Old 05-11-2021, 12:01 PM   #141
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^ On the gear ratios - this is not what I wanted to see. If I want super-tall gearing that limits my shifting fun I'll buy a used Cayman...
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
NoHaveMSG (05-13-2021)
Old 05-11-2021, 12:08 PM   #142
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I wouldnt call it super tall.
Its about 40mph, probably hits between 60~62mph in 2nd at redline.
Blighty is offline   Reply With Quote
Old 05-11-2021, 12:40 PM   #143
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
According to R&T, at release the FR-S hit 35 mph in first at 7400 rpm - and of course that's before the final drive was shortened. So there appears to be a substantial maximum speed gap in first that will only get wider in the higher gears.
Old 05-11-2021, 01:52 PM   #144
ermax
ermax's Avatar
If my stupid brain is working. I'm sure there is a google tool for this
Yep, there is a really good one here:
https://www.blocklayer.com/rpm-gear.aspx
Or this link which supplies all the details for a 2013 Twin with 6MT:
https://apx6u.app.goo.gl/XgGN
The Following User Says Thank You to ermax For This Useful Post:
Blighty (05-11-2021)
Old 05-11-2021, 04:08 PM   #145
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I don't have a recent data log of bouncing off the rev limiter in 1st in my '17 BRZ, but I do have a data log where 27.5 mph is recorded at 6000 rpm.
This means a '17 BRZ (i.e. with a shorter final drive) should do 34 mph in 1st.
I vaguely remember seeing 37 mph in 1st at one point, but don't remember if it was in my car or a pre-'17 rental; neither do I remember what rev limiter was set to.
Having rewatched that clip at 0:15 frame by frame (use ,/. keys in YouTube), I'm now even more suspicious of what's going on.
As the digital tachometer crosses 5k rpm, the digital speedometer changes from 61 to 62 km/h.
As the digital tachometer crosses 7k rpm, the digital speedometer changes from 64 to 65 km/h.
You don't need to be a math professor to know that if a car does 61–62 km/h at 5k, it should do ~86 km/h at 7k rpm in the same gear.
Similarly, if it does 64–65 km/h at 7k, it should be doing 46 km/h at 5k rpm.
Assuming both rpm and wheel speed sensors are responsive enough, this can only be explained by either:
- they were revving the engine in neutral (or with clutch pressed) while slowly accelerating downhill (not likely?),
- or there's too much artificial smoothing or latency going on (which makes me sad).
What's even more suspicious is that in the last couple of frames of that shot you can see the digital tachometer showing increasing rpms,
while the vertical line in the dyno plot on the left is already showing decreasing rpms.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Blighty (05-12-2021), Sport-Tech (05-12-2021)
Old 05-11-2021, 04:17 PM   #146
Transport3r
Drives: -
Lol. So the one datapoint in this whole discussion turns out to be effects editing in a marketing video? Nice.
Transport3r is offline   Reply With Quote
The Following 3 Users Say Thank You to Transport3r For This Useful Post:
p1l0t (05-12-2021), Tcoat (05-11-2021), timurrrr (05-11-2021)
Old 05-11-2021, 07:12 PM   #147
p1l0t
p1l0t's Avatar
Old 05-11-2021, 11:29 PM   #148
Blighty
Great pickup.
If its faked then its faked. Pretty good fakery though, they even included the dyno animation.
If its real then its possible that this is a second gear wheel spin. Wheel speed isn't the only thing they use to calculate real speed - you wont find your car reporting your speed based on a burnouts tire velocity But all this certainly makes it much harder to garner anything at all (apart from perhaps the shift point up to 2nd was down between 55-60kph - which actually starts to put it back in the ballpark of a 4.1 ratio (57kph at 7400).
The Following User Says Thank You to Blighty For This Useful Post:
p1l0t (05-12-2021)
Old 05-12-2021, 09:21 AM   #149
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Before we get too deep into this conversation, and this may have been mentioned, I just skimmed through everything - but keep in mind there are different final gear ratio's in different regions due to regulations. So this video may not be telling us much of anything related to the actual final drive U.S. specs.
Dzmitry is offline   Reply With Quote
The Following 3 Users Say Thank You to Dzmitry For This Useful Post:
p1l0t (05-12-2021), Sport-Tech (05-12-2021), Tcoat (05-12-2021)
Old 05-12-2021, 01:31 PM   #150
Blighty
Yes it would be safe to assume its from the JDM STI showcar, but I doubt there would be a difference.
Are there different final drives in the 86/BRZ across different regions? I thought that, apart from the change with the 16+ cars, they were all the same.
Old 05-12-2021, 03:11 PM   #151
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Finally someone mentions wheel spin!
Hmm, are you sure?
The speed data on the CAN bus (and OBD-II) certainly reports whatever the speed the rear wheels are rotating at.
When I launch at autox and get wheel spin, or when I go sideways at the skidpad, I certainly see the CAN speed not matching the GPS speed, but still being in sync with the rpms.
I just reviewed a few of my onboards, and whenever I see the digital speedo, it matches the virtual gauges in my overlay created from the CAN data (except for the lag due to terrible refresh rate).
I have to admit I never tried doing a standing burnout in my BRZ to be able to say for sure that they only use the speed sensors on the rear wheels to calculate speed displayed on the digital speedometer.
Possibly! But if I were to make a bet, I'd expect them to use one final drive everywhere for this new gen, at least for the first few model years.
I think I heard that they kept the taller FD in Europe for '17+.
Blighty (05-13-2021), Dzmitry (05-13-2021)
Old 05-12-2021, 03:29 PM   #152
Sasquachulator
Pavement Grey
Some places didnt get the +5hp/trq and the red intake plenum with the manual.
Gonna assume the FD didnt change when those didnt change either.
The Following User Says Thank You to Sasquachulator For This Useful Post:
timurrrr (05-12-2021)
Old 05-12-2021, 03:42 PM   #153
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Hmm, are you sure?
Here's CAN data.
On all the three graphs, green line is GPS speed.
Cyan — CAN speed
Purple — RPM
Cyan — CAN speed
Orange, purple — Rear wheel speeds
Cyan — CAN speed
Orange, purple — Front wheel speeds
The Following User Says Thank You to timurrrr For This Useful Post:
Old 05-13-2021, 06:58 AM   #154
Kronk
Drives: Planning for GR86
Kronk is offline   Reply With Quote
The Following 2 Users Say Thank You to Kronk For This Useful Post:
Blighty (05-13-2021), timurrrr (05-13-2021)
In-dash digital speedometer vaer Electronics | Audio | NAV | Infotainment 4 04-14-2020 10:19 AM
Does the BRZ get same refresh? snezze21 BRZ First-Gen (2012+) — General Topics 74 03-24-2016 01:51 PM
Convert the digital speedometer from Kmh to MPH? Jastation Electronics | Audio | NAV | Infotainment 10 09-28-2015 05:46 AM
Digital speedometer in base GT86? rhysmcinerney Electronics | Audio | NAV | Infotainment 25 01-22-2014 06:18 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
