#449 |
Vehicle Mileage: 100k (currently)
Vehicle Make: Scion FR-S Mileage After Recall Performed: performed at around 85k, so ~15k miles ago Symptom(s): One unexpected stall while pulling back into grid after its 4th run at an autocross, but it restarted and idled without issue immediately afterwards. Part-way through the next run it sounded harsh/ragged for about 5 seconds during a 2nd gear pull and then the engine failed hard. Remarkably, no CEL before or after. Failure: Totally destroyed the contents of cyl. #3, punched hole in top of block, and other related carnage. Sealant material found in oil pickup during engine teardown. State: Missouri Is Dealership Offering Repair: No. Currently getting a new bottom end (and other parts that were damaged) at an independent shop. More details: Car drove without issue following the recall in early 2019, even surviving a full season of autocross. It then only saw a limited amount of normal driving during 2020 due to Covid. 2021 rolls around, the car gets an oil change, and resumes autocross. It survived the 90 minute drive to the venue and its first 4 runs, but not the 5th. Towed to a local Toyota dealership that wasn't remotely interested in hearing that the recall might have been related to the failure, given the time since the recall and the usage of the car. Their engine replacement option also left a lot to be desired ($8k for a 60k mile engine of the same year with only a 90 day warranty... yeah, no). After hearing that, the car was transferred to known good, enthusiast-friendly indie garage. Surprise surprise, their teardown found quite a lot of sealant material in the oil pickup and other evidence of poor application. Pretty confident this led to its premature demise... Some pics of the carnage and oil pickup: https://i.imgur.com/FbFmY3T.jpg https://i.imgur.com/HGRROrR.jpg https://i.imgur.com/jpPDeRA.jpg https://i.imgur.com/ssZ9SEJ.jpg https://i.imgur.com/2tsUnhk.jpg Last edited by t0ast; 06-15-2021 at 11:38 AM. |
#450 |
Drives: 2022 GR86 (was 2013 BRZ)
Vehicle Mileage:115,000 miles
Vehicle Make: 2013 Subaru BRZ Mileage After Recall Performed: 15,000 miles, and 18 months Symptom(s): Rod knock. Failure: Runs, but makes bad noises State: CA Is Dealership Offering Repair: Work was done by Stevens Creek Subaru. I don't think I'll even try to get anything out of the dealership, given others experiences.
| The Following User Says Thank You to treedodger For This Useful Post: | DarkSunrise (06-22-2021) |
#451 | |
2022 BRZ Build 2013 FR-S Build |
#452 | |
I always ran 5W30 full synthetic and changed at 5k miles. I think Castrol this time. In hind sight I wish I had installed an oil gauge with a warning light set to pressure higher than the idiot light, or at least pulled the pan after the recall to check the oil intake screen. It may be unrelated to the recall, but I'm highly suspicious given others experiences. Once out of the car, I'll pull the old engine apart and see if I find any smoking guns. Aug 2021 UPDATE: So I pulled the engine and inspected the oil pickup screen, and it was pretty clean. No large amount of sealant, just a few small bits. So no clear smoking gun of sealant in the oil, unless a lot of small bits made it through the oil pickup screen. Replaced engine with 30k mile 2015 Junkyard engine, and we on the road again.
| The Following User Says Thank You to treedodger For This Useful Post: | DarkSunrise (07-01-2021) |
#453 | |
#454 |
Drives: '13 Scion FR-S
I don't know if this is the place and don't want to muck up the thread but I had engine failure not too long ago. Had my engine replaced with my personal mechanic because the dealership wanted too much money for a used engine with higher usage. In California the recall has triggered a registration blockage and I'm unaware of whether the recall was carried out on the donor engine.
I'll be heading into the dealership to have the new engine checked. Any advice? |
#455 | |
Drives: 2015 FR-S
Blackstone-labs also can analyze a small sample of your engine oil and for 30$ tell you all the contaminants. You can also ask them specifically to check for chemicals that would resemble "sealant" its only $30 Also how much was your engine + labor cost? |
#456 | |
Drives: Ultramarine Scion FR-S
Vehicle Mileage:105,000 miles Vehicle Make: 2013 Scion FR-S Mileage After Recall Performed: 7,000 miles. 11 months since Aug 2020. Symptom(s): Rod knock. Failure: Runs, but makes loud rattling noises. No check engine light. No oil light. Just loud knocking at start and throughout drive. Stopped driving it asap. State: CA Is Dealership Offering Repair: No, they kept my car for a week to diagnose, but technician denies that it has to do with the recall. They mentioned possible oil starvation, but they’re the ones who just did my oil change a month ago. Dealership said they would need to open the engine to diagnose further, but they would have to charge me “a couple thousand” just to take engine apart and asked if it’s even worth it to fix? He said it’d be $9k to replace the engine. I can’t afford that. Towed the car home with my insurance and it’s a sitting duck. I avoided the J02 recall until California mandated it and withheld my registration until I got it done. Car was running fine before this. Daily commuter car, never autocrossed, barely drove this year working from home due to covid. Same dealership did a multipoint inspection, oil change and coolant change June 2021. Bought and installed new tires as recommended. Rod knock July 2021. Waste of brand new tires. What can I do? Is the repair under 12 month warranty if they deny it’s related to the recall? How can I prove it is related? What else would it be? Should I run it up the food chain at the dealership? I feel helpless and stranded without my one and only car.
Invidia n1 | Valenti smoked tails | CF spoiler | shark fin
#457 | |
You might also insist on a disinterested party doing that work, but that may involve you agreeing to drop the claim if the screen is clear.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#458 |
BRZ N02
Drives: 2013 A/T Subaru BRZ Limited, SWP
Is there any apparent correlation between post-recall failure and Toyota service technicians performing the work?
#459 | |
There have been both.
| The Following User Says Thank You to Dadhawk For This Useful Post: | x808drifter (10-15-2021) |
#460 | |
BRZ N02
I took my '13 BRZ to the dealership I bought it from for the recall, and have since clocked an extra 40k miles, no issues related to the fix that I can tell. They service a lot of modified Subarus and I suspect they have techs that would know how carefully the RTV should be applied. I don't imagine Toyota techs have that same experience/knowledge in general. Anyway, just wanted to add my thoughts. I'm probably repeating someone else.
| The Following User Says Thank You to Baldoak For This Useful Post: | Dadhawk (12-16-2021) |
#461 |
Drives: '13 Whiteout
The mechanics at the dealerships aren't allowed enough time to do the sealant correctly in many cases hence the issues.
#462 | |
| Tags |
| fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
| TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-18-2019 11:24 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 06:49 PM |
| Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 07:23 PM |
