Drives: 14 FRS Monogram, 05 Mazdasped Miata
Spark plugs
2014 running E85, but I may have to go back to 93 since E85 is hard to get here. 50K mile DD and I'm about to change plugs. From what I read here, most use the OEM. Is there a better choice?
#2 |
Drives: 2014 DGM BRZ Turbo
I believe HKS makes a set that is considered "one step colder" but in reality it makes little to no difference. I run OEM and I'm turbo'd and they work perfectly, don't change the gap. Order the Toyota version rather than Subaru and they come out to be much cheaper.
| The Following 2 Users Say Thank You to Olson1288 For This Useful Post: | Qwimby1 (06-16-2021), soundman98 (06-17-2021) |
#3 |
My advice: Skip the plugs altogether until you drop an igniter. Bet they'll last 100 Kmi or longer.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (06-17-2021) |
#4 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (06-17-2021) |
#5 |
Coil pack? When the iridium tips in the plugs burn, they make the igniters work extra hard. Igniters already don't last forever so it doesn't matter. Might as well do them all in one fell swoop.
...IMHO
#6 | |
Changing them together is a big expense and if done , potentially delicious tuning ones? Sent from my SM-G781B using Tapatalk |
#7 | |
#8 | |
Normally, they're like headlight bulbs. When the first one goes, just suck it up and change them all.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Brz-123 (06-25-2021) |
#9 |
Drives: 2013 Scion FR-S 10
FWIW I had a coil pack on my passenger side die a year and a half ago.
Replaced that one coil and I have not had any issues since. I abuse the car regularly, although maybe not as much as those who have racetracks to go to. its nice to know that I can just get the toyota plugs and not worry about gapping them. I am supposed to do that sometime soon, but im not sure how Im supposed to get the tool in there even if I jack up the motor a fair bit. (the tool for the plugs) |
#10 | |
#11 | |
And IIRC MY15 onwards had a revised set which are reliable compared to the ones before Sent from my SM-G781B using Tapatalk |
#12 |
I don't know. If there's truth to the factory change I imagine they'd be a sub for earlier model years. Personally, I'd try those before going aftermarket. That's just my mistrust for aftermarket talking there.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Qwimby1 (06-26-2021) |
#13 |
| The Following User Says Thank You to KN0W For This Useful Post: | Ultramaroon (06-25-2021) |
#14 | |
https://www.delicioustuning.com/node...QaAgYzEALw_wcB https://www.delicioustuning.com/node/958 Sent from my SM-G781B using Tapatalk |
| The Following User Says Thank You to Brz-123 For This Useful Post: | Ultramaroon (06-25-2021) |
| Spark Plugs | FR-S2GT86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 09-16-2020 02:23 AM |
| OEM Spark Plugs - NIB | JohnPayneFun | Mechanical Maintenance and Tools | 2 | 04-20-2020 03:03 PM |
| spark plugs | Legend@wheels | Engine, Exhaust, Transmission | 3 | 12-12-2018 12:13 AM |
| How to gap spark plugs | Strife26 | Engine, Exhaust, Transmission | 38 | 01-09-2018 01:06 AM |
| Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 10:47 AM |
