Old 05-20-2021, 08:14 PM   #365
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I was also thinking just the other day that they should use wind energy to make electricity through ions or static electricity like lightening.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
Capt Spaulding (05-21-2021), Spuds (05-21-2021), Ultramaroon (05-28-2021)
Old 05-21-2021, 06:05 PM   #366
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
The video is really interesting - for me the high spot is the "powerpod." if the tech scales it could offer an opportunity for home owners to bypass solar and get close to going off grid with wind alone.
I can't wait.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Dadhawk (05-21-2021), Irace86.2.0 (05-22-2021)
Old 05-22-2021, 12:22 AM   #367
Irace86.2.0
I can't wait.
Santa Rosa is 30 minutes from the coast. We typically get pretty decent winds for being in the valley, especially at night. A miniature dildo on the roof or turbine would be cool. Solar would probably be cheap enough in the future to have that too.
Old 05-22-2021, 02:09 AM   #368
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
In this context (and only this context) what is a dildo?
Spuds (05-22-2021)
Old 05-22-2021, 02:41 AM   #369
Irace86.2.0
It is the weird, phallic-shaped, vibrating rod that generates energy from wind harmonics.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Captain Snooze (05-22-2021)
Old 05-22-2021, 11:38 AM   #370
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Probably the only wind power generator I wouldn't consider for visual reasons unless literally everyone around me had one. I don't have a great house for wind anyway, but that's a different problem.
The Following User Says Thank You to Spuds For This Useful Post:
Old 05-22-2021, 02:06 PM   #371
Irace86.2.0
I wouldn’t be surprised if teens spray painted a dildo tip and veins on those things if they were on people’s roofs.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Capt Spaulding (05-24-2021), Spuds (05-22-2021)
Old 05-24-2021, 12:20 PM   #372
Capt Spaulding
Persona Non Grata
The mental image of that will be with me for a while. The big question is can you get one with rabbit ears?
Old 06-10-2021, 01:41 AM   #373
Irace86.2.0
Old 06-16-2021, 11:05 AM   #374
Irace86.2.0
https://arstechnica.com/science/2021...cean-trenches/
Mercury is accumulating in deep-ocean trenches
Key quotes:
This latest report is the first to measure mercury-accumulation rates in sediment cores from some of the deepest parts of the ocean—the hadal zones (>6 km depth). While the deep ocean is considered one of the most important, and relatively safest, places for mercury to end up, the rates of accumulation were up to 56 times greater than prior estimates. The highest measured concentrations were also nearly as high as some of the most contaminated bodies of water on the planet—a jarring finding given that these locations (the Atacama and Kermadec trenches) aren't in the vicinity of any known mercury sources.
Natural sources of mercury, such as volcanic eruptions and rock weathering, have always existed. But according to the latest estimates for the UN Environment Programme, human activities have caused a 450 percent increase in atmospheric mercury compared to natural levels. While the biggest mercury spikes occurred largely due to gold and silver mining between 1520 and 1920, global emissions are still on the rise.
Fossil fuels account for about one-quarter of this increase, but lately the leading contributor has again been artisanal and small-scale gold mining. This kind of extraction has released roughly 1,220 tons of mercury in 2015 alone (nearly 40 percent of that year's global total).
These sediment cores give the first direct evidence of how deep-ocean mercury concentrations have been changing over the last 60-190 years (i.e., the flux). The results show rates between 6 and 56 times greater than what researchers had inferred from measurements in other parts of the ocean. The concentrations were also the highest recorded at any site that was not in the area of a known source, such as an underwater volcano or industrial contamination.
"The concentrations we found—particularly the maximum concentrations in the Atacama trench off Chile—are almost as high as you would see in the Mediterranean Sea or the St. Lawrence Gulf in Canada, which are areas that are actually contaminated long-term by industrial releases of mercury," says Outridge. "To find those sorts of concentrations in a remote part of the ocean—that was a surprise—and the accumulation rates were at least an order of magnitude higher than the averages that have been calculated in the past from water column measurements."
"I think that we would expect concentrations to increase in the sediment as you go from coastal areas into the deep ocean," says Outridge. "If you take lakes as an analogy, if you go from the edge of the lake out to the deepest part of the lake, then the concentration does increase, of mercury and other elements. I think what's going on here is that we're seeing a particle filtering effect, where the finest sediment makes it to the deepest part of the ocean and the coarsest sediment settles out in the coastal areas."
With relatively little life down there and low chances of the mercury moving out before it's buried by plate tectonics, we should be somewhat reassured that mercury might be concentrating in these trenches. But the potential damage en route is still significant, and it's in everyone's interest to keep working to minimize mercury use as much as possible.
Spuds (06-17-2021)
Old 06-16-2021, 11:48 PM   #375
Captain Snooze
Drives: Red Herring
"The tipping point for irreversible global warming may have already been triggered, the scientist who led the biggest-ever expedition to the Arctic has warned.
"The disappearance of summer sea ice in the Arctic is one of the first landmines in this minefield, one of the tipping points that we set off first when we push warming too far," said Professor Markus Rex.
"And one can essentially ask if we haven't already stepped on this mine and already set off the beginning of the explosion." "
German research vessel to return from 'dying Arctic'
Peatlands worldwide are drying out, threatening to release 860 million tonnes of carbon dioxide every year
Specifically, our new research in Nature Climate Change found drying peatlands could release an additional 860 million tonnes of carbon dioxide into the atmosphere every year, by around 2100. To put this into perspective, Australia emitted 539 million tonnes in 2019.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Irace86.2.0 (06-17-2021), Spuds (06-17-2021)
Old 06-17-2021, 05:19 AM   #376
Captain Snooze
Drives: Red Herring
Thank you, it's been a pleasure.
I mean if there is anybody about in a hundred years time they will probably look upon these times as a myth.
"Yeah, they used to fly through the air in a tube to go places."
"Nah, that's not possible."
Old 06-17-2021, 07:33 AM   #377
Captain Snooze
Drives: Red Herring
Fermi paradox
The Fermi paradox, named after Italian-American physicist Enrico Fermi, is the apparent contradiction between the lack of evidence for extraterrestrial civilizations and various high estimates for their probability.
It is the nature of intelligent life to destroy itself
This is the argument that technological civilizations may usually or invariably destroy themselves before or shortly after developing radio or spaceflight technology. The astrophysicist Sebastian von Hoerner stated that the progress of science and technology on Earth was driven by two factors—the struggle for domination and the desire for an easy life. The former potentially leads to complete destruction, while the latter may lead to biological or mental degeneration. Possible means of annihilation via major global issues, where global interconnectedness actually makes humanity more vulnerable than resilient, are many, including war, accidental environmental contamination or damage, the development of biotechnology, synthetic life like mirror life, resource depletion, climate change, or poorly-designed artificial intelligence. This general theme is explored both in fiction and in scientific hypothesizing.
From Wiki
Note Well:
There are many hypotheses listed on the Wiki page but this is the one that is relevant to this thread.
Old 06-17-2021, 10:03 AM   #378
Irace86.2.0
There are ways of living sustainably. Living sustainably requires an acceptance of limitations, and that is the hardest part. We are driven through our biology to overreach and not see past our our nose. It’s the fault of our selfish genes, to take a phrase from Richard Dawkins.
youguysneedlives
Planet Earth: The Car Enthusiast sniffpetrol Other Vehicles & General Automotive Discussions 1 02-03-2018 10:54 PM
Planet Eclipse Geo2 Gt86_nick Miscellaneous 0 11-01-2014 10:53 PM
Planet Audio 2250D amplifier Noob4Life Audio/Visual, Electronics, Infotainment, NAV 1 09-16-2013 07:33 AM
Like saving the planet? read this carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 7 02-14-2013 06:09 PM
