#78849 | |
Be Kind
Drives: 2020 86
Tires are made of rubber! So are condoms though
| The Following 3 Users Say Thank You to Wally86 For This Useful Post: |
#78850 |
Fender liner melting with some headers or turbos has been mentioned before. I don't remember what you have done to your car.
#78851 | |
Drives: 2018 Subaru BRZ
I have ceramic coated headers. Maybe the overpipe gets hot. Another thing it could be the accessory belt touching the inlet tube. The smell goes away quick after WOT.
#78852 | |
Drives: Crapcan
Could have been debris or a timing cover leak on to the header. Sent from my iPhone using Tapatalk
#78853 |
Well the belt touching the tube should be a real easy visual.
#78854 | |
Man, I was just reading the seal replacement for that, have to pull the whole engine. Does this usually happen when in WOT?
#78856 |
I'll inspect it today after work, I was on my way to work running a bit late. Is a little weird since this is a fairly new car, less than 26K miles.
#78857 | |
Drives: Crapcan
Sustained acceleration probably got the exhaust hotter then normal. Just my guess. Yes to reseal the timing cover, engine has to come out. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Wally86 (06-22-2021) |
#78858 | |
It did remind me of the smell I sensed when I first fired up the engine after installing the headers. I don't usually drive on WOT, so it probably never really settled.
#78859 |
The Dictater
Drives: '13 Red Scion FRS
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (06-23-2021), Wally86 (06-22-2021) |
#78860 |
Famous Potatoes
Drives: '15 ultramarine
Talk about things melting, we are expecting 9 days in a row over 100°F. Way hotter than average. Ouch!
#78861 |
Well there is the SSD drive. HDD drive, SATA drive.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | soundman98 (06-23-2021), Ultramaroon (06-22-2021) |
#78862 | |
Dry heat or Satan's asshole (Fort Polk, LA) type of heat that has 98% humidity.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
