Old 06-19-2021, 01:58 PM   #1
Maheralfa
Drives: 2020 Toyota gt86 black
Need help with aftermarket wheels
I'm looking into aftermarket rims and I'm having a hard time choosing. I was wondering if I have to change my stock suspensions before adding a new set of rims. What I want is 18x8.5 for both front and rear. I just don't know how wheel offset works. I don't want to run to any trouble when upgrading my break kit too because that something I would want to do down the line. I use the car as a daily so I want something reliable I would also like to avoid rubbing and scrubbing. If you guys have any good advice about this and what offset should I be looking at. Cheers
Maheralfa is offline   Reply With Quote
The Following User Says Thank You to Maheralfa For This Useful Post:
humfrz (06-20-2021)
Old 06-19-2021, 03:29 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
that depends a lot on the size of the tires, as well as the offset of the wheels.
Old 06-19-2021, 04:01 PM   #3
saltywetman
Drives: 2020 Toyota 86 GT 6M
i think you should be safe with 18x8.5 wheels as appropriately sized tires for that width wheel shouldn't have any rubbing issues on stock suspension. It's when you go with 9.0-9.5 and wider tires that you will have to make camber adjustments
saltywetman is offline   Reply With Quote
Old 06-19-2021, 04:19 PM   #4
whataboutbob
AutoX-10/10ths every run
Check the wheel fitment thread here: https://www.ft86club.com/forums/showthread.php?t=7535
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Spuds (06-20-2021)
Old 06-19-2021, 05:55 PM   #5
Maheralfa
Yeah I'm looking into having a flush set up. Does it mean I'll have to hey different offset for the rear? And different for the front?
Old 06-20-2021, 12:22 AM   #6
whataboutbob
You can probably use up to 3mm wheel spacers with stock wheel studs safely.
Build thread:Here
Old 06-20-2021, 01:04 AM   #7
Welp, I suggest you leave your car's wheels and tires alone, to best achieve your objective.
Well, you did ask -
soundman98 (06-20-2021), x808drifter (06-20-2021)
Old 06-20-2021, 04:06 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
https://www.ft86club.com/forums/showthread.php?t=67345
Read #2
Read it again.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
Maheralfa (06-20-2021), Spuds (06-20-2021)
Old 06-20-2021, 10:42 AM   #9
Maheralfa
What would you suggest I start with? I’m new to the car modding scene. But I really wanna get that kind of wheel set up but I wanted to do it properly. If coilovers would help I would even start with that. But I have no idea where to begin
Old 06-20-2021, 11:08 AM   #10
soundman98
soundman98's Avatar
i start with narrowing down the type of style i prefer-- mesh or # of spokes, color, dish/flat face. figure out what wheels are even available in the style/finish you like, figure out which brands make a quality wheel in that style, and then work backwards to what sizes are available by that mfg, in your country, and in stock, or available for made-to-order or pre-order, and not some obscure site that says everything's in stock but will reject and refund any orders after placing the order for stuff that can't be ordered...
for example, rota's really good on their japanese site at saying they make every one of their wheel designs in any bolt pattern in any of a thousand sizes, and any of a thousand offsets, but you'll never find more than 5-10 of any styles in a specific size in only a few offsets that are actually available to order from american distributors.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Old 06-21-2021, 12:11 AM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So first question is why are you changing the wheels? Is it just a style thing? Are you looking to improve performance? What are your priorities, in order? Just to give folks an idea of what tradeoffs you are willing to accept.
For pure fitment questions, I recommend the wheel and tire fitment thread linked above. Great resource showing what should work and what needs further modifications.
Also, Tire Rack has a good research section that explains the various measures and things to look for in buying aftermarket wheels.
Maheralfa (06-21-2021), soundman98 (06-21-2021)
Aftermarket lugs on STI wheels spicyricecake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-20-2015 03:44 AM
WTB: aftermarket wheels in texas Astroboy Want-To-Buy Requests 3 07-03-2015 11:22 AM
What color are your aftermarket wheels? NWFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-11-2015 01:45 PM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 08:19 AM
