Old 05-08-2021, 12:55 PM   #77463
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Is important to be accurate... although 1/16th or even a 1/4in tolerance was probably fine...
Measure twice.
Sapphireho is offline
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (05-08-2021), NoHaveMSG (05-08-2021), p1l0t (05-08-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 01:53 PM   #77464
soundman98
ProCrastinationConsultant
soundman98's Avatar
Measure twice.
cut 4 times.
once to figure out the end of the tape measure is bent.
twice after realizing a screw got caught under the magnetic end of the tape measure
three after forgetting you needed 2 @ 5/8", and 1@ 3/8"
and four to get it all close enough for beer time.
soundman98 is offline
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
p1l0t (05-08-2021), Spuds (05-08-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 01:56 PM   #77465
soundman98
soundman98's Avatar
bit of a bittersweet day today. pulling the trucks audio build apart, and detailing the truck so i can start a new one. it's the first time in 4 years that the plastic rear interior panels have gone back on, i even found all the hardware!
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (05-09-2021), p1l0t (05-08-2021), ScoobsMcGee (05-11-2021), Spuds (05-08-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 02:13 PM   #77466
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Measure twice.
Imperial is bad enough Not to mention a crap chinese made rule that`s 1/32 out every inch
gen3v8 is offline
The Following 3 Users Say Thank You to gen3v8 For This Useful Post:
p1l0t (05-08-2021), soundman98 (05-08-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 02:23 PM   #77467
Measure twice.
Ha! That damn thing!
Ultramaroon is offline
gen3v8 (05-08-2021), p1l0t (05-08-2021), ScoobsMcGee (05-11-2021)
Old 05-08-2021, 04:14 PM   #77468
Thing is, in most cases as long as this is the measuring stick you are using, it would really wouldn't impact you much. It is only if you were using one that is "correct" and this one together that it would cause slight issues.
Dadhawk is offline
Old 05-08-2021, 06:33 PM   #77469
Thing is, in most cases as long as this is the measuring stick you are using, it would really impact you much. It is only if you were using one that is "correct" and this one together that it would cause slight issues.
Still works fine as a square. Hell, now it's a keepsake.
Dadhawk (05-09-2021), p1l0t (05-08-2021)
Old 05-08-2021, 06:39 PM   #77470
I get that. It's a big deal for those things that have been waiting on the shelf for the more important projects to be finished.
Old 05-08-2021, 09:22 PM   #77471
soundman98
soundman98's Avatar
In some handyman magazine my dad used to get, issues had a reader sent in 'top tip' section, and every other issue, someone would say something along the lines of "Use the same tape measure for the entire project", and then describe their example of how their project went wrong not listening to everyone else that suggested it.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (05-09-2021), p1l0t (05-08-2021), Spuds (05-08-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 10:10 PM   #77472
p1l0t
p1l0t's Avatar
So wait.. you're saying even before millennials on forums there were guys asking for advice, ignoring it, and then raging about it?
p1l0t is offline
The Following 9 Users Say Thank You to p1l0t For This Useful Post:
Dadhawk (05-09-2021), humfrz (05-09-2021), MICHAEL450f (05-08-2021), NoHaveMSG (05-09-2021), soundman98 (05-08-2021), Spuds (05-08-2021), Stephen W. (05-09-2021), Tcoat (05-09-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 10:33 PM   #77473
soundman98
soundman98's Avatar
time is circular
The Following 8 Users Say Thank You to soundman98 For This Useful Post:
MICHAEL450f (05-09-2021), NoHaveMSG (05-08-2021), p1l0t (05-08-2021), spike021 (05-09-2021), Spuds (05-08-2021), Stephen W. (05-09-2021), Tcoat (05-09-2021), Ultramaroon (05-09-2021)
Old 05-09-2021, 01:49 AM   #77474
Oh, ya. "Yes, dummy, I know I told you to tighten the nut till it squeaked - I thought you were tightening up the lug nuts!"
humfrz is offline
p1l0t (05-09-2021), soundman98 (05-09-2021)
Old 05-09-2021, 11:59 AM   #77475
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Didn’t know there’s an actual crypto call “Shiba Inu Coin”… maybe I need to buy some
ichitaka05 is offline
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
DarkPira7e (05-09-2021), soundman98 (05-09-2021)
Old 05-09-2021, 12:32 PM   #77476
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd be worried it would be as finicky as a Shiba Inu
NoHaveMSG is offline
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (05-09-2021), spike021 (05-09-2021), Spuds (05-09-2021)
