Old 05-12-2021, 10:32 PM   #23031
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Installed TRD Special Edition exhaust
Old 05-13-2021, 04:38 AM   #23032
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Isn't it hanging a little low? I had the same issue with an aftermarket exhaust and that turned out to be an absolute pain to sort.
alex87f is online now   Reply With Quote
Old 05-13-2021, 07:27 AM   #23033
saltywetman
Drives: 2020 Toyota 86 GT 6M
Originally Posted by Lucky21 View Post
Installed a CAG One For All monitoring gauge and new wheels
[IMG][/IMG]
[IMG][/IMG]
Is that the full modellista aero kit on? got any more pix?
saltywetman is offline   Reply With Quote
Old 05-13-2021, 12:11 PM   #23034
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Been a busy couple weeks. Pulled the car in the garage for an oil change, and while I was at it...*
  • Cusco transmission mount collar
  • MTEC shifter and clutch springs
  • Cusco steering rack bushings (which I almost dorked up because I was in a hurry)
  • RCE Yellows and Bilstein B6s
Car doesn't look that different, but the handling and feel is TRANSFORMED. The trans mount collar came with a fairly significant amount of NVH, but I don't hate it. Sounds more Race Car without being obnoxious. The shifter and clutch springs tightened everything up, and feel like it should have from the factory all along.
The steering rack bushings were a pleasant surprise. I thought the steering was quick before... Now it's practically telepathic.
The springs and shocks are super interesting as well. Combined with some crash bolts for a little negative camber (-1.1°), the understeer is GREATLY diminished, and the front end feels super planted on corner entry now. Corner exit, the rear is a little flighty, but I need to play with it a little to understand what's going on and maybe adjust my style a little.
The ride quality is the interesting part. The car is noticeably lower and firmer, yet the ride is somehow less harsh. It's like you feel more of the road, but the chassis is still more composed than on the stock bits. A well-sorted kit from @Racecomp Engineering, and highly recommended!
*Actually several sessions, so I could feel the difference of the mods independently, because I'm a nerd.
Cephas is offline   Reply With Quote
Old 05-13-2021, 02:14 PM   #23035
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Looks clean! The only thing I'd recommend, in keeping the stock rims, would be some 20mm spacers to push them out to the edge. Won't effect ride quality or feel but really improves the stance without any fear of rubbing.
MJones_RB is offline   Reply With Quote
Old 05-13-2021, 04:23 PM   #23036
NLSP
NLSP's Avatar
Yea it does hang a bit low for my liking...the TRD USA exhausts were designed to have a 25+/- 5 mm gap between the bumper.
I've seen people try closing these gaps by tightening a hose/worm clamp around the hangers, so I might try that.
What was your solution?
Old 05-13-2021, 05:19 PM   #23037
Cephas
Cephas's Avatar
Thought about that, but probably going to slap snow tires on the stockers this winter, and come out next spring with a nice, wider wheel/tire combo to fix the stance. The reduced wheel gap from the springs is enough to scratch the itch for me, for the time being!
Also, this came the other day...
Old 05-14-2021, 08:21 AM   #23038
alex87f
Meow
alex87f's Avatar
My solution was exactly that . It just took me a long time to come round it.
They've been there for over a year, and haven't moved one bit. Haven't eaten into the silent blocs either.
Old 05-14-2021, 02:57 PM   #23039
NLSP
NLSP's Avatar
Haha nice! Sounds like a good solution then, thank you for confirming
Old 05-14-2021, 10:44 PM   #23040
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
The front and side are from the kouki trd kit I'm afraid.
Lucky21 is offline   Reply With Quote
Old 05-14-2021, 10:50 PM   #23041
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Had a Friday night meet. Turnout was better than expected, and we had a 2J swap car make an appearance.
The one day I forget to bring my camera. Camera phone works decently at least.
Old 05-14-2021, 10:57 PM   #23042
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Went to the dyno today for a tune. I added a low boost map which caps off at 5 psi
Old 05-15-2021, 12:49 AM   #23043
saltywetman
Darn i should've picked that out... for some reason i didn't notice the satin black lower portion and thought it was just shadows lol
Old 05-15-2021, 01:02 AM   #23044
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
I saw one with the front end in my local group.
