundman98
ProCrastinationConsultant
soundman98's Avatar
you know, when my parents where kids, when they got a free tire, they were happy about it.
Old 07-08-2021, 12:33 AM   #19189
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Got my sensor interface wired and connected to power. I am pulling RPM reference off of coil pack number 1. I have not connected it to my laptop yet to verify it is reading. Tomorrow I hope to daisy chain my gauges to the interface and to my data logger for a dry run to make sure it will record.
Old 07-12-2021, 12:55 PM   #19190
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Flushed the brakes and cleaned and re-greased the slide pins.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-13-2021, 02:47 AM   #19191
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Installed Perrin 22mm front sway bar. People say this is a simple 1hr job but they failed to mention all the underbody panels. Removing the skid plate, the transmission aero cover, the two underbody aero covers behind that, and the draw stiffeners made the job a lot bigger than on early MY cars that had nothing underneath.
N_Raged is offline   Reply With Quote
Old 07-13-2021, 08:21 AM   #19192
StraightOuttaCanadaEh
Wes
What made you want to install one of these?
Instagram: @gt86ws
Old 07-13-2021, 03:41 PM   #19193
N_Raged
Autocross
https://www.ft86club.com/forums/show...postcount=4090
Old 07-14-2021, 03:41 PM   #19194
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
STI goodies
Changed oil, tire rotation and some STI parts
2020BRZtS is offline   Reply With Quote
