Old 05-10-2021, 01:05 PM   #911
Well damnit that will teach me to stop researching when enough is enough!
Found another picture from an angle I haven't seen before. Now I have to add oxygen tanks and plumbing. I was just going to throw them on the scrap heap but there they are in all their glory. Also need to drop the starboard flap completely and take more material off the spine.
Dadhawk (05-10-2021), soundman98 (05-10-2021), Spuds (05-10-2021), Ultramaroon (05-10-2021)
Old 05-10-2021, 03:28 PM   #912
Just toss the bottles onto your parts pile and call it good. I read somewhere that they were removed for safe transport right after that picture was taken.
soundman98 (05-10-2021), Spuds (05-10-2021), Tcoat (05-10-2021)
Old 05-10-2021, 04:16 PM   #913
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You gonna do the engine now too?
Old 05-10-2021, 04:17 PM   #914
Spuds
The Dictater
Spuds's Avatar
Except that looks like it was after transport unless the farm he put it down in had a hangar...
Probably don't need to change the flap angle if that is the case at least.
Edit:. Also the canopy looks to have been assembled in this one?
The Following User Says Thank You to Spuds For This Useful Post:
Old 05-10-2021, 05:37 PM   #915
Hmmm! Well, I was kidding about the transport but I think you have a point. That tree line is the same in all the pics. Also, the control surfaces are all in the same position.
Spuds (05-10-2021)
Old 05-10-2021, 06:24 PM   #916
Well I have to make them anyway so may as well be in the airframe as beside it.
I looked for an engine for it but the only option was to buy another very expensive kit or go resin. The resin one was just about three times what I paid for the kit. Since I am giving it away I just didn't feel quite that generous.
The picture I was basing the front section on was the partially stripped down and tarped over engine front section. It just seemed more different than having the plane complete but broken in half. It was obviously further through the process than the picture of the front and tail but I am assuming they were still in the same position by the background.
The whole story goes like this (I can't remember the site where I found it).
He was returning from his last mission and the press were all in attendance.
He made a couple of high speed low passes for the cameras.
You can see how close to the buildings he was.
On his third pass he came in too low and bounced the tail off the ground.
This pushed him nose down and he had a prop strike which mangled the prop.
This is where it gets amazing!
He had been going so fast that he was able to bring the nose up and actually get some altitude.
He glided the plane away from the airfield and crowd.
After just under 2 miles (yes miles) he had dropped off enough speed and was over a nice open freshly plowed field so he just puled it up into a stall and lightly laid it on the ground tail first.
I was baffled by the pictures as there are no marks where it slide but apparently it just stayed put.
They then lifted the whole thing and manually lowered and locked the landing gear down.
Then they dragged it back the two miles to the airfield with it totally breaking in half on the way.
Once back it was stripped of good parts and the rest was scrapped.
I never could find out where the nose art ended up but I doubt it was reused or scrapped so could be hanging in somebody's basement to this day.
Dadhawk (05-10-2021), Jdmjunkie (05-10-2021), soundman98 (05-10-2021), Spuds (05-10-2021), Ultramaroon (05-10-2021)
Old 05-10-2021, 06:50 PM   #917
We'll see it on an episode of Antiques Roadshow. (U.S. Public Broadcasting System series)
Did I ever neither confirm nor deny a story about an alleged 450 knot tree strike?
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Dadhawk (05-10-2021), soundman98 (05-10-2021), Spuds (05-10-2021), Tcoat (05-10-2021)
Old 05-10-2021, 07:04 PM   #918
Could be a BBS show as well though. Nothing says it ever left Briton.
No, no you did not.
Old 05-10-2021, 07:13 PM   #919
No, no you did not.
One of the many close calls that I may, or may not have survived.
Old 05-10-2021, 07:19 PM   #920
Is that really a "may or may not" situation?
Old 05-10-2021, 07:47 PM   #921
Spuds
The Dictater
Spuds's Avatar
Do you mean one of the alleged close calls that if it were to have happened you clearly survived it?
...Unless you secretly died and your mind entombed in a machine body...
soundman98 (05-10-2021), Ultramaroon (05-10-2021)
Old 05-10-2021, 07:51 PM   #922
Old 05-10-2021, 09:08 PM   #923
Yes, maybe.
Old 05-11-2021, 12:31 AM   #924
spike021
spike021's Avatar
Legos count as plastic, right?
I just built my first Lego project since I was a kid. Happened to be in the toy section at Target the other day and the box caught my eye. My dad has been building the fancier NASA Legos like the Saturn V so he kinda inspired me as well.
Not bad for a $13 kit... took about two hours. Nice weeknight project to do while watching the Giants baseball game. Most of the black outlines, the Porsche emblem, and the traditional rear “turbo” script were decals. I wasn’t 100% accurate due to tremors but managed to do a decent enough job.
Might need to buy one of the fancy super car lego kits now...
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 6 Users Say Thank You to spike021 For This Useful Post:
Dadhawk (05-11-2021), Kaotic Lazagna (05-11-2021), NoHaveMSG (05-11-2021), soundman98 (05-11-2021), Spuds (05-11-2021), Ultramaroon (05-11-2021)
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
