Old 04-05-2021, 03:06 AM   #421
RBenz13
Custom User Title
RBenz13's Avatar
Drives: '13 SWP MT BRZ Ltd
Just installed my (second-hand) set of CSG-spec Flex-As. I've been eyeing these for a while and got a great deal on a lightly-used set. I'm going for an OEM+ daily and light track build, so Tein was an obvious choice. The facts that these are serviceable, spec'd by a reputable contributor to the community, and EDFC-compatible were the main reasons I wanted these over other offerings.
AlI can say is, "Wow." These are by far the best set of coilovers I've ever driven on. I'm not nearly as capable of performing similar testing as the OP, but if my butt shock Dyno is any indicator, I'm in for a great ride.
Thanks CSG for the support and thanks to this community for keeping this forum going.
RBenz13
RBenz13 is offline   Reply With Quote
The Following 3 Users Say Thank You to RBenz13 For This Useful Post:
CSG Mike (04-05-2021), jflogerzi (04-08-2021), kevaughan (09-27-2022)
Old 04-10-2021, 10:27 PM   #422
jflogerzi
jflogerzi's Avatar
RBenz13
How many miles on the them prior to you getting them?
2013 Series 10 FRS #553
Old 04-10-2021, 10:34 PM   #423
RBenz13
Custom User Title
RBenz13's Avatar
~18K. I'll be sending them in for TeinUSA service after another 17K. I'm a few months out from heading on a year-long military tour without my car, so getting them for less made sense despite having to service them earlier (mileage-wise) than first-hand. More savings for the custom wheels and other goodies she'll be gifted while I'm gone.
RBenz13
Old 04-15-2021, 03:37 AM   #424
westy86
westy86's Avatar
Drives: 14 frs
Got my csg spec coils on today need to get em settled and then alignment but the car already handles like it’s on rails. The pilot sport 4s tires did not hurt haha
westy86 is offline   Reply With Quote
Old 04-16-2021, 01:07 AM   #425
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Well done to OP on the analysis. Love my CSG exhaust for a shameless plug. Really happy with it, but it is not a damper. Surprised to see a report of a softer feel than stock, but like that.
Anyone have the EDFC system installed, just curious. And, where do you put it? Wait, my phone is now too big for the tiny cubby under the HVAC controls. Does it fit there? Haven't read all 30 pages just yet.
jeepmor is offline   Reply With Quote
Old 04-16-2021, 02:23 PM   #426
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
If you think they feel good now wait until you get the alignment. I got them almost spot on by myself but just reducing rear camber and correcting rear toe by the alignment shop made a HUGE difference. day and night difference.
Plumbus is offline   Reply With Quote
Old 04-28-2021, 11:14 PM   #427
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
Installed and aligned about a month ago and so far these are everything they are touted to be. Also want to thank CSG again for their great customer service as I was in the midst of moving as these were in the process of navigating their way through customs.
therealstoly is offline   Reply With Quote
The Following User Says Thank You to therealstoly For This Useful Post:
CounterSpace Garage (04-29-2021)
Old 05-04-2021, 03:35 PM   #428
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by timurrrr View Post
Speaking of endlinks, is that expected that I'm rubbing a hole in the frame with my end link at full lock? This is camber maxed out on the top hats, measured at -3.1.
Lower profile end link, check out racer x.
You could use the SPL endlinks to gain some clearance [...]
So back then I ended up buying Racer X end links and they worked fine for a while.
After about a year of usage, RXes started to develop some play, which I believe is normal for this types of joints.
The SPLs also seem to have the same type of joints.
I don't really care about having the stiffest joints on my sway bar end links.
I'm perfectly fine with OEM-style joints, as long as the link is
  1. low profile enough to avoid contacts with the chassis
  2. reasonably adjustable so I can make sure there's no preload
    and the geometry is correct at ride height
    (ideally, they should extend all the way to OEM length)
Any recommendations?
- Depends on if you're slammed or not. The sway mount is offset for OEM end links.
Are they though?
I recently put the OEM front end links back while investigating an unrelated issue.
The angle between the OEM end links and the line between the roll bar pivot point and the attachment point of the end link looks ~75–80º, not 90º.
Fine print: this is judging by the photo I took of the front right end link at ride height when the steering wheel was turned slightly to the left in order to be able to take a photo of the end link with my phone. Also, my ride height might be slightly higher than the recommended settings, but not by a lot.
Given the issue I'm having with interference with the chassis, personally I'd prefer the coilovers to have such a location for the end link attachment point that would eliminate the risk of contacting the chassis; or if it was very clearly documented that aftermarket end links are strongly recommended. I'm glad I don't live in a climate where rust is a major issue — it took me a few months to realize that I have a hole in the paint there, otherwise I'd probably be pretty unhappy with that discovery :P
Old 05-04-2021, 03:38 PM   #429
CSG Mike
CSG Mike's Avatar
Are you using camber bolts or endlink spacers?
Old 05-04-2021, 03:39 PM   #430
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Neither. I do understand that I could add camber bolts and dial out the camber with top hats, but generally I'd prefer to avoid camber bolts unless absolutely necessary.
Old 05-04-2021, 03:43 PM   #431
CSG Mike
CSG Mike's Avatar
You should not be having chassis interference in that case, unless perhaps your front subframe is uncentered.
Use camber bolts to shift the knuckle as needed to get desired camber without interferance.
Old 05-04-2021, 03:44 PM   #432
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The chassis interference is pretty even on both left and right sides.
Old 07-15-2021, 03:44 PM   #433
Pillow142
Pillow142's Avatar
Drives: '18 86 (Asphalt)
Anyone have a PDF of the manual? I seem to have lost mine
Pillow142 is offline   Reply With Quote
Old 07-24-2021, 01:17 AM   #434
benzz280
Drives: Toyota 86
email them, got mine swiftly
benzz280 is offline   Reply With Quote
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 12:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
