| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#19111 |
Persona Non Grata
Drives: '15 BRZ (WRB)
That sucks mousse. Same thing happened to us on a long road trip 1000 miles from home, only the damage was much worse. Glad to see you have a plan.
Slow is smooth, and smooth is fast
#19112 |
Drives: Crapcan
This was last night.
Rewired flex fuel kit from rear 02 reference to evap reference using Openflash Performance's instructions (which are real cute BTW). Installed Nameless "Ultra Quiet" track pipe. Surprisingly it is not that bad and is quieter then the 3" Perrin CB I had a while ago. Way too loud for DD driving but for the occasional weekend drive and track days it is okay. Today is repacking my spare CV axles with Redline CV2 grease to go into the car this weekend.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | BrahmaBull1990 (05-28-2021), norcalpb (05-28-2021) |
#19113 |
Howdy
Drives: 2020 BRZ PP
Sorry to hear. Luckily it doesn't look too bad!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#19114 |
Howdy
Drives: 2020 BRZ PP
Just got the Berz back with the Edelbrock installed! I love it! I'm not used to fast cars, so I will need to adjust my driving for a bit. It's putting down 246WHP, which is perfect. This feels like the most power I will ever need for this platform and it feels conservative, as far as FI goes.
| The Following 6 Users Say Thank You to BrahmaBull1990 For This Useful Post: | juenedgi (05-29-2021), NoHaveMSG (05-29-2021), Stonehorsw (05-28-2021), therealstoly (05-28-2021), Wally86 (06-02-2021), wolffbite (05-28-2021) |
#19115 |
30 minute maintenance
Drives: My18 wrxsti
^ ^ ^ Looks like 6,000rpm will be a good shift point if you track it. Right in the meat without revving the shit out of it.
| The Following User Says Thank You to gen3v8 For This Useful Post: | BrahmaBull1990 (05-28-2021) |
#19116 |
Howdy
Drives: 2020 BRZ PP
Brilliant - my thoughts also.
| The Following User Says Thank You to BrahmaBull1990 For This Useful Post: | gen3v8 (05-28-2021) |
#19117 |
Drives: SWP BRZ
i have take a look into it after getting police report.
i dont think i have internal damage but i will have to take bumper off to find out but not touching anything until adjust to show up later i just thank that i didnt buy supercharger and installed yet if accident happened after supercharger installed, OMFG! |
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | BrahmaBull1990 (05-28-2021) |
#19118 | |
ProCrastinationConsultant
the hood lines still look straight, meaning the sub structure should be straight, and the headlight doesn't even look cracked. so a front bumper, maybe a front core support. out of all the accident damage you could've had, this is insignificant.
#19119 |
Got under the car today and finally figured out my steering noise.
Turns out 6 years after installing my Perrin steering lockdowns, the steering rack mounting bolts became loose by a 1/4 turn. This was causing the lockdowns to rattle on the rack and steering feel like crap. Tightened those to 65ft/lbs and all feels great again! |
| The Following 5 Users Say Thank You to norcalpb For This Useful Post: | BrahmaBull1990 (05-30-2021), DarkSunrise (05-30-2021), NoHaveMSG (05-31-2021), Stonehorsw (05-30-2021), Wally86 (06-02-2021) |
#19120 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
E85
First e85 tank.
Checking the AFR (initially I freaked out with the values that seemed unusual, but posts on forum about OFT have helped me understand better( Last edited by Stonehorsw; 05-31-2021 at 09:39 PM. Reason: Grammar corrections |
| The Following 2 Users Say Thank You to Stonehorsw For This Useful Post: | BrahmaBull1990 (05-31-2021), NoHaveMSG (05-31-2021) |
#19121 |
Drives: Crapcan
Remounted my splitter and added some additional bracing. Put in a new stock driveshaft. Built a new mount for my oil cooler that goes to the crash beam instead of mounting the lower tray. It sits too low though and actually almost touches the lower tray, so I am worried a hit from underneath will break it. May have to rethink this in the future, kind of annoyed with it right now.
Was going to replace all 4 hubs and swap out my CV's, but I also wanted to rebuild my front calipers and swap out my rears for a new set but I forgot my brake bleeder. I don't want to tear the car apart that far twice so decided to hold off on that for now.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#19122 |
Howdy
Drives: 2020 BRZ PP
Took my BRZ back to the mechanic after my Edelbrock install. There was a small oil leak that turned out just to be the drain plug gasket WHEW
#19123 | |
Drives: RX-7 / BRZ
Next time you get a chance check out 'Professional Awesome Racing's' front mount splitter quick latch system. Makes that process much faster given you can clip on and off to test-fit in seconds.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | NoHaveMSG (06-04-2021) |
#19124 |
Drives: 2017 BRZ series.yellow
Autocross prep for this weekend.
Means taking the skinnys off and putting the meatys on. Wish I could always run the big tires, car looks a bit lame with all the camber on factory wheels. |
| The Following 6 Users Say Thank You to Breezio For This Useful Post: | BrahmaBull1990 (06-05-2021), Busybee (06-07-2021), JD001 (06-05-2021), Stonehorsw (06-05-2021), Wally86 (06-07-2021), weederr33 (06-05-2021) |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 08:53 AM |
