Old 02-27-2021, 09:55 PM   #155
ML
ML's Avatar
Drives: 13 White MT FR-S
what are you guys doing as far as maintenance for the k24 before it goes in? Seems VTC gear, type s oil pump, spark plugs, and maybe head gasket just to freshed up the motor? I know the oil pump is basically mandatory. I'm getting my motor locally with about 100k on it.
Old 02-27-2021, 11:11 PM   #156
PulsarBeeerz
Drives: JRSC BRZ SOLD
All the above plus new OEM timing chain, timing chain tensioner and timing chain guides.
PulsarBeeerz is offline   Reply With Quote
Old 03-01-2021, 04:13 AM   #157
Tomm
Identifying as a Member
Tomm's Avatar
Drives: 2013 FRS LS1
Head gasket too? If I was breaking it down that far I'd be doing Wiseco pistons, Saenz rods, and sending the head off to 4P.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline
Tomm is offline   Reply With Quote
Old 04-29-2021, 10:04 PM   #158
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Eager to hear more about this...
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
Old 04-30-2021, 12:52 AM   #159
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Some info here:
https://www.ft86club.com/forums/showthread.php?t=145040
Old 05-07-2021, 10:38 PM   #160
jmimac351
jmimac351's Avatar
Thanks for sharing. I hope to have a candidate in house in a few weeks. If that works out there is a 110% chance this swap happens. It's a great "recipe".
2015 Subaru BRZ
Old 05-08-2021, 07:06 PM   #161
Irace86.2.0
I sent an email to NorthWestJDMMotors and tried to call. No answer so far. I’ll probably get a motor this month or early next month.
RSX Type-S oil pumps are in short supply like many things. KPower is prioritizing selling these to people who bought their swap kits, and I’m 98% sure it is required to use their oil pan. FYI.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
jmimac351 (05-08-2021)
Old 05-10-2021, 04:09 AM   #162
Tomm
Tomm's Avatar
4Piston's ported pump won't work?
The Following User Says Thank You to Tomm For This Useful Post:
Irace86.2.0 (05-10-2021)
Old 05-10-2021, 11:20 AM   #163
Irace86.2.0
I’m not sure if their kit will work with the swapped oil pan, but the pump probably will.
Still backordered or in short supply.
Old 05-10-2021, 01:46 PM   #164
Irace86.2.0
That oil pump is good insurance like they said, but I won’t be revving the motor out to 9k.
Old 05-11-2021, 03:58 AM   #165
Tomm
Tomm's Avatar
That's fair. Whats your power goal?
Old 05-11-2021, 12:55 PM   #166
Irace86.2.0
I’m still debating what I want to do. I may stay NA/E85 for a few years and then go turbo after nursing school, or I may go with a modest turbo build and then do a built motor and the works later. If I do a turbo now, I may stick with sub 400whp for now, so fairly modest goals. The K24 can handle 450whp with stock internals, but I don’t want to be near that for now. Part of that is for reliability with the motor and part of it is for reliability with the tranny, and so I can keep the current clutch. 8k 350-400whp is plenty for now, and it approximates what I had before.
I’m debating on what I should do for a turbo. I would want lower turbo lag, and I don’t want the boost threshold to be too high in the powerband, but I would also prefer something that is large enough that it pulls all the way to redline and doesn’t fall off. The GTX3071R seems to pop up a lot in my searches, but I don’t know about all the differences in the GTX series. Seems like there is a lot of overlap because a given turbo can have different ar housings and internals, and it just makes choosing a “perfect” difficult—options overload.
https://en.m.wikipedia.org/wiki/Overchoice
Old 05-12-2021, 04:20 AM   #167
Tomm
Tomm's Avatar
I personally would wait until you get the motor in there. K series motors have a way of turning people onto the all motor idea. A ported k24a2 head with a nice set of cams and upgraded valve springs/retainers will easily get you close to 300 (assuming you run the Kpower IM, header, haltech, cam gear, etc.).
Irace86.2.0 (05-12-2021)
Old 05-12-2021, 09:07 AM   #168
Irace86.2.0
I’ll probably do that just because of cost and reliability until after nursing school, but there will definitely be a turbo in the future. This way I can sort out any issues before boost too.
Tomm (05-12-2021)
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
