Old 07-02-2021, 10:59 AM   #1
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
200TW Tire Test
Stumbled across this and found it interesting.
The Following 7 Users Say Thank You to NoHaveMSG For This Useful Post:
BigTuna (07-02-2021), churchx (07-02-2021), Four_wheel_drifts (07-02-2021), gen3v8 (07-02-2021), Mike_ZN6 (07-02-2021), RToyo86 (07-02-2021), SCFD (07-02-2021)
Old 07-02-2021, 01:14 PM   #2
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Looks like the BFGoodrich Rival S 1.5 is still king of the hill over the Advan A052. The A052 seems to wear much faster than the Rival S 1.5 as well.
Mike_ZN6 is offline   Reply With Quote
Old 07-02-2021, 01:48 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Which is surprising to me considering the A052 seems to be a more popular track tire. Though GTA pushing it probably helps that.
The Z3 felt as he described to me though I was able to get pretty good consistency out of it even when hot, that could come down to the way a twin uses it's tires compared to that m3. It was strange to me he rated the RS4 as comparable as I did not think it felt like the Z3 at all and I didn't like it that much.
Now that I think about it the braking on the RT660 was very good and easy to modulate. I haven't got to run these on a track I am familiar with yet, but I was pretty impressed with them.
Old 07-02-2021, 02:19 PM   #4
RayRay88
Drives: 2017 86 860 Special Edition
Just a guess but brand recognition is high up there too. BFG used to advertise heavily in the 90's and early 2000's and now I just don't hear too much from them. It also doesn't help that Advan has the cool JDM thing going for them. In any conversation i've had with people about competition/track tires it's always the usual suspects - Bridgestone, Falken, Advan, Michelin, Hankook, Kumho, Continental/Hoosier.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
NoHaveMSG (07-02-2021)
Old 07-02-2021, 04:36 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
AFAIK Rival S 1.5 was never considered "king of the hill". Before A052, it was RE71R > Rival > all else. When A052 arrived it was generally regarded (and tested) fastest of the 200tw tires. I've seen results suggesting RT660 = or better vs. RE71R, assumed it was a couple/few ticks behind A052.
Results showing Rival faster than A052 are surprising to me, but maybe they've been quietly improving it over the years. Meanwhile I bought a set of 245/40-17 Nankang CR-1s and a set of 235/45-17 A052 for time trials this year, if I have budget left I might try the Rival S 1.5 before end of year!
Old 07-02-2021, 05:27 PM   #6
Four_wheel_drifts
Drives: Whiteout track car; lava donor
My experience with the RE71R is that they were very good here in the PNW during Spring and Fall. But if run close to or above 80F ambient, I could kill them in a single track day.
They were a good tool that allowed me to play with GT3’s and GT4’s (I’m a PCA national instructor) running CCW at ORP. But due to the rapid wear, I couldn’t afford to continue running them.
They also seemed to camber wear more than any other tire I’ve used.
A student that I right seated with recently had the Azenis. He also made the comment that they were comparable to the RE71R. But long before I finished the day with him, I thought “These are no RE71R’s.”
Four_wheel_drifts is offline   Reply With Quote
Old 07-02-2021, 06:48 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Too bad our lapping days never line up. I'd let you bolt up my set and try them.
Old 07-02-2021, 06:51 PM   #8
Mike_ZN6
Mike_ZN6's Avatar
Yeah, but they discontinued the RE71Rs. I thought the Rival S 1.5 was the best option for some time before the A052 released. I was under the impression the A052 was faster than the Rival S 1.5, but I am not so sure after seeing this test.
Old 07-02-2021, 08:37 PM   #9
jflogerzi
jflogerzi's Avatar
The 660s are close to re71s but not quite there. Yoko AO52s are your closest comparable
2013 Series 10 FRS #553
Old 07-03-2021, 09:51 AM   #10
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Great comparison. Keep in mind the Rival S 1.5 are just about the worst 200TW tire in the wet. I've run RE71R, A052 and the Rival 1.5's and really like them all, but I'm way more comfortable running the RE71R or even the A052's in the wet.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
jflogerzi (07-03-2021)
Old 07-03-2021, 11:29 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
It was funny to see vid that best results in wet people got using tires like MPS4S even on eg. supercars like mclaren's .. i have strong suspicion, that regarding these particular tires tested it's less about which is best in wet, more about, which sucks less in wet.
MrSkubi (07-07-2021)
Old 07-06-2021, 07:58 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
New(ish), I've found the RE71R and A052 to both be *outstanding* in the wet at the track, in the pouring rain with some standing water. If you can keep your wits for brief instances of hydroplaning...
Goingnowherefast (07-06-2021)
Old 07-06-2021, 08:04 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Z3's were also good in the rain.
Old 07-06-2021, 09:12 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
But they won't suffer from eg. excessive cooling off driving through puddles? Or compound of these tires doesn't need to be brought upto temps?
New 200tw tire from Continental RayRay88 Tracking / Autocross / HPDE / Drifting 24 08-23-2021 12:23 PM
Maxxis VR-1 (New 200TW tire) CSG Mike Tracking / Autocross / HPDE / Drifting 64 03-31-2021 04:10 PM
Unusual Tire Wear - Test xdavidx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 10-10-2019 07:49 PM
Maxxis VR-1, New 200TW "Extreme summer performance" tire CSG Mike Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 06-01-2016 05:04 PM
