Old 05-13-2021, 07:40 AM   #155
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by Blighty View Post
Yes it would be safe to assume its from the JDM STI showcar, but I doubt there would be a difference.
Are there different final drives in the 86/BRZ across different regions? I thought that, apart from the change with the 16+ cars, they were all the same.
Again, I'm not an expert on this info, but I do know Europe had a much lower gear ratio offered, a 3.727. If you do the calculations based on this video we see, assuming the internal gear ratio's remained the same, the final diff would have to be 3.5! That's substantially lower than the 4.1/4.3 from the first gen. Certainly not impossible, as their reason for it in Europe was mpg improvements, but seems like a wild drop for U.S. spec.
Point is, we don't know. There could be plenty of reasons we see what we see in this video, so I'll just patiently wait for those specs to be released.
Dzmitry is offline   Reply With Quote
Old 05-13-2021, 10:49 AM   #156
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Kronk View Post
0:59 .
This has some much better vision for spitballing. Early at where you have posted, and also at 2:29 it shows 4th at the rev limit doing 174kph.
First thing I've noticed is that it matches the OG 4.1 Final drive fairly close (actually more like 4.2).
BUT should we consider there being a difference between reported speed and real speed, as per automotive regulations dictating that all cars must report under the real speed.
If that is the case then a final drive could very well be the current and outgoing 4.3. But as its a testing car potentially they have a special version of the speed readout that is 100% accurate.
Of course its all under the assumption that they haven't changed the gear ratios themselves.
What I think is fairly clear though is that its going to be pretty much in the ballpark of the current car.
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
ermax (05-13-2021)
Old 05-13-2021, 11:04 AM   #157
Blighty
Originally Posted by timurrrr View Post
Here's CAN data.
On all the three graphs, green line is GPS speed.
As you say, that CAN data point does match the rear wheel speed.
If only I still had my car outside to do a burnout
Old 05-13-2021, 02:07 PM   #158
ermax
ermax's Avatar
0:59 .
Looks like the original 3rd gear with the 4.1 final. The speed is a little lagged it seems but very close.
Old 05-13-2021, 02:14 PM   #159
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
0:59 .
Thanks for spotting that!
The video is 24 fps, and each km/h number stays on for 6 frames, so it looks very much like a 4 Hz refresh rate.
And that's the TRACK mode
Between 0:41 and 0:43 (two seconds), the number changes 7 times. So ~3.5 Hz.
... so it didn't change much (if at all) from 1st gen.
I wouldn't overthink the regulations concern.
The current gen already very close to the real (GPS) speed, and I can't imagine why the new gen would be much worse.
We're also not talking about a Koenigsegg with bespoke transmission and final drive here.
I don't think they would spend too much time fine-tuning individual gear ratios, etc.
I'm pretty sure if they slap the '13 gears and final drive on the car with the same weight as '13 and 2.4L engine, it would be good enough in their opinion.
So if the 4th gear looks like it matches the '13 FD, then I'm just going to assume the gearing is the same as the '13-'16 gearing — until we have solid data about all the gears.
Old 05-13-2021, 02:31 PM   #160
Where on earth did you come up with that? You have it backwards.
Australia - The speedo must not indicate a speed less than the vehicle’s true speed or a speed greater than the vehicle’s true speed by an amount more than 10 percent plus 4 km/h.
USA - must be equipped with a speedometer indicating vehicle speed in miles per hour and/or kilometers per hour. The speedometer must be accurate to within plus or minus 8 km/hr (5 mph) at a speed of 80 km/hr (50 mph).
Europe - no speedometer can read slower than the actual speed. Ever. On the high side, it's allowed to read up to 10% above the actual speed plus four or six kilometers per hour, depending on the type of vehicle.
Canada - In Canada, Transport Canada doesn't have any regulations on speedometer accuracy.
LOL WE DON'T CARE!
Old 05-13-2021, 03:20 PM   #161
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Probably just confused "less" and "more", no big deal.
It's a confusing topic to talk about two different speeds for the same object at the same time
The Following User Says Thank You to timurrrr For This Useful Post:
Blighty (05-18-2021)
Old 05-13-2021, 03:22 PM   #162
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Hmmm I wonder if we can find a way to prove that due to the 4 Hz refresh rate the speed is reported too low,
and file something like a class action lawsuit which would result in increasing the refresh rate
Old 05-13-2021, 04:45 PM   #163
No no you can not. It is still accurate in the 10ths of a second. This is more than enough for near everybody except the most fanatical of gauge watchers.
Red-86 (05-13-2021)
Old 05-13-2021, 05:43 PM   #164
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I shudder to think how some of the people in this thread could ever have coped with a good old cable driven speedometer, where the needle position was governed by how frequently an off center peg was hitting against the spring loaded needle...
How did we ever survive? Oh the humanities!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 3 Users Say Thank You to nextcar For This Useful Post:
Dadhawk (05-14-2021), soundman98 (05-13-2021), Tcoat (05-13-2021)
Old 05-13-2021, 05:43 PM   #165
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Who just said "Ever."?
Old 05-13-2021, 05:43 PM   #166
ermax
ermax's Avatar
Just maintain a consistent speed for a fraction of a second and BAM, you have your answer. :P
The Following 2 Users Say Thank You to ermax For This Useful Post:
Tcoat (05-13-2021), timurrrr (05-13-2021)
Old 05-13-2021, 06:08 PM   #167
Red-86
Drives: 86 (sold), 370Z
I am amazed at angst over digital speedo refresh rate. Wow. It’s there to make sure you don’t get a speeding ticket. You really shouldn’t be staring at it for long (because that is taking your eyes off the road), and for the quick speed check they are designed for, a normal refresh rate where each number is quickly parsed with a brief glance is better and safer than a faster but unintelligible whirring refresh rate that is useless at anything but a constant speed.
Red-86 is offline   Reply With Quote
The Following User Says Thank You to Red-86 For This Useful Post:
Tcoat (05-13-2021)
Old 05-13-2021, 06:14 PM   #168
And could constantly fluctuate in a 10 MPH arch!
In-dash digital speedometer vaer Electronics | Audio | NAV | Infotainment 4 04-14-2020 10:19 AM
Does the BRZ get same refresh? snezze21 BRZ First-Gen (2012+) — General Topics 74 03-24-2016 01:51 PM
Convert the digital speedometer from Kmh to MPH? Jastation Electronics | Audio | NAV | Infotainment 10 09-28-2015 05:46 AM
Digital speedometer in base GT86? rhysmcinerney Electronics | Audio | NAV | Infotainment 25 01-22-2014 06:18 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
