Old 04-30-2021, 12:42 PM   #15
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
Originally Posted by BRZoomTX View Post
The log itself is definitely missing all important parameters except AFR, and overall is rather useless for debugging. Yes EcuTek app logs fine, but as mentioned you must select additional parameters for this to be a useful log.
Be sure at minimum to add Engine RPM, LTFT, STFT, fuel system status, and Commanded AFR. These will serve best to tell you as an end user what is going on when looking at the log. The rest of the information wont mean much to you, but they mean a lot for tuning, so the more parameters you log the better someone here can assist.
Generally, the ProECU Desktop defaults are good parameters. Match these in your app if that is what you are using to log.
On the issue itself, total fuel trims beyond 20% either direction is not good, but it is also somewhat expected if you have a only a single Flash and Go iteration. Generally these are best to get the car moving but are not ideal under hard driving. I definitely strongly recommend working on more tune iterations because the car is very far off right now based on your screenshots.
Also FWIW, LTFT and STFT dropping to zero is normal when you give it enough throttle for the ECU to switch to open loop (fuel system status 4). Most tuners especially for FI will disable LTFT in open loop. Ensure you log Fuel System Status, once you see it switch to 4 the car is in open loop mode. You then want to look for the Actual AFR to follow the Commanded AFR. Ideally connect and log output of a wideband but it is not required.
Since your closed loop fuel trims are so far off, I would expect your fueling in open loop to also be off. They at least have it on the richer side vs leaner side (more safe), but it is worth observing open loop operation to make sure you are not excessively rich as this can also cause its own set of problems.
Got it sorted out for the most part, now just need a 3" overpipe all the way back to exhaust or a 3" tapered to a 2.5", my current set up JDL 3" dp connects to a 2.5" OP and has a hard change at the flange so its restricting air flow
Limitless_BRZ is offline   Reply With Quote
Old 04-30-2021, 01:21 PM   #16
Limitless_BRZ
https://datazap.me/u/limitlessbrz/wo...ta=13-14-15-30
Uploaded a WOT 3rd gear log, We think that the 3" downpipe sharp change to 2.5" Op is hurting air flowing causing the ECU to pull timing
Old 04-30-2021, 09:26 PM   #17
tomm.brz
Drives: brz 2017 hksv2
well you should try to have a less atrocious airflow scaling and tune overall, since the ecu is constantly pulling out fuel while you WOT with boost
From the whole I see there i would say
Change tuner lol
but you won't do it and we can't help anyway because only your tuner can modify it
BRZoomTX (05-01-2021)
Old 04-30-2021, 10:15 PM   #18
Limitless_BRZ
Change tuner lol
It’s through delicious tuning, their good. gonna see what happens with the 3” turbo back exhaust
Old 05-01-2021, 11:25 AM   #19
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
My own personal opinion about Delicious aside, the current tune is not dialed in well as already mentioned. Adding a 3" turbo-back wont fix the issue you're having here. Your 2.5" will easily flow enough air for your current boost level.
Before your pull your LTFT is near 20% indicating idle and cruise MAF scaling is not dialed in well. During the pull, you start rich then lean out on the top end, it swings from ~4% too rich to ~5% lean; nearly a 10% variation in fueling during your pull. Your MAF g/s curve is also bumpy, especially on the top end, and contributes to why your fueling is off.
Your tuner [Delicious] should have you do much more low end MAF scaling before having you do these pulls. The car does not look ready to be driven hard yet. Just my $0.02.
Your current MAF scaling will be causing more of an effect on your drivability than your 2.5" overpipe. You can run a stock catback on a turbo and not suffer from such issues. You won't make the best power but you shouldn't feel anything along the level of thinking the car is pulling timing.
Regarding timing, you are actually running a couple degrees more on the top end than the low end, so over time it is adding timing, not taking it out. You did have knock event early in the pull but IAM remained 1. Delicious will want to look at that area but please have them address your MAF scaling first.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZoomTX For This Useful Post:
DarkPira7e (05-04-2021), Limitless_BRZ (05-01-2021), tomm.brz (05-01-2021)
Old 05-01-2021, 12:58 PM   #20
Limitless_BRZ
This is why I love forums, I appreciate it!
Old 05-01-2021, 01:39 PM   #21
tomm.brz
So OP likes to be spoon-fed but doesn't like the crude truth :P
The main facts around every Delicious tune not made by a guy named Zach that i've lately seen , are that those amount of fuel trims (both on CL and OL states) are there because of a specific reason
In the same time, those trims that linger even in final releases say a lot about how the tuner and his work
The introduction of closed loop fuel control by ecutek in racerom 10 made things different by the tuner side
It can help a lot and make tuners feel relieved that nothing will happen because of bad MAF/SD scaling, but it can be a double edged knife
hope OP will sort it out anyway
Old 05-03-2021, 11:42 PM   #22
tomm.brz
Limitless , keep us updated :-)
Old 05-04-2021, 01:04 AM   #23
Limitless_BRZ
I will! i am having a hard time finding a 3" op/front pipe exhausts in stock.. So i might actually go with a local tuner (DB Tuned) im local to him in arizona, might be easier and see what he ends up saying
Old 05-04-2021, 09:20 AM   #24
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I want to attest that I ran 17 psi and made 330whp with perfect drivability on stock catback and a 2.5" over pipe/frontpipe from 3" downpipe off of the turbo.
@BRZoomTX is spot on
BRZoomTX (05-04-2021)
Old 05-04-2021, 10:17 AM   #25
tomm.brz
But, with e85?
i think OP use 93oct?
Old 05-04-2021, 10:17 AM   #26
DarkPira7e
DarkPira7e's Avatar
But, with e85?
93 is the only high octane available in Vermont, no E85 in the state
Old 05-05-2021, 10:01 PM   #27
Limitless_BRZ
I’m only on 91, e85 rare around here.
Old 05-05-2021, 11:22 PM   #28
tomm.brz
Ok, you won't remove those amount of knock just going 3" turbo back
Piss fuel will require more DI or timings will always be low and the car lazy as f***
Is LTFT a value or a table? dstrout Software Tuning 24 09-12-2018 07:54 AM
Help with e85 oft - ltft is very high Neos Software Tuning 4 05-15-2018 06:25 AM
Normal LTFT?? dillanp86 Engine, Exhaust, Transmission 16 05-07-2018 11:17 PM
strange LTFT bee_are_zee Software Tuning 11 05-17-2016 07:28 PM
LTFT reading oft mike7792 Software Tuning 1 02-01-2016 09:21 PM
