| Engine Swaps Discussion of engine swaps. |
Drives: 2013 F-RS
I'm looking to do a swap on a 15k budget with labor, trying to get around 400hp+, is it a realistic budget? if so, what are the best options out there engine and transmission wise?
I've been reading around on all the different swaps, but all the information is all over the place. I'm new to all this, so thank you guys in advance for any information that is provided! |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#3 |
Meow
Drives: Focus ST mk4
Step 1: sell 86
Step 2: use car money + 15k from project & go on craigslist Step 3: get a used Vette Step 4: avoid losing tens of thousands when resale comes Just my 2c ;-) |
#4 | |
#5 |
I think this misses the point of what he is trying to do. The car is awesome and as long as the LS motor does not destroy the car's balance/handling, the finished product would be so much better then an old vette. If I had the money, I would do an engine swap. You might be able to save money by buying a used vette for the motor/parts though. FYI, you will never recoup the money you put into it.
#6 | |
#7 | |
#8 | |
The swap didn't add that much weight. Move the battery to the trunk to mitigate that a little. Sent from my ONEPLUS A5010 using Tapatalk |
#9 |
Rust bucket enthusiast
400+ once vs 400+ for a while is where the real cost difference comes in
#10 |
Meow
That, and keeping a car with stock-like amenities (cruise control, ESP, stock cluster, AC, etc.)
#11 | |
#12 | |
#13 |
Drives: Q5 + BRZ + M796
Best bet is a K24 KPower industries swap with a turbo kit and stock trans with full CANBUS integration with Haltech. They will make a BMW tranny swap option down the road. Tf-works offers a CD009 swap with wiring kits for more basic setups. I don’t think they will offer full CANBUS like KPower.
There are plenty of cheap swaps to be done if CANBUS is not required. You could get a junkyard, iron block LS or older smallblock Chevy or Ford with any number of transmissions that directly bolt up, have adapters or aftermarket bellhousings. Aristo 1JZ/2JZGTE with a W58/R154 or a 2JZGE and a turbo kit with the same transmissions.
#14 |
Drives: Crapcan
I was thinking that too. Motec to run all the OE accessories along with EPS and communicate with TC is approaching half his budget before wire harness.
| Xander Performance 2013 frs lsx swap | all4spl | Engine Swaps | 33 | 02-10-2022 04:02 PM |
| HELP!! Engine Swap for 2013 Scion FRS | padillaricardo48 | Engine Swaps | 19 | 09-03-2020 06:21 PM |
| 2JZ Budget Swap 2.0, Another One | Pure Automotive | Engine Swaps | 42 | 07-06-2018 06:15 AM |
| Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 08:53 AM |
| Get Your Subscriptions In, We're Doing a Budget 2JZ Swap!! | Pure Automotive | Engine Swaps | 258 | 09-27-2017 02:41 PM |
