Old 05-26-2021, 04:18 PM   #1
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Clutch fork grease
Looking to install a new verus clutch fork Pivot ball an TOB. What's the best recommended grease/lube to use.
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 05-26-2021, 07:07 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
https://www.amazon.com/dp/B000KXLR5E...ing=UTF8&psc=1
Sent from my SM-G998U using Tapatalk
Joveen is offline   Reply With Quote
Old 05-27-2021, 12:35 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
For the application and location, Moly Fortified EP Grease, NGLI GC-LB Grade.
Don't use this same grease on the TOB or splines, however.
EndlessAzure is offline   Reply With Quote
Old 05-28-2021, 09:20 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I wonder: Do we really want grease on the input shaft housing? From what I've seen the grease is a magnet for the dust from the clutch disc. After a few k miles it's no longer a lubricant just a gritty mess that, in the long run, causes more wear on the housing.
Old 05-28-2021, 09:21 AM   #5
BlOody_BoOger
I think you just put a very small amount to help the input shaft slide in when your putting it back in
Old 05-28-2021, 07:02 PM   #6
jflogerzi
jflogerzi's Avatar
Thats what she said
2013 Series 10 FRS #553
SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB zc06_kisstherain Transmission and Driveline 3 10-17-2018 10:31 PM
[SOLD!] FS: NEW Diftech Heavy Duty Clutch Fork + Versus Clutch Fork Pivot reeves Transmission and Driveline 2 08-25-2018 12:18 AM
Clutch Fork Failure - i.e. New Clutch and Tranny BuzzR Engine, Exhaust, Transmission 11 06-22-2018 02:53 AM
Clutch Squeaks at the end of travel... clutch fork? treminaor Issues | Warranty | Recalls / TSB 54 12-02-2016 03:53 AM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
