Old 05-13-2021, 07:40 PM   #1
pakunodafie
Drives: Toyota GT86
Exclamation Long cranks and engine struggling to start. Please help!
Hello guys, I am experiencing this issue since last week, Whenever I parked the car for about 1-2 hours and get back to start the car, sometimes it start fine sometimes it cranks for a long 5secs and struggle to start but it will fire.
If the car parked overnight and starting the car it just start right away (0.5 - 1sec) It seems weird I cannot replicate the issue it just goes randomly when car is parked for a few hours and starting it back.
The car is Automatic and have push start button,
No modifications only Invidia N1.
Car is 2014 Model.
I read some forums that I need to prime my fuel pump first for (2-5sec) by pushing the start button twice then fire it up. I can live with this but since owning the car way back 2014, I am used to start up the car without priming the fuel.
Already checked on this forums some other have similar issues but no solutions or feedback how to fix it. If anyone encountered this and have a fix or speculations please help.
- Battery is tested healthy
- Alternator tested while idle giving 14v+
pakunodafie is offline   Reply With Quote
The Following User Says Thank You to pakunodafie For This Useful Post:
humfrz (05-14-2021)
Old 05-13-2021, 08:01 PM   #2
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
My understanding is you need 4 things:
Spark
Fuel
Air
Compression
I would start with the easiest first, maybe someone else has some tips. But I would check fuel and spark
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
pakunodafie (05-13-2021)
Old 05-13-2021, 08:03 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
Mine does this from time to time. I notice it most on quick short trips
Old 05-13-2021, 08:49 PM   #4
pakunodafie
Drives: Toyota GT86
How do you live with it or fix it?
Old 05-13-2021, 10:03 PM   #5
soundman98
soundman98's Avatar
i grew up on a car that destroyed it's own engine mounts calmly driving around town, randomly puked transmission fluid, leaked oil at a rate fast enough i didn't need to change it, just keep adding new oil, the a/c never worked, the heat stopped working after the 2nd year, and the convertible top only kept the big rain drops out.
after that, your priorities change. if it starts, it starts. not worth messing with.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
BrahmaBull1990 (05-14-2021), humfrz (05-14-2021), Lantanafrs2 (05-13-2021)
Old 05-14-2021, 09:26 AM   #6
pakunodafie
Drives: Toyota GT86
Up
Old 05-14-2021, 03:44 PM   #7
Car is 2014 Model.
How many miles on your car? If it's over 50,000 miles, and you haven't changed the spark plugs, you may consider doing that.
Have you changed the source of your fuel lately? Maybe it got hold of some "bad gas".
Old 05-14-2021, 04:24 PM   #8
pakunodafie
Drives: Toyota GT86
Mine has 140,000 km, did a Major service at 90,000 with sparks plugs and injectors replacement (covered by warranty) .
Fuel is consistent since day one, I only topup with the best fuel here in UAE (98 Special) Already refuel twice from empty to full. And still long cranks occasionally happens.
humfrz (05-14-2021)
Old 05-14-2021, 04:41 PM   #9
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Hahaha too relatable. My first car was a 1989 Subaru GL Wagon. It leaked so much oil I just had to keep replacing it. The odometer stopped working before I got it at 232k miles. It always started though; ended up giving it away to a friend for his first car.
soundman98 (05-14-2021)
Old 05-14-2021, 05:26 PM   #10
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Like @humfrz said. At least pull the plugs and see what they tell you. You can learn a lot about your motor from just reading the plugs. Does that 90k service include coils?
aKaGorganZola is offline   Reply With Quote
The Following User Says Thank You to aKaGorganZola For This Useful Post:
humfrz (05-14-2021)
Old 05-14-2021, 06:36 PM   #11
pakunodafie
Drives: Toyota GT86
I am not sure if coils are included on the Major services, But they change the sparks plugs and replaced the injectors (covered by warranty).
Old 05-14-2021, 08:28 PM   #12
aKaGorganZola
I think that would be a good first step. Take an hour or so and pull the plugs and see what they say. If everything is good there you can move on to other things. My next thought would be fuel somewhere. Maybe your pump is getting tired and it gets hot after a drive and doesn't want to build pressure. If you've got any way to check your fuel pressure that might be worth a check. Hope you get it figured out and it's something silly and easy dude
Old 05-14-2021, 09:28 PM   #13
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I second this. Pull your spark plugs and see what they look like. You can always upload a picture of your plugs so we can see.
scion fr-s is offline   Reply With Quote
Old 08-30-2021, 08:49 PM   #14
aKaGorganZola
So funny story but just this last week my car started behaving very similarly to this. After a drive the car cranks for a few seconds before firing up then send to run ok. Over night three car starts fine in the morning. I just assumed it was the heat and humidity but when I pulled up the live data it looks like my fuel pressure is lower than I remember. It's foggy now but I seem to remember about 60psi at the fuel rail but now I'm only seeing about 40. Anyone know if our cars have an inline fuel filter i can pull to check or just the sock in the tank?
cranking, start up
2013 Scion FR-S cranks but no start!!! Btborja Issues | Warranty | Recalls / TSB 43 10-29-2023 10:30 PM
HELP! Cranks but won't start P0102 P0113 Sum10clever Issues | Warranty | Recalls / TSB 2 09-06-2020 12:46 AM
Clutch Flywheel & Fuel rail change Engine cranks but won't start after svnintl Engine, Exhaust, Transmission 17 08-02-2020 09:27 PM
Car cranks but wont start yablonskiy11 Issues | Warranty | Recalls / TSB 15 01-02-2019 01:18 PM
FRS struggling to start (video) FRStevan Issues | Warranty | Recalls / TSB 12 06-10-2017 03:48 AM
