Old 05-06-2021, 08:35 PM   #5657
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Port injectors yes, fuel pump, not with the stock pulley.
DI injectors should still be cleaned by a professional injector service.
Awesome. Thanks a ton. Will PM sometime next week to put in the order.
Sent from my Pixel 3 using Tapatalk
dynarun55 is offline   Reply With Quote
Old 05-12-2021, 08:35 PM   #5658
jacobe38
jacobe38's Avatar
Drives: frs
Hello all, hoping to get a bit of feedback on my new c30. installed today, and I wanted to verify this idle noise is normal. i move around a bit because its weirdly angle dependent on how clear you can hear the whine. as such i figure its coming from within the rotrex and what you hear is the sound echoing out through the tube and air filter.
what im trying to pick out is that high pitch whine. unsure if mechanical whine, or just the sound of air whistling, normal or not, etc. kind of hard to hear from inside, did not seem to get louder when i revved a bit.
just wanted to verify this is normal sounding for a c30 at idle. fluid reservoir is full
thanks for listening to me whine heh
jacobe38 is offline   Reply With Quote
Old 05-13-2021, 01:57 PM   #5659
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Sounds normal to me ....
mswbrz is offline   Reply With Quote
Old 05-14-2021, 01:27 AM   #5660
jacobe38
jacobe38's Avatar
Drives: frs
thank you for responding!
Old 05-15-2021, 01:18 PM   #5661
Swolzee
Swolzee's Avatar
Drives: Honda Insight
I have a couple of questions:
1) Who all is running meth, and what are your current logs looking like? (before you even say "just run E85" know that I'm 50mi from the closest E85 pump so it's not an option)
2) Who is using a Full Blown fan/shroud kit with the FB or Koyo rad? Do you track it and how do the temps look?
3) Knowing I'm not going to be running E85 what would 700cc injectors using 93oct and meth be rated up to max?
Everything you know about *EJ* boxers doesn't apply to an FA.
I'm old to EJ's, new to FA's so I do look at this from a perspective of "where's the 1:1 tq/hp I'm accustomed to?". Displacement plays a huge roll but even in my EJ22T prior to going 2.4L it was still roughly 1:1. Time to untrain the brain.
I'll have plenty more questions don't doubt. But real quick, after reading though 200+ pages on this thread I would like to give a shoutout to CSG Mike. I might be new to the forum but it's clear to see what a valuable asset this dude is to the community here giving out tons of free information that he no doubt has a lot of time and money invested in gathering said info.
Not trying to overstep here, but I encourage anyone who is looking to get a kit, a replacement belt, whatever to consider someone like this first even if the cost is a bit more. Just remember this is what keeps this information flowing, I assure you Amazon isn't about to get on here and answer your questions! I'll get off the soap box now, and I will certainly be placing my own orders soon.
Swolzee is offline   Reply With Quote
Old 05-15-2021, 01:35 PM   #5662
ML
ML's Avatar
Drives: 13 White MT FR-S
I track it with a koyo rad and no shroud with a 12 inch fan. best compromise of reducing drag at higher speeds to still having some cooling during red flags/pits IMO
Old 05-18-2021, 09:08 AM   #5663
Swolzee
Swolzee's Avatar
Did you try using a shroud prior and realized it caused too much drag?
Old 05-18-2021, 09:17 AM   #5664
ML
ML's Avatar
https://racelouvers.com/content/Race...unnel-Data.pdf
Old 05-19-2021, 07:17 PM   #5665
ML
ML's Avatar
Blew up the rotrex for the 2nd time after a year and a half. At the track, main shaft seized and the pulley sheared and snapped the belt. Will get pics later
Old 05-20-2021, 07:39 AM   #5666
ML
ML's Avatar
Old 05-20-2021, 08:39 AM   #5667
dynarun55
dynarun55's Avatar
Was it C30 or C38 ?
Old 05-20-2021, 09:10 AM   #5668
ML
ML's Avatar
Originally Posted by dynarun55 View Post
Was it C30 or C38 ?
c38. Unit did something similar last year driving on the street, (less dramatic failure) and I had it rebuild by superchargerrebuilds.com due to being out of warranty and that was almost a year ago.
Old 05-20-2021, 07:53 PM   #5669
AndreC
Drives: Fast track beast
How was their rebuild? I purchased a new Rotrex but might look at getting the old one rebuilt in the meantime.
Sent from my SM-G973W using Tapatalk
AndreC is offline   Reply With Quote
Old 05-20-2021, 08:44 PM   #5670
ML
ML's Avatar
It was like $600 and took 2 months I think. It worked...for awhile, not sure if I can blame this one them. Looks like the bearing failed
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
