Old 04-27-2021, 10:30 AM   #127
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by 86league View Post
Updated the original post with the link to thingiverse where the .stl files are hosted.
Thingverse can't seem to find:
https://www.thingiverse.com/thing:4840911
Is the number correct or has the project been removed?
Thanks!
LimitedSlip is offline   Reply With Quote
Old 04-27-2021, 01:40 PM   #128
nwgabrz
Drives: BRZ Limited
I've always been interested in Innovated Dynamics's FR-S brake ducts and but since I own a BRZ, I've never purchased them. But with contemplation of swapping to a FR-S front bumper, I've thought about those ducts again. Unfortunately Innovated Dynamics has now shut down. Of course, there are other brake duct kits on the market such as the one made by APR, and others, but in terms of design, I liked the Innovated Dynamics version.
Another one that I like, but has never been brought to production, are the ML24 brake ducts.
What I'm thinking is that maybe we can 3D scan or laser scan an FR-S fog light bezel piece so that we can have the edge shape as a 3D model along with the snap on edges.
Then we can bring it into SolidWorks or an equivalent program and remodel the interior part so that it has a nice concaving duct, similar to the ML24 one.
Afterward, we 3D print a mold for the piece and then cast our trim piece using that mold, and sand it afterward.
I would then skin it in carbon fiber using resin, carbon fiber fabric, and clear coat, and wet sand it.
How difficult would the process of scanning, and then manipulating the model, and then either 3D-printing the piece or 3D-printing a mold for the piece be? I reckon we can do one and then mirror the object for the other side.
nwgabrz is offline   Reply With Quote
Old 04-27-2021, 07:13 PM   #129
86league
Drives: '13 BRZ Limited
Thanks!
I had just joined thingiverse to upload this. It showed up for me with that link, but it also tells me I need to wait 24 hrs to publish as a new member.
I went back and published it. Let me know if it doesn't work now - sorry for the hassle.
86league is offline   Reply With Quote
Old 04-27-2021, 07:26 PM   #130
I can see them.
Old 04-27-2021, 08:15 PM   #131
LimitedSlip
Good to go now. Thanks much!
Old 05-21-2021, 08:13 PM   #132
Jchang
Drives: 2018 Subaru BRZ Ts
Has anyone made an .stl file for exhaust covers before? I feel like someone would’ve made one in the past by now.
Jchang is offline   Reply With Quote
Old 05-24-2021, 09:27 AM   #133
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
What do you mean by exhaust covers? Most of the people in here are ringing and designing for plastic based printers, which I’m doubting would hold up against anything exhaust related
ybotspawn is offline   Reply With Quote
Old 05-24-2021, 09:33 AM   #134
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Block off plates for those that go single exit exhaust.
Old 05-24-2021, 09:34 AM   #135
ybotspawn
ybotspawn's Avatar
Ahhh point taken
Old 06-02-2021, 02:37 AM   #136
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Got a Deka ETX15L battery to shed some weight vs. the OEM (11.8lbs vs 34lbs) but it's not a drop in replacement.
I ended up 3D printing a tray that holds the Deka and is same width as the stock tray front to back. This "adapter" raises the Deka enough to let you use the stock tie-down parts. Also made a little block to go under the tie down bar to spread out the load on the top of the battery. Seems to work well.
Printed in ABS. I'd previously done something very similar with a Braille 14115 and it held up well. The ETX15L was a lot cheaper than the Braille and works a little better in terms of height IMO.
Would you mind sharing the file?
Old 06-02-2021, 10:52 AM   #137
86league
Updated original post with the thingiverse link.
Old 06-15-2021, 09:56 AM   #138
For those of you that are way more of a 3D print expert than I am, can you use a 3D pen (which is basically just a hot glue gun sized for filament) to "weld" 3d printed pieces together?
It seems like it should work either on its own or as a "spot welder" to hold pieces together while glue dries but I was curious to see if anyone has experience doing it.
Old 06-15-2021, 04:41 PM   #139
RayRay88
Drives: 2017 86 860 Special Edition
It won't hold very well. If you're serious about "spot welding" either use epoxy or my favourite, friction welding. Put some filament in a dremel and put it on high speed. The friction and resulting heat will melt the filament on both pieces and essentially weld the pieces together.
I would practice on dud prints before you attempt something precious.
RayRay88 is offline   Reply With Quote
Old 06-15-2021, 07:14 PM   #140
I've seen the friction welding done, but it seems risky if its for relatively small pieces.
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
