Old 05-02-2021, 12:08 AM   #1
londonbell
Drives: GTS 86
86/AT Did anyone had same issue like mine?
Hi there
This is my very first topic in community.
I had this issue yesterday. After a short road trip from beach, on the way home. Trying to push gas pedal hard on the ramp of Freeway in order to reach 110km/h speed. I keep it on D gear, no sports mode.
But at the half way of ramp, the rev are significantly high (6k up) but speed is only show 60-65kph and I can feel the trembling, dragging, and I pull over the car on the freeway shoulder immediately.
After that, the car automatically shut down, and several warning lights pop up, including ABS, steering wheel, Break, engine oil... (sorry forgot to get a photo)
Tried to re-stratup the car, but there is no start up after short rev circling when I push the bottom and break, also the warning lights pop up again after every time I try to start up the car. Tried several times of it, same. So I did push the gas in the same time when I startup the car, thanks God the car back alive again after that.
My car is 86 GTS AT, 2013. Stock car, currently 82,000km. Service my car regularly (every 5000km) with Subaru Castrol Edge 0w-20 and filter. Just changed trans fluid (dealer said its drain and refill) and coolant flush at local Toyota dealer.
Trying to search the same issue on internet, but no same issue...
Gonna send my car to dealer for checking.
So is anyone had same issue like mine? Much appreciated.
Cheers
londonbell is offline   Reply With Quote
Old 05-02-2021, 12:11 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
has it happened again since?
Old 05-02-2021, 12:46 AM   #3
londonbell
Drives: GTS 86
It happened yesterday. At the moment, not happened again.
Old 05-02-2021, 01:06 AM   #4
soundman98
soundman98's Avatar
How full was the gas tank?
Old 05-02-2021, 01:22 AM   #5
Brz-123
If you remove the Toyota Subaru D4S plastic cover from thw top of your engine intake, do you see 2 pipes plugged into the back. One of them has likely popped off is what I suspect. If yes , push it back on and try again.
If not , I am unsure and best get it checked over at the dealers.
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 05-02-2021, 02:14 AM   #6
londonbell
Drives: GTS 86
Half of the gas tank.
Otherwise it won't re startup again when I push the gas and engine start button in the same time.
I use #98 fuel only as the car required. Mostly BP 98 ultimate, Coles Shell V-Power.
Old 05-02-2021, 02:17 AM   #7
londonbell
Drives: GTS 86
Just checked... nothing wrong over there...
Old 05-02-2021, 05:01 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Recall?
Old 05-02-2021, 05:44 AM   #9
londonbell
Drives: GTS 86
Originally Posted by x808drifter View Post
2013.
Recall?
I did this EVS recall on 2019, dealer put a silver sticker on the inside of door.
Old 05-02-2021, 10:14 AM   #10
soundman98
soundman98's Avatar
wait for it to happen again
right now you have a weird situation, but not a pattern. patterns can be solved, weird situations just make people pull their hair out.
Old 05-05-2021, 10:26 AM   #11
londonbell
Drives: GTS 86
It's been 4 days after it happened. Never happen again.
But I've been notice this drag feeling since trans fluid changed, sometimes the high rev didn't match speed. At the moment, just push the gas very gently and it seems fine...
Old 05-05-2021, 04:18 PM   #12
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Who did the tranny fluid change?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
soundman98 (05-06-2021)
My SWP BRZ...there are many like it, but this one is mine mobybrz Member's Car Journals 1 02-16-2013 02:54 AM
Another one down (not mine) Lee358 Off-Topic Lounge [WARNING: NO POLITICS] 27 01-12-2013 03:19 PM
Got mine! Foobar BRZ First-Gen (2012+) — General Topics 13 08-12-2012 08:40 PM
Not mine, but now it is (aka, another "got mine" thread) brianbot5000 Northwest 2 07-01-2012 01:50 PM
It's Mine! ant08 Scion FR-S / Toyota 86 GT86 General Forum 8 05-30-2012 10:09 PM
