Old 05-12-2021, 06:33 PM   #1
breowleh
breowleh's Avatar
Drives: 2018 Audi S4 Premium Plus
Bilstein B16/B14 and rear tophats: Dumb, drill, or buy something else?
Pretty self explanatory, but I'm trying to put together my B14 rear coils and the OEM tophats. I was under the impression it was just plug and chug.
While the spring fits the perch, after removing the adjustment knob, there is absolutely zero chance of getting the tophat fed over the threaded post, it doesn't fit and I'm not going to force it.
Should I
1. Do further disassembly and make it all fit together
2. Drill out the OEM top hats (yikes)
3. Buy some other top hats, if so what would you recommend?
For now, I am putting suspension back to stock -_-
breowleh is offline   Reply With Quote
Old 05-12-2021, 06:55 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I do believe the instructions are for you to drill it out, #1 is not an option.
Page 6 says to drill a 12mm diameter hole;
https://static.summitracing.com/glob...m4-y666a00.pdf
Diftech or Raceseng have aftermarket options.
ineedyourdiddly
Old 05-13-2021, 03:40 AM   #3
breowleh
breowleh's Avatar
Revised:
1. RTFM
2. Buy something if you want 😅
Thank you much
The Following User Says Thank You to breowleh For This Useful Post:
strat61caster (05-13-2021)
Old 05-13-2021, 04:03 PM   #4
EB86
Drives: GT86
I ask a local engineering shop to drill mine so it was neat and central.
EB86 is offline   Reply With Quote
Ohlins R&T w/ Raceseng Rear Tophats overlookedx Brakes, Suspension, Chassis 5 02-01-2018 07:14 PM
WTB 1" rear raceseng tophats gallucci86 Want-To-Buy Requests 1 02-13-2017 12:45 PM
Robispec Rear Tophats ReThink Brakes, Suspension, Chassis 2 08-01-2014 03:11 AM
WTB - Rear Coilover Tophats ReThink Want-To-Buy Requests 1 03-19-2014 01:56 AM
Toronto FR-S orders- Drill or no Drill on bumper Dragon86 CANADA 35 10-12-2012 01:35 PM
