, dpfarr
Old 06-15-2021, 10:26 PM   #4145
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Do I need to let the SC cool down when I park before shutting the engine off after a mild drive? I’ve been letting it chill in neutral for 30-60 seconds. There was something about hot oil needing to be circulated out?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 06-16-2021, 11:19 AM   #4146
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I believe you're confusing S/C shutdown with Turbo cooldown.
I had at turbo timer on the Talon I once owned. It kept the engine running for a pre-set time after the key was turned off. This kept the oil circulating through the hot turbo.
An Edelbrock doesn't have circulating oil but rather an oil bath, for lack of a better term.
Muskoka800 is online now   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
BrahmaBull1990 (06-16-2021)
Old 06-16-2021, 04:51 PM   #4147
Hurricane Nate
Drives: 2020 BRZ (Black)
Originally Posted by B T View Post
I had that occur one time. Change the tensioner. After I did that it never happened again.
Did you change the entire tensioner or just the pulley?
I finally got back from vacation, so I had some time to take a look. It looks like the serpentine belt was getting some funny wear on the side closest to the engine on the outside of the belt (where it goes over idler pulleys). It’s very subtle but it is there. It doesn’t look like any of my drive pulleys are misaligned, but the idler pulley between the A/C and the S/C has what looks like a bit of funny wear that the other idlers don’t have. It doesn’t look significant to me, but it is different from the other pulleys.
Now that the new serpentine belt is on, I’m going to let it run, and see if the problem appears again. I just can’t find anything obviously wrong.
Hurricane Nate is offline   Reply With Quote
Old 06-17-2021, 01:06 PM   #4148
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
It was the entire tensioner assembly.
B T is offline   Reply With Quote
The Following 2 Users Say Thank You to B T For This Useful Post:
Hurricane Nate (06-29-2021), SOCON (06-03-2023)
Old 06-23-2021, 03:15 PM   #4149
Decep
Drives: 2013 FR-S Series 10
Anyone have a link to the air filter for this setup? Been almost 25k miles probably time to change. I remember reading it’s a dry filter.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 06-23-2021, 05:53 PM   #4150
Muskoka800
You should find one at Edelbrock.com.
The earlier kits used an oiled K&N filter however I understand they have since switched newer kits to a fool-proof dry type.
Old 06-24-2021, 06:08 PM   #4151
FrickingReallySlow
Drives: 2015 FR-S
Can the dry type just be cleaned and re-used or have to be replaced?
FrickingReallySlow is offline   Reply With Quote
Old 06-25-2021, 09:35 AM   #4152
Pgh_Area
Pgh_Area's Avatar
Drives: '14 Ultramarine Fr-S
Being a K&N, follow their recommendations.
Edelbrock P/N: 51-0157.
K&N SP-3737
Pgh_Area is offline   Reply With Quote
Old 06-25-2021, 05:44 PM   #4153
Decep
Thank you for the edelbrock part number. Couldn't find it on edelbrock's website nor on the packing list of the instructions.
With that K&N part number i can't find anything though.
RCE SS-1 Coilovers
Corsa Catback
Old 06-26-2021, 01:37 AM   #4154
Pgh_Area
Pgh_Area's Avatar
Jegs has it: https://www.jegs.com/webapp/wcs/stor...0002&langId=-1
Old 06-26-2021, 11:12 AM   #4155
Glitch
Drives: 2019 86 TRD SE
installed Works oil cooler kit with Edelbrock SC
Installed the Works sourced oil cooler kit.
So far I am pleased with the results. I know its not going to allow for un ending track abuse, but for what I do it seemed the most practical.
(spirited driving)
The hose length and connectors all worked out, though I required a bit of finesse and a zip tie to get the tubing in a safe position I felt would ensure they did not rub the belts or other metal parts.
Improvement in oil cooling fit the advertisement of 10-13 degrees.
During spirited driving I would see the oil temps around 250f and now I they stay around 230f and drop very quickly after resuming normal driving conditions.
Running AMS Signature Series 0W-20 Synthetic, so I believe this should be an acceptable temp or am I wrong?
Glitch is offline   Reply With Quote
The Following User Says Thank You to Glitch For This Useful Post:
BrahmaBull1990 (06-26-2021)
Old 06-29-2021, 07:40 PM   #4156
Hurricane Nate
Originally Posted by Glitch View Post
I like the custom bracket (red) you have for the Injector controller mounting.
I'm thinking of getting a similar bracket made. Do you have any design dimensions or files you can share?
Sorry about straying from the topic of your post.
Old 06-29-2021, 10:22 PM   #4157
Z06ZN6
Drives: 2017 Toyota 86
(spirited driving)
I see a paper towel stuck between the abs unit brake lines...
Z06ZN6 is offline   Reply With Quote
The Following User Says Thank You to Z06ZN6 For This Useful Post:
BrahmaBull1990 (07-01-2021)
Old 06-30-2021, 09:44 AM   #4158
Glitch
The bracket is by Verus and I picked it up from FTSpeed.com.
https://www.ftspeed.com/part/23a-par...r#.YNxlh-hKhhE
Indeed there is, I always keep a paper towel in the engine bay for checking fluids and the sort. Perhaps I should replace it with a yellow napkin for an extra 5hp.
The Following 3 Users Say Thank You to Glitch For This Useful Post:
B T (07-01-2021), BrahmaBull1990 (07-01-2021), Hurricane Nate (07-01-2021)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
