Old 06-26-2021, 02:14 PM   #1
Jimbsy
Drives: 2017 860 Halo White
Steering Issues after minor Collision
Hello all
Last weekend during the storm my 86 hydroplaned in a roundabout and the front right wheel hit a curb bending the control arm (Which I have now replaced), along with that, I had gotten an alignment done yesterday. Post all of this, I have been having some issues with my steering on the right side, this side feels heavier to move, and when turned and letting go of the wheel, the wheel will not return back to the neutral position and stays turned (doing a little wobble). Furthermore, when in the neutral position, if you pull down slightly and release, the wheel will wobble (Video attached). Wondering how I should go about getting these issues resolved.
Thank you!
(link to the wobble)
Jimbsy is offline   Reply With Quote
Old 06-26-2021, 02:28 PM   #2
Decep
Drives: 2013 FR-S Series 10
did you inspect the wheel and tire ?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 06-26-2021, 02:46 PM   #3
norcalpb
norcalpb's Avatar
I recommend inspecting the outer tie rods
Old 06-26-2021, 03:42 PM   #4
Jimbsy
Yes, the rim wasnt bent and the tire was still in good shape
Old 06-26-2021, 03:42 PM   #5
Jimbsy
Alright, I will check them out
Old 06-26-2021, 04:07 PM   #6
Jimbsy
I attached 2 images I took of the tie rods, anything look off?
Old 06-26-2021, 09:01 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Did you re-balance the wheel after the accident?
Old 06-26-2021, 10:21 PM   #8
norcalpb
norcalpb's Avatar
I’m not 100% sure, but that large grease splatter below the tie rods looks pretty fresh.
Old 06-26-2021, 11:01 PM   #9
I'd suggest you rotate the wheels (front to back) just to insure a wheel/tire isn't causing the problem.
If that doesn't do it, I'd suggest you have the right front wheel bearing and assembly inspected closely.
Old 06-27-2021, 12:59 PM   #10
pope
has a funny hat
Drives: 2014 BRZ Limited
I’d assume that is a byproduct of having the alignment done.
Personally, I’m concerned about the multiple shiny threads on the tie rods. Requiring that much lengthening to correct the toe makes me think you still have bent/broken parts under there. Strut, spindle, steering rack, subframe have it all checked.
Also, as previously suggested by another, have the wheel rebalanced if it hasn’t been. And, remove the tire from the rim and have both inspected if that wasn’t done as well.
pope is offline   Reply With Quote
The Following 2 Users Say Thank You to pope For This Useful Post:
Turdinator (06-27-2021), x808drifter (06-27-2021)
Old 06-30-2021, 08:35 PM   #11
Grady
Grady's Avatar
If the rim was bent the tire was probably damaged also. You can not see internal stress on the tire. I would replace tire and make sure they balance correct. Do you have post accident alignment numbers?
Old 07-05-2021, 09:21 PM   #12
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Not really, that's like 2.5 turns. Nothing to worry about on a new control arm install after a bash.
Now, about the original issue (s). A wheel balancing is ALWAYS recommended after a hit even if nothing seems visually bent. As for the steering effort, well...
NOTICE:
Initialize the rotation angle sensor and calibrate the torque sensor zero point if any of the following conditions occur:
The power steering ECU is replaced.
The steering column assembly is replaced.
Steering effort differs between turning left and right.
Says the repair manual.
Steering column issues kkronja Issues | Warranty | Recalls / TSB 3 11-18-2020 04:39 AM
Minor issues after J02 recall... nextcar Issues | Warranty | Recalls / TSB 3 11-13-2019 05:31 PM
First BRZ Collision? DjDATZ BRZ First-Gen (2012+) — General Topics 17 07-09-2012 10:11 PM
got into my first collision statuskuo Off-Topic Lounge [WARNING: NO POLITICS] 48 02-14-2012 04:19 PM
Steering Issues? (Toyota Recall) Buggy51 Other Vehicles & General Automotive Discussions 8 11-10-2011 02:07 AM
