Old 05-11-2021, 10:16 PM   #19083
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
Originally Posted by Capt Spaulding View Post
Since then, I've added a substantial amount of sound damping to the rear half of the car and a few 100 - 200 mile hops suggest it's made a difference, If the pandemic allows, we're going to take it up to Seattle, if not this summer, then next. Before that, I'll probably swap the stock struts for Bilstein B6s. They're rumored to take a bit more of the edge off bumps.
How did you add sound dampening? I appreciate that this car isn't meant as a plush highway cruiser and I don't want to turn it into one. But a little less road noise at 70+ mph would go a long way.
Thanks!
AnalogMan is offline   Reply With Quote
Old 05-11-2021, 11:22 PM   #19084
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
There's a "how-to" in the DIY section that I used as an inspiration. Basically, I used about 15-20 sq ft. of adhesive butyl sound deadening mat rolled onto the floor of the trunk spare time well, wheel arches, and the inside of the trunk lid. I used a product called Noico. There are a number of other Dynamat clones as well as the original on Amazon. Over that I used a layer of mass loaded vinyl and close cell foam under the trim panels on the sides of the trunk and under the carpet mat covering the trunk floor. It's all easy to find on Amazon.
edit: The guy who did the DIY pulled most of the interior apart along with the doors and insulated all of it. He may have even done the roof. It's always seemed to me most of the noise is coming from the rear wheels, suspension and differential so I focused on that. I'm pretty happy with it. I still have a fair amount of the Noico mat. One of these days I may pull out the rear seats and bring the deadening material up to the rear of the doors.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
AnalogMan (05-12-2021), Tcoat (05-12-2021)
Old 05-11-2021, 11:37 PM   #19085
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by AnalogMan View Post
How about anyone else? What's the longest ride you've taken your car on? And what's the longest ride for which it was honestly enjoyable?
i'm at 50k miles for a car i only drive occasionally on the weekends. in a similar time span, i put about 20k mi on my daily driver...
200-400 miles is no big deal with this car. 1200 starts to get a little tiring
Old 05-12-2021, 08:12 AM   #19086
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I drove mine a 3rd of the way up the east coast of Australia. I took 2 days and it was an effort.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
BrahmaBull1990 (05-12-2021), soundman98 (05-12-2021)
Old 05-12-2021, 09:28 AM   #19087
AnalogMan
AnalogMan's Avatar
Thank you! The process you described sounds like it should have a noticeable improvement in noise levels. But all the layers also seem like it could meaningfully reduce trunk space!
Old 05-12-2021, 10:44 AM   #19088
Because of the pandemic, I haven't driven my BRZ very much in the past year (the timing couldn't have been worse, I bought it November 2019).
So, hankering to break the self-imposed house arrest just a little, thanks to vaccinations we decided to take a little trip. Yesterday we drove the BRZ. 7 hours, for a little getaway on the Canadian border (since the Canucks won't let us in).
The first hour was exhilarating. Even just on the highway, it reminded me all over again why I bought and love this car. The second hour was almost as much pure fun.
After the third hour, it started to get a little... tiring. After 7 hours, the noise and jittery ride were a little... much (at least for this 60-something aging body).
I guess sometimes, there can be too much of a good thing. I think future drives will be limited to no more than 3 hours a day. The car is an absolute blast to drive. But it's not the best choice as a highway cruiser for long days.
For the first 4 years with the FRS (on lowering springs and TRD exhaust) I spent between 15 and 20 hours a week on the highway. Now I am down to about 6 or 7 with the 86.
Not once was I ever bothered by noise, jarring, seat comfort, etc.
I will add the disclaimer though that for many years I drove very loud military vehicles, straight piped big block V8s, old (50s) cars with all steel interiors or rotted out shit boxes with soup can holding the exhaust together or worn out and outright broken suspensions so the FRS and 86 are like whisper quite, riding on a cloud luxury machines in comparison.
Anybody that thinks these things are noisy or bouncy inside never spent to in a jacked up 67 Dart!
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
AnalogMan (05-12-2021), Capt Spaulding (05-12-2021), Dadhawk (05-12-2021), DriveDriftDogfight86 (05-17-2021), JD001 (05-16-2021), soundman98 (05-12-2021), ToySub1946 (05-13-2021), Willpower (05-28-2021)
Old 05-12-2021, 11:47 AM   #19089
Capt Spaulding
Persona Non Grata
I know, right? But the beauty of it is the materials are very thin and overwhelming majority of the volume they take up is in the voids behind the existing trim panels. I used an adhesive backed close cell foam product and attached it to the mass loaded vinyl. The resulting composite is 1/4 inch thick. It fits pretty easily behind the trim. The only measurable loss of trunk volume is the 1/4 inch MLV/CCF panel under the trunk carpet. The 1/4 inch, while measurable is, to me not noticeable.
It does add a bit of weight. I'd guess about 20 pounds in my case. I'm easily 30 pounds over weight - so maybe I'll use this as a reason to lose some weight. Or not.
edit: I didn't want to plug specific products so I didn't put any links (other than the name of the butyl mat) in the post. I you like, I'll be happy to give you those in a PM.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 05-12-2021, 11:59 AM   #19090
Yea, the FRS is the quietest car I've ever daily driven.
soundman98 (05-12-2021), Tcoat (05-12-2021)
Old 05-12-2021, 12:31 PM   #19091
Sasquachulator
Pavement Grey
Can anyone compare the loudness to a subcompact like a Yaris or compact like a Corolla?
The last time i test drove one of these i think iI was going 80-100km or something around there, and i didnt find it all that much louder than my other car (Honda fit?) at the time. When i get a chance i'll test drive the 2020 86 GT nearby and see for myself.
I never understood the sound complaints, interior quality complaints or the power complaints. IT was all on par with a compact car to me....
does that mean my expectations were too low, just right for this particular car, or i should have expected more because RACECAR!!!?
Old 05-12-2021, 04:11 PM   #19092
Capt Spaulding
Persona Non Grata
I have driven many noisier cars and many quieter cars. My "06 F150 STX is quieter and my '73 Mercury Capri was noisier. My wife's '12 Camry SE V6 is marginally quieter. My particular yardstick for interior noise is conversation. Can I maintain a normal conversation in a normal tone of voice at 75-80 mph? In the BRZ that proved a bit difficult. So tried a number of potential solutions ranging from aviation intercom systems to sound insulation. The insulation seems to fit the bill.
Cars like this are canvases. Many of us use them as a foundation for something we think is greater. My motorcycling career ended in the side of a Tahoe. When I bought the BRZ, I sold my wife on the idea by telling her it would be like a Honda Goldwing with doors and A/C. A decent road tripper with sporting pretensions. A budget GT car. And, so it is. For me, the noise isn't really a significant inconvenience. I would, however, like to carry on normal conversation and I find that over the course of 9 or so hours the noise is a bit fatiguing. It is, however, something I can mitigate. So I have. For my purposes, the car is better as as a result.
Old 05-15-2021, 11:53 AM   #19093
valette.aglm@gmail.com
Kurt90
Drives: GT86
Tire Valve Caps
I have just ordered same nice aluminium valve caps for my GT86 from this site
https://jdm-best.com/products/valve-caps-laser-blue-alu
Hopefully it goes well, what you guys think about the style of it?
valette.aglm@gmail.com is offline   Reply With Quote
Old 05-15-2021, 12:19 PM   #19094
soundman98
soundman98's Avatar
Be sure to use anti-seize on them. Aluminum valve caps can and will seize onto the valvestem, making it impossible to add air to the tire
Old 05-15-2021, 12:41 PM   #19095
StraightOuttaCanadaEh
Wes
Yep happened to me
Instagram: @gt86ws
Old 05-16-2021, 10:22 AM   #19096
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
finished flocking my bezel and installed the gauges
The Following 3 Users Say Thank You to Breadman For This Useful Post:
Dzmitry (05-17-2021), ichitaka05 (05-18-2021), Kiske (05-18-2021)
