Old 05-14-2021, 12:57 PM   #29
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by nikitopo View Post
Maybe trying to keep the low center of gravity? Tim Schrick is participating in the VLN Endurance Racing Nürburgring championship and he replaced the engine with an older EJ20 motor. This year replaced it again with a six-cylinder EG33 motor.
https://www.motul.com/de/en/news/eve...z-in-the-world
I don't think you can have a lower COG with engines other than a boxer. It not only about how much low or high the engine sits in the bay. It is about the overall height of the engine and of not being top heavy. The main advantage of a K24 swap would be its higher power output and lower weight, so you would have also a bit better front to rear weight distribution with the expense of a bit worse COG. I believe K24 weights around 413 lbs. (including transmission), while FA20 is in the range of 480 lbs.
Supra's cog is lower.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
NoHaveMSG (05-14-2021)
Old 05-14-2021, 01:30 PM   #30
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
and I remember the original 86 launch docs said the LFA & 360 had a lower CoG and they used V configs..perhaps not the best cars to compare to a twin lol. perhaps for cheaper applications boxer is easiest way to achieve low CoG.
but idk CoG is cool but also a bit overrated IMO..thought experiment, hypothetically you could take say a higher riding sports car and put slabs of metal underneath the car to make it have a "better" CoG than the twins, doesn't mean much then right?
HKz is offline   Reply With Quote
The Following 2 Users Say Thank You to HKz For This Useful Post:
NoHaveMSG (05-14-2021), Tokay444 (05-14-2021)
Old 05-14-2021, 01:50 PM   #31
Ohio Enthusiast
Drives: 2018 BRZ
Car and Driver says that Toyota's claim isn't true.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
timurrrr (05-17-2021)
Old 05-14-2021, 02:06 PM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
Not sure how the lower c.g. of a boxer engine is overstated, if twins managed to have one of the lowest numbers of the segment.
They have a commendably low c.g. with the flat engine mounted high. They'd have a similarly low c.g. with a V-engine mounted low. C7 c.g. was measured at 17.5", quite a bit lower than its flat-engine Porsche 911 and Cayman contemporaries, 0.6" lower vs. FT86.
Even with a tall upright I-4 (mounted low), the twins would probably be no higher (I'd bet lower) than 18.5" c.g. height. Frankly the flat-4 has a bigger negative in FR application due to the engine having to sit quite far forward for steering shaft clearance. 18.1" c.g. height is great, but 55/45 is kinda crap, again I'd rather have 18.5" c.g. height with more rearward f/r distribution.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Ash_89 (05-14-2021), Tokay444 (05-14-2021), why? (05-15-2021)
Old 05-14-2021, 02:33 PM   #33
Tokay444
The engine can have a cog on the oil pan. If you mount it on the roof, what good does that part specific cog do you?
Yes, the cars have a low cog. No, it's not specifically because of the Boxer engine.
The Following User Says Thank You to Tokay444 For This Useful Post:
ZDan (05-14-2021)
Old 05-14-2021, 06:09 PM   #34
Lantanafrs2
Drives: 2013 frs red
Plug and play. No radiator required
Lantanafrs2 is online now   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
soundman98 (05-14-2021), T-Steve (05-15-2021)
Old 05-15-2021, 01:29 AM   #35
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It has been discussed here. I won't open the same topic again.
In general my feeling is that some people are really not happy that Toyota went with a Subaru engine. Then they will just throw whatever kind of arguments and hypothetical facts, no matter the reasoning and what real facts indicate. It is what it is.
The Following User Says Thank You to nikitopo For This Useful Post:
Tcoat (05-17-2021)
Old 05-15-2021, 08:13 AM   #36
why?
why?'s Avatar
Drives: series.blue
of course people are pissed Toyota went with a boxer 4 that has next to no development. Add in the torque dip and the fact it sounds like a farm tractor and you take one of the strengths of the original 86 and totally wreck it.
Old 05-15-2021, 10:06 AM   #37
ZDan
ZDan's Avatar
Drives: '23 BRZ
That's not the case for me. I've never owned a Toyota and never a huge fan of most of their sports/sporty cars. Love the 2000GT but honestly 240Z is the better car. I also love the original AE86, for what it was (lightweight, rwd, but a bit crude with live rear axle). The FT86 is not really a modern AE86 anyway, it's a modern S13 240SX.
Having done vehicle design and layout, I have opinions about flat/opposed engine architecture in cars (and motorcycles!) based on facts. It's not the end of the world, but there *are* tradeoffs, and the "low-c.g." argument is usually tremendously overstated. Yes, it is beneficial that the cylinder heads are low. But it hurts that the bottom-end, harmonic balancer, flywheel, clutch, and the front of transmission are mounted *high*. I would bet there *is* a slight net benefit vs. a lower-mounted upright inline-4, but I bet it's near enough a wash vs. DOHC V4, which would be *my* choice for a small lightweight sports car. I'd actually bet on the V4 having a slight advantage but there wouldn't be much in it either way.
Indeed, it is what it is! I love the car and generally have few complaints. My 1st one being that I wish it were a shorter-wheelbase cab-rearward 2-seater, which would fix the F/R weight distribution. 2nd is engine architecture, again I'd prefer a V4 but ain't no automakers doing that anyway, but Subaru would be well qualified to develop one! Inline-4 *would* be able to sit lower and further aft vs. the flat-4, somewhat addressing the F/R distribution without tremendously impacting c.g. height.
The Following 4 Users Say Thank You to ZDan For This Useful Post:
Ash_89 (05-17-2021), NoHaveMSG (05-15-2021), soundman98 (05-15-2021), Tokay444 (05-17-2021)
Old 05-15-2021, 01:31 PM   #38
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Torque dip is almost gone in new engine and I've heard people saying it sounds better too. No?
Old 05-16-2021, 02:54 AM   #39
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Subaru was dogmatic for years even on moving to a direct injection engine design. They are not that flexible to changes and sometimes it is for the best, because it gives them time to improve things gradually year by year up to perfection. This situation is changing lately for them, by working more closely with Toyota, but there are still old voices within the company. You also mentioned several times about the F/R distribution issue. Don't want to go off topic here, but STI had a different suspension setup on their JDM tS cars (the ones with the STI Bilstein suspension) with softer rear springs that transfer more weight to the rear. There are different ways to *fix* issues and although might not seem optimal, they still give them an option to not ruin the vehicle's practicality (i.e. being a 2+2 seater).
Old 05-16-2021, 09:56 AM   #40
ZDan
ZDan's Avatar
Drives: '23 BRZ
I dunno, the perfect embodiment of a somewhat difficult-to-package engine may be dogmatic to a fault... They should do the V4, they already have cylinder heads for it!
Softer rear springs do not "transfer more weight to the rear". Weight transfer during acceleration is a function of c.g. height, wheelbase, and acceleration rate. Softer springs either end won't change that.
If it *must* be a 2+2, V4 mounted as far aft as possible would help.
"Fixes" mean big compromises, the best "fix" is to improve the weight distribution to something more reasonable for an FR sports car. 55/45 is garbage. Even V8 nose-heavy Mustangs and Camaros do better...
50/50 would greatly reduce load on the outside front during cornering and give more total lateral grip. It'd also improve braking performance. In addition to being able to put the power down better. Faster!
Old 05-16-2021, 10:31 AM   #41
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If Toyota wanted a V4 engine, then they would look somewhere else or they would develop it themselves.
I didn't mention during acceleration, but let's leave it there.
Not sure why a car that is praised for its handling ability, has now a garbage weight distribution. 911's have an even more garbage weight distribution with the majority of the total weight on the rear, but they have worked with suspension geometry for decades and they are well established in car's history.
Subaru have their expertise on building boxer engines and it is what is. They don't have the capacity having different engine designs. I am mentioning it again that they even had a big trouble moving into direct injection! Something that looks a "fix" for you, could mean a (financial) disaster for them.
Old 05-16-2021, 12:41 PM   #42
ZDan
ZDan's Avatar
Drives: '23 BRZ
I never said anything about Toyota...
In any context, your comment about JDM tS having "softer rear springs that transfer more weight to the rear" doesn't make sense. Softer rear springs don't transfer more weight to the rear under braking, acceleration, or cornering. If they went with softer rear springs, they moved roll stiffness distribution forward, which would further load up the outside front during cornering and keep the rears more evenly loaded. Good for drive, but bad for front grip...
55/45 is crap for an FR performance car. Yes, the car is well set up and very fun to drive! But grip is *far* from optimized... With 50/50 weight distribution, I would have won my time trial easily on Sunday vs coming in 2nd by less than a tenth...
Rear bias is BETTER for a rear-drive performance car. 50/50 is *not* "perfect". It is better than 55F/45R, but 45F/55R is *better still*. Mega-performance rwd cars will generally have ~45/55 to ~40/60 weight distribution.
Forward weight distribution means the outside front is doing way more than it's fair share during cornering, so you're losing grip there. Could try to correct for that with more rear roll stiffness, but before long you'll overcome the Torsen diff's ability to deliver power to both rears, so kind of a dead-end. Even with a good ramp-type clutch diff, you're only going to be able to put so much power down on corner exit. This is already a minor issue even at stock 205hp.
Forward weight distribution in an FR performance car is bad for:
1. braking: fronts are relatively overloaded with ~75% of the load and rears underutilized carrying only 25%
2. cornering: outside front overloaded, way beyond the linear portion of the grip/load curve, while outside rear is underutilized again
3. accelerating: less load on the driven rear wheels = less drive grip.
There are better ways to do things. But yeah, it's easier to stick with what you know. But is it really the best long-term strategy? At this stage, probably not worth the investment as we move to other types of power units...
Looking for previous owner MasterBandit Southern California 3 11-04-2019 11:13 PM
Your previous car. EzyBrzy Northern California 37 12-06-2015 02:34 PM
What do you do in your FRS/BRZ that you never did in your previous cars? Thehermdawg FR-S / BRZ vs.... 17 05-23-2014 01:35 PM
Sure the FR-S is awesome, but do you miss your previous car? Frs x3 Other Vehicles & General Automotive Discussions 132 05-20-2014 02:28 PM
Any previous Miata owners out there? x96nax Tracking / Autocross / HPDE / Drifting 26 07-27-2013 07:29 AM
