Old 06-25-2021, 05:09 AM   #1
J95
J95's Avatar
Spare parts that worth having at home?
Hello,
I bought a couple of Wheel lug stud SU00300781, because they are cheap and I read they are prompt to break. I will order also some exhaust gaskets because I changed it a couple of times and now itīs leaking
I do track my car and I do frequent jobs like brake fluid bleeding, oil change... So I wonder if there is something else that is likely to need an exchange, so itīs worth to have in stock. For example what about bleeder screw? SU00300582
J95 is offline   Reply With Quote
Old 06-25-2021, 09:22 AM   #2
whataboutbob
AutoX-10/10ths every run
An OEM axle. At least 1 coilpack. Spare set of front brake pads.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
J95 (06-29-2021)
Old 06-25-2021, 01:20 PM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Spare OEM parts or parts that can replace OEM when they break to save your butt?
Why get OEM studs when ARP studs exist?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
J95 (06-29-2021), Overdrive (06-29-2021)
Old 06-28-2021, 05:46 PM   #4
It has been my experience that whatever part gives out, you won't have a spare on hand.
I still have a spare fuel pump for a 1948 Chevrolet - if anyone is interested -
The Following 5 Users Say Thank You to humfrz For This Useful Post:
Capt Spaulding (07-03-2021), J95 (06-29-2021), Lantanafrs2 (06-30-2021), soundman98 (06-28-2021), Ultramaroon (07-02-2021)
Old 06-29-2021, 07:14 PM   #5
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I'm with Wally, here. One of my wheel studs broke off in the lug nut. Rather than just replace the one that broke and have to deal with it again when another one breaks, bit the bullet and replaced all 20 with ARP studs. Not cheap in the moment, but I'm pretty sure these studs are going to outlive the car, so we'll call it cheap insurance. Makes even more sense to be proactive if you're going to be taking the wheels on and off frequently for brake maintenance. If you manage to wreck an ARP stud, well...yikes. By the power of Grayskull!
Some of the spares I keep around at the moment, nothing spectacular:
Stock air filter for when I have to clean my aftermarket drop-in one (doesn't apply to people who have changed their whole intake, of course).
Bottle of 50/50 premixed Subaru coolant.
Set of spare signal, low beam and high beam bulbs.
Quart of oil.
Spare fuses.
Also, while they're not "parts", with how much they've shrunk in size now, I always keep one of those small power bank/battery jumpers and a small air compressor in the trunk, because dead batteries never happen in convenient places, and I'm admittedly bad about keeping my spare tire pressure up as regularly as the main 4. Good for adjusting tire pressure for auto-x and track days as well.
And after seeing whataboutbob's suggestions I think I'm going to throw those things into my spares too.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Wally86 (07-01-2021)
Old 06-30-2021, 07:30 AM   #6
chipmunk
Drives: _
Subaru's Supercoolant jug.
chipmunk is offline   Reply With Quote
The Following User Says Thank You to chipmunk For This Useful Post:
Old 06-30-2021, 10:43 AM   #7
Lantanafrs2
Drives: 2013 frs red
Does it have crickets?
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
humfrz (06-30-2021), Ultramaroon (07-02-2021)
Old 06-30-2021, 11:00 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
For me, it has been front hubs. I keep at least one loaded set with me. I also carry a spare CV, couple coil packs. Consumables are a given, always have them on hand.
I do have a spare TOB, transmission, engine. You know, the basics.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Capt Spaulding (07-03-2021), Ultramaroon (07-02-2021), Wally86 (07-01-2021)
Old 06-30-2021, 11:01 AM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Brake hardware kits are good to have on hand.
I've needed to replace slider pin bushings and pad clips on the fly due to random damage
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 06-30-2021, 03:10 PM   #10
Nope.. It just quietly goes ahgaha - ahgaha , like they used to do - whoops, wait one ....... the rubber diaphragm just disintegrated after the third ahgaha - I reckon it's time to toss it ......
Old 07-01-2021, 06:32 AM   #11
chipmunk
Drives: _
Let me also add:
Low profile mini fuses
Bulbs for side marker lights (others are LEDs)
A pack of condoms to give to KIA or BMW drivers trying to drag race you, so they won't reproduce.
Old 07-01-2021, 06:33 AM   #12
chipmunk
Drives: _
It will buff right off
The Following 2 Users Say Thank You to chipmunk For This Useful Post:
humfrz (07-01-2021), Ultramaroon (07-02-2021)
Old 07-01-2021, 02:02 PM   #13
I sorta tried that once - I made a diaphragm out of a piece of inner tube - it didn't work too good - I still had to go to the junk yard to get another fuel pump -
Ultramaroon (07-03-2021)
Old 07-01-2021, 06:34 PM   #14
He probably got it straight from Moses so likely locusts.
humfrz (07-03-2021), Lantanafrs2 (07-01-2021)
Query about Toyota 86 spare parts in UAE .neji MIDDLE EAST 6 03-13-2022 01:24 AM
Blown/spare parts engine Charleston, SC Garrett86 Engine, Exhaust, Bolt-Ons 0 05-15-2019 05:18 AM
Bringing home parts from Japan stocktc1 Scion FR-S / Toyota 86 GT86 General Forum 20 11-05-2016 03:16 PM
Where to get spare parts on the cheap? shay999 AFRICA 9 11-22-2015 10:16 AM
Final drive spare parts misooscar Want-To-Buy Requests 0 08-28-2015 10:45 PM
