#85 |
Drives: Toyota 86
Yep! Soon.
Added some new photos on our website: https://denstoj.com.au/products/fa20...r-retainer-kit Thanks for your patience. |
#86 |
Drives: 2016 scion frs
I was watching a teardown video of the new supra engine (B58), they have these from stock. Interesting stuff. BMW thought of it. If only Subaru or Toyota thought of it. Good thing @Denstoj did.
At 7:58 is where theyre shown on the video. |
| The Following User Says Thank You to jrhudson For This Useful Post: | NoHaveMSG (05-13-2021) |
#87 | |
Drives: Toyota 86
Glad we can help you all have peace of mind with your engines. |
#88 |
ProCrastinationConsultant
i suspect that's very much the difference between a $30k car and a $60k car
#89 |
#90 | |
Drives: Crapcan
Here is a thread were someone made their own retainers and he lists part numbers and engines that had them. https://www.ft86club.com/forums/showthread.php?t=145329 I will be buying the kit from Denstoj though. That will hopefully squash one beef I have with the FA engine.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (05-16-2021) |
#91 | |
Drives: 2103 Subaru BRZ
#92 | |
Drives: Toyota 86
Machining the original pivots can be done (as we have been), but both the hardness and ensuring the groove dimensions are correct consistently make it more difficult. We had a custom jig manufactured to do this at our specialised machine shop. We've always wanted to make a completely custom solution at is the best option. Now due to demand, we're able to make the investment. Thank you again for your patience. |
| The Following User Says Thank You to Denstoj For This Useful Post: | rixter145 (05-21-2021) |
#93 |
So oil squirts into the socket of the rocker pivot at rest. This takes up the lash until the lobe comes around to begin lifting. Then the oil film is squeezed down through the center of the pivot and circulates back around the clearance between the pivot pin and its bore.
This seems to be an interesting shock absorption system. I've heard that the FA20 likes to be adjusted to the looser side. I wonder if rocker ejection is a symptom of a tad too much lash.
#94 |
Sleep Chomper
Hi all,
Giving a write up on the recent rocker retainer clip breaking. Two months ago, I found out that my exhaust cams were not moving while the car was warmed up. After some head scratching, we pulled the sensor out and low and behold, we found this sheared out retainer kit. ![]() Alarmed, I immediately reached out to Denstoj auto and they were extremely quick to send me a kit of their bespoke drop-in replacements. We then started taking out the engine and started checking all the rockers to see if there were more cracked/sheared retainers. Well, I will let the other pictures speak for itself: ![]() ![]() ![]() As the mechanic who is working on installing the new bespoke pivot & retainers, he noted in the following documentation, which ones were cracked. ![]() Note that cyl #2 front and cyl#4 rear cams were actually out of tolerance spec, but only one of them cracked. Upon installing the new pivots, my mechanic ensured everything was properly shimmed and my engine was good to go again. Meanwhile, Denstoj has requested me to send back the cracked retainers for investigation and here is what they hypothesize: I suspect during installation the rocker retainer clip has been stretched as it’s been pulled on and off multiple times. The clip need to be very tight on the rocker. If left loose the lower part of the clip is in contact with the pivot shoulder and can be damaged throughout the range of operation. During normal operation if installed correctly the clip will not have any load or wear. It is only in the event of a rocker dislodgement that the clip “catches” the rocker. Check out my video on the installation of the clip to the rocker arm - FA20 Engine Installation of Rocker Retainer Kit - Clip Fitment: I have inspected all of the clips and only some have damage on the lower side and have been over stressed. I want to point out that the shop that installed my retainers the first time was not my current mechanic and it is possible that the installation was not done correctly. I also want to thank Denstoj for being super apologetic and accommodating in resolving this issue with high urgency. Such customer service is hard to come by nowadays and it is a breath of relief that they care about producing a product that works. |
| The Following 5 Users Say Thank You to rixter145 For This Useful Post: | blsfrs (08-11-2021), DarkPira7e (08-11-2021), Jdmjunkie (08-11-2021), NoHaveMSG (08-11-2021), soundman98 (08-11-2021) |
#95 |
Drives: 2013 frs base
I am curious to know how the clip got to the cam sensor and didn't stay in the valve cover or end up in the oil pan. I would think that oil pumped to the head would drain to the pan and the clip would go with the flow. How much oil makes its way to the timing cover?
#96 |
Drives: Crapcan
A lot of it. There is only a small head drain on the bottom of the heads. The rest drains out past the cam gears and into the timing cover.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (08-11-2021), Ultramaroon (08-12-2021) |
#97 | |
Sleep Chomper
| The Following User Says Thank You to rixter145 For This Useful Post: | blsfrs (08-13-2021) |
| Trans retainer cover | Jcas | Engine, Exhaust, Transmission | 0 | 04-29-2019 05:24 PM |
| WTB: spare wheel retainer screw | Pat | Want-To-Buy Requests | 4 | 04-06-2016 01:57 PM |
| Pop-Screw Retainer Size? | FR-S Matt | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-20-2013 11:48 AM |
| big black plastic retainer | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 66 | 02-11-2012 03:33 AM |
