Old 06-22-2021, 05:58 PM   #141
Greg_2086
Drives: 2020 86
Thanks to all involved for the testing to get the trunk door speaker amplifier functioning with the 2020 build configuration! Cannot wait to hear the difference with intended power and low-pass filter.
To clarify the wires of the antenna harness, is the smaller wire the antenna turn-on and the larger the radio signal?
After cutting/de-pinning the unused brown amplifier turn-on wire, it should be spliced to the antenna turn-on wire (referring to oddrelic’s post #132 it is spliced to the smaller antenna wire).
2020 86 Neptune, TRD handling package, TRD lowering springs
Build Thread
Greg_2086 is offline   Reply With Quote
The Following User Says Thank You to Greg_2086 For This Useful Post:
FR-S2GT86 (06-22-2021)
Old 06-22-2021, 07:45 PM   #142
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
For further clarification, the larger "wire" as you referred to it is actually the antenna CABLE. Don't tap into that. Tap into the small wire next to it in the plug. See these two pictures here with the red arrow pointing to the wire in question.
Tap the wire in the below picture indicated by the red arrow into the wire in the above picture AFTER you de-pin it from the ten-pin plug,
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Greg_2086 (06-22-2021)
Old 06-23-2021, 12:41 AM   #143
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
@Tcoat
I stand by what I say. I've just ordered all of the necessary radio harness and antenna adapter parts to build you a Model Year 19+ 86 Harmon Base Audio Head Unit / Factory Door Speaker Amplifier Retainer Package for your system. No wires will have to be cut, de-pinned or tapped into by you or your installer, it will be designed to be a simple plug-and-play installation. When I'm finished building it, I will gladly send it to you so that you'll have it to install........as soon as your factory warranty is up in about 4 more years.
......Or you can just install it or have it installed when you receive it. It won't take but 15 to 20 minutes with the right tools available.
PM me your address so that I can ship it to you when it's ready. I'll even include detailed instructions in paper form to ship along with it. You have my assurance that it will work properly in your Hakone Edition.
On a side note:
One of the other members here will have to test for, and build a harness to get the back up camera to display on the head unit for you, since I don't have any of those features in my car.
I invite anyone else here who has this Harmon Base Audio Head unit, and who has the experience and skills to test for and build a plug-and-play backup camera integration harness for Mr. Tcoat to please do so. I'm sure he will be grateful.
The Following 4 Users Say Thank You to FR-S2GT86 For This Useful Post:
86-75309 (06-23-2021), Tcoat (06-23-2021), Wally86 (06-23-2021), WildCard600 (06-25-2021)
Old 06-23-2021, 04:28 AM   #144
Originally Posted by FR-S2GT86 View Post
@Tcoat
On a side note:
You are a man of honour!
LOL Since I actually drive my car the warranty will be up (based on mileage) before the end of this year.
Since no wires will be cut I will install as soon as I can.
The camera I can get used to since I don't rely on it anyway.
Old 06-23-2021, 07:58 PM   #145
86-75309
Drives: Until recently, a 2020 Hakone 86
I'll be looking forward to a report on the installation of the plug-and-play harness kit.
As soon as I can overcome my fear of mangling the dash trying to remove the head unit, I may inquire about the possibility of purchasing a copy of the harness for myself.
I'll live with the back up camera the way it is for now. Eventually I may even get used to it.
86-75309 is offline   Reply With Quote
The Following User Says Thank You to 86-75309 For This Useful Post:
FR-S2GT86 (06-23-2021)
Old 06-24-2021, 03:29 PM   #146
Autoxer62
I wouldn't presume that FR-S2GT86 wants to build harnesses for anybody else besides Tcoat, but maybe he'll be kind enough to share a parts list and photo? Thinking about the project it'll be a little tedious but really not all that difficult (everything goes straight across except for one wire).
In any case, thanks for running all this down for us!
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
Wally86 (06-24-2021)
Old 06-24-2021, 05:13 PM   #147
oddrelic
oddrelic's Avatar
Drives: 2020 86 Hakone
If you're not worried about the Dealership giving you issues, it's very easy to unpin the brown wire and a couple bucks worth of wire and a tap that all can be found at Walmart is all you need. It's a 20 30 min project for anyone not very familiar with wiring. If there's enough demand I'm sure we can come up with a how to video.
Sent from Tapatalk
oddrelic is offline   Reply With Quote
The Following 2 Users Say Thank You to oddrelic For This Useful Post:
86-75309 (06-24-2021), Wally86 (06-24-2021)
Old 06-24-2021, 06:10 PM   #148
86-75309
I used to know my way around car audio, back before they started putting computers in everything. A nice wiring diagram and a parts list, along with some courage, may be all I need.
Old 06-24-2021, 08:58 PM   #149
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
@Tcoat is getting the first one, no charge just because he was the loudest when it came to complaining about how much his system sucked, and I just wanted to challenge myself to see if I could solve his issue for him.
I don't have a problem building some of these harnesses and sending them out, but I'll only be soldering and heat shrinking his. I'm not doing this for profit so if you guys want to pay for the parts and shipping, I will gladly put them together with crimp caps and move the pins into the correct plug positions for you before sending them out. If you wish, you can always cut the crimp caps off and solder and heat shrink them yourselves.
If you guys would rather me just post a list of parts, some good pictures and some step-by-step instructions, I can do that also. I would of course start a completely new how-to thread if I do.
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
Wally86 (06-25-2021), WildCard600 (06-25-2021)
Old 06-25-2021, 07:34 AM   #150
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I vote pictures and step-by-steps.
Most of it seems pretty straight forward minus tapping the proper switched 12v source.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 06-25-2021, 09:07 AM   #151
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Parts list, pictures and step-by-step it is. I'll write up a how-to in the "DIY Guides" section, post it there and if anyone wants to make an accompanying video, they can add it in that thread. I'll post a link to it here in this thread when it's ready. I'm not expecting all of the parts to arrive until this coming Monday, so it will be some time next week.
86-75309 (06-25-2021), Wally86 (06-25-2021)
Old 07-01-2021, 06:15 PM   #152
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
The inexpensive version of the DIY has just been completed in that section as the second post. Here is a link to that thread:
https://www.ft86club.com/forums/show...13#post3446013
Please note however, that I am also working on the tutorial on how to build the plug-and-play harness, which is what you see in the picture for that first post. Stay tuned.....
oddrelic (07-03-2021)
Old 07-03-2021, 10:18 AM   #153
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Thanks to everyone involved in those tests ! I've switched my amp feed to the antenna since like I mentioned, on some occasion the acc drop was a bit faster than the radio tuning off and i could hear a quick shot of non amplified audio when turning my key off.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
The Following User Says Thank You to trueno86power For This Useful Post:
FR-S2GT86 (07-03-2021)
Old 07-03-2021, 12:40 PM   #154
Greg_2086
Drives: 2020 86
I preface this with I have not taken apart my dash yet, but stumbled across while digging into whether the front dash and door speakers are wired in parallel or series and how the rear amp jumper might impact impedance versus using the amp.
If this unused connector still exists in the 2020's, it might minimize the adapter harness FR-S2GT86 is making for the no-cut factory wire/adapter harness solution since the antenna adapters would no longer be needed.
Possibly D29 Option Connector in the wiring image below?
Given that the antenna turn-on and amp turn-on are energized when the vehicle is in ACC or ON and whether the head unit is manually on or off versus being controlled by the head unit (referring to FR-S2GT86's post #140) this might be another source to tap the amp turn-on into instead of the antenna turn-on.
Maybe oddrelic or FR-S2GT86 could test the functionality of this?
Build Thread
audio, head unit double din, mp3, stereo, usb port
2020 86 TRD info? Vr4gasmtt Scion FR-S / Toyota 86 GT86 General Forum 18 08-27-2019 02:41 PM
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 02:53 AM
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 06:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 06:43 PM
