Old 05-03-2021, 09:26 PM   #1
dedpedal
Drives: Nissan 370z, Toyota GT86
dedpedal's 86 Beams トラックカー
Hey guys, my name is Anthony, I've had a long history of cars, a few SC300's, SC400's, a couple MKIII Supra's, (Grew up with Toyota, ventured into Nissan; S13 hatch, 370z, V36 G35 Sedan) I found myself keen on the idea of a FRS/BRZ/GT86 years after release, due to the fact of affordability. Since release their body styling has been appealing to me, and after watching them, learning them, working on them, driving them... I've saved up enough to buy one as a project. Shameless Instagram plug @dedpedal
Yes its a 2013, yes its a FR-S, but title says Toyota, and as a Toyota fan boy at heart, I refer it as my GT86. With that said, I'm ditching the Subaru FA20 motor and swapping in a Beams motor.
The car is for the most part stock. it has BC racing coilovers, and the rest are just Toyota / GT86 badging with the face lift.
I have a lot planned in this build, most of which I've been planning about 2 years ago before I even got the car. I do hope that I'm able to contribute to the platform, and justify the looks of this car in its performance as well. The purpose of this car? Grip and Drift fun, just like my Z, at less weight, and more power, with less cost! (maybe not the less cost...)
As a teaser I'm looking to adapting a knuckle that's forged (I've noticed the OEM one is cast) and that is readily available with 5x114.3 hubs. So no need to worry about discontinued small manufacturer projects. Wheel bearings are a consumable!
For now here are some pics from the day I got it.
Purchased without wheels or tail lights, my best friend was generous enough to let me borrow his spare wheels and stock tails to drive it home until I get my own stuff for it.
and for the fun of it, here are pics of my triple duty 370z
dedpedal is offline   Reply With Quote
The Following 2 Users Say Thank You to dedpedal For This Useful Post:
beltax90 (05-13-2021), Stonehorsw (05-04-2021)
Old 05-06-2021, 09:12 PM   #2
dedpedal
Been assessing a lot of the current state, and what the previous owner did/did not do... no need to go into detail but...
From left to right: FR, FL, RR, RL (no wonder the p/o stated the coilovers feel terrible)
As I rebuild the BC, I have some Revel (Tanabe) coilovers which ill be using to assess the cars weight and feel, springs are KW ~6kg for the front, and ~4kg rear. I set some preload on the rear, but the bump travel on these things are ridiculously short!
Moved on from the suspension and into the cockpit
First DIY mod I did was the reverse lock out bracket, I shorted the height just enough to shorten the pull up throw with my T&E Vertex shift knob
Will be installing some parts that I collected over a year ago as well, doge approves
PCI seat mounts and brackets
Installed some cheap aero and wheels as a placeholder. Most of these items are for me to enjoy the car until the final phase.
The Following User Says Thank You to dedpedal For This Useful Post:
BrahmaBull1990 (06-29-2021)
Old 05-06-2021, 09:42 PM   #3
dedpedal
On the back side of things I also acquired a spare subframe. Anyone know what subframe bushings are in this? Its blue delrin with a steel sleeve insert. I thought Maybe its Cusco, but I cant find anything on it. the superior steps have been chipped off, so I might knock these out and get some SuperPro polys (personally don't want solid delrin/alloy)
The subframe had a little surface rust so I started grinding away- took off the rear AFS leveling bracket, and some of the excess welding splatter, proceeded with welded in the Part Shop Max diff risers
Altezza pumpkin also arrived with 4.3 final gearing and a Cusco RS 1.5/2 way LSD, I'm happy to see the inside so clean, now to hope the clutch packs are fine.
Old 05-07-2021, 11:03 AM   #4
RayRay88
Drives: 2017 86 860 Special Edition
Very nice! What front lip/side skirt is this?
RayRay88 is offline   Reply With Quote
Old 05-07-2021, 05:20 PM   #5
dedpedal
Got it off ebay, not sure of exact brand, but fitment wasn't bad 9/10
Old 05-07-2021, 05:24 PM   #6
dedpedal
Started painting the subframe, I'm using the left over Steel-It cans I had when I did my 370z subframe.
Multitasked and cleaned off the muck from the engine bay
Also got some finishing touches to my cockpit (prototype of the carbon shifter plate)
beltax90 (05-14-2021)
Old 05-10-2021, 01:18 PM   #7
dedpedal
Subframe bushings came in!
First encounter with Super Pro, they also make stuff for the 370z, but I haven't gotten anything from them at the time.
Lifetime warranty WITH racing?? Ill take it!
I'm actually please with their quality. A nice touch is the steel rings that mate with the edges of the subframe. this is good to prevent any slicing from heavy / sudden loads to the frame. Something I have yet to see from Energy Suspension.
Old 05-11-2021, 06:54 PM   #8
dedpedal
Picked up my street exhaust from my favorite shop, Speed Alliance in San Diego
Took it around to break in the exhaust and had to take an obligatory gas station photo
Berserker (05-11-2021)
Old 05-13-2021, 07:28 PM   #9
dedpedal
Did some more suspension changes, and comparisons
Current setup seems to be the most promising... I haven't taken photos of the front but right now its 6kg front and 4kg rear on the KW springs
This should feel very similar to the HKS coilovers
Old 05-14-2021, 11:18 AM   #10
dedpedal
Originally Posted by beltax90 View Post
Cool! what part of sd are you in?
Scripps Ranch, you around?
Old 05-14-2021, 11:28 AM   #11
dedpedal
1/3 major components was acquired last night
The Following 4 Users Say Thank You to dedpedal For This Useful Post:
beltax90 (05-14-2021), BrahmaBull1990 (06-29-2021), Irace86.2.0 (06-27-2021), saltywetman (06-05-2021)
Old 05-14-2021, 12:32 PM   #12
dedpedal
yup! maybe ill see ya around sometime! or maybe i already have during the supra years!
Hmmm it's possible! Maybe we can meet up some time
Old 05-28-2021, 04:08 PM   #13
dedpedal
lack of updates, but out of the many, here's some pics of the completed subframe
any rust sanded down, shaved off extra tabs, & painted with Steel-it.
Super Pro bushings installed
Thefalls (05-28-2021)
Old 06-03-2021, 11:15 AM   #14
dedpedal
Really just some superficial updates right now (alot of data collection been going on recently so not much movement in the garage)
I did pick up my wheels though
18x10.5+22, 5x114 (yes 5x114)
set of 9.5s are on order, about 10 weeks out...
Flipedge - Kouki GT86 Build Flipedge Member's Car Journals 1 12-10-2018 02:12 PM
AJ's Turbocharged GT86 Build ASHRAF Member's Car Journals 16 05-29-2017 05:15 PM
ck-GT86's Build ck-GT86 Member's Car Journals 37 07-14-2016 11:40 AM
fully build turbo fr-s/gt86/brz Baramzisyan Want-To-Buy Requests 15 03-22-2014 03:26 PM
NST GT86 MTM build Asurendra AUSTRALIA 25 01-03-2013 05:58 AM
