Old 04-29-2021, 09:33 PM   #113
Originally Posted by timurrrr;3428237
Surprisingly on that occasion it was 100% accurate [I
when driving at constant speed[/I] on a straight flat highway.
I'm not talking about a single sample, I'm talking about hundreds of samples across multiple drives on different sets of same spec tires.
Well, you are fortunate. I've tested all cars I've owned since GPS became common, and they all have been 2 to 8 miles an hour off in the same condition.
timurrrr (04-29-2021)
Old 04-29-2021, 11:11 PM   #114
ermax
ermax's Avatar
Originally Posted by timurrrr View Post
But I do agree that this is not worth 8 pages of a discussion lol.
I just hope that it's ~10 Hz from the factory, or at least that someone comes up with an easy tweak for the software.
In the worst case, I'll try to I find time to make a DIY speedo with blackjack and HUDers.
Okay I’m not familiar with blackjack or HUDer and a quick Google turns up nothing for either of them. Do you have any links?
Old 04-30-2021, 02:24 AM   #115
Kronk
Drives: Planning for GR86
Here accuracy panels: 10% faster
But it’s not a problem. Your circuit references are based on your speedo. And legal road limits are based on this wanted poor accuracy.
Kronk is offline   Reply With Quote
Old 04-30-2021, 11:53 AM   #116
Ernest72
Digital is fine, no issues in 5 years of ownership. Only looked at the needle speedo once and it’s too small. You are way overthinking this.
Old 04-30-2021, 12:28 PM   #117
Dake
Dake's Avatar
They're talking about the digital speedo and their superhuman ability to notice that it might be a quarter second off of where it should be while negotiating the Forrest Elbow at Mount Panorama.
Semi-serious though Timurr, I get what you're saying. You're saying it doesn't matter so much that the speedo is inaccurate, just that it should be consistently inaccurate. But let's look more closely at your example from the last page:
See above my comment on this thread a few pages ago: track driving.
When I track out from T6 at Laguna Seca and I see 78 mph on the speedometer, does it mean that
I've nailed that corner ... or does it
mean it's still showing the speed I had before the corner?
You are introducing a number of variables into this and the potential refresh rate of the digital speedo isn't even the biggest one. I'd say the biggest is, how are you managing to look at the speedo at the exact same moment every time so as to have exact comparisons (or exact enough to then be wrong due to the quarter-second refresh)?
So T6 at MLC... you've entered, headed for the apex, and you've picked up your exit point, your eyes are now looking up the hill to get the car in position for the corkscrew. That's where you should be looking. Looking at the speedo in any of those instances is taking your eyes away from where they should be. Furthermore, you should be able to tell whether you're on speed because you either hit your targets or you don't. You're either in the power band, or you're not (that's why the tach is the right in the center of our display).
Your eyes should be outside the whole time at most every point on that track aside from maybe the front straight when you're just WOT and heading for the line. I will bet you'd see better overall time gains if you put a piece of cardboard over the instruments, drove outside the whole time and just focused on hitting your entry/apex/exit every turn through feel and engine sound, than you'll ever gain from worrying about 1 mph (+/- .025 seconds) at any given point along the track.
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
soundman98 (05-01-2021)
Old 04-30-2021, 01:59 PM   #118
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://knowyourmeme.com/memes/im-go...ck-and-hookers
I use the end of the track out curb as a time reference.
The timing is as precise as any reference people use for braking.
I have to admit: the more I think about it, the more it seems that at points where it is useful for me to know speed the speed doesn't change that much.
But just the second thoughts that I don't know if the speed I'm looking at, when I do look at it, makes me doubt the speedo.
This is where I am constantly scanning towards with my vision.
Just to clarify, I'm not just staring at the speedo every time I take every corner of every lap.
It's more of a sampled data check as I go, primarily used to sanity-check/calibrate my seat of pants.
Looking and thinking ahead is still the priority, of course.
It's funny that nobody in this 9 page (lol) discussion has even mentioned the biggest source of inaccuracy.
Not theoretical, but happens every time when you're "on it", affects all speedometers of all cars, and easily affects the reading by up to 5 mph when driving on the track.
Curious when someone brings it up
But again, a fairly consistent/predictable/correctable one.
Old 04-30-2021, 07:50 PM   #119
p1l0t
p1l0t's Avatar
What about a Nixie Clock? These are pretty sweet, retro but fast.
https://eshop.3dsimo.com/collections...c13nXZoAUAJieE
You can crank some of these puppies up to like 100,000hz!
https://hackaday.com/2019/12/12/cust...-100000-hertz/
Old 05-01-2021, 08:55 AM   #120
JuniEdith
Drives: Subaru
A car with a digital speedometer uses a speed sensor, which usually consists of a magnet surrounded by a wire coil, quite like the pickup on an electric guitar. The sensor is mounted directly next to a gear on the transmission, and as the gear spins, its teeth whiz by, interrupting the magnetic field on the sensor.
Nobody loves slow speed refresh,this may occur due to faults the speedometer should try to show exact speed.
JuniEdith is offline   Reply With Quote
Old 05-01-2021, 10:50 AM   #121
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
It will be predictable.
You also have revs and gear you are in displayed without the same keep and hold as the speed, and these have an much more optimal layout for racing as per the new visual mode.
It should be one of the better cars for track day information.
Blighty is offline   Reply With Quote
Old 05-01-2021, 01:25 PM   #122
soundman98
ProCrastinationConsultant
soundman98's Avatar
i don't think i've ever heard of people at track days talking about their speed through corners. it's usually references to rpm and/or gear selection. 'should be topping out 3rd there, but instead of shifting, hold to redline, that'll be the braking zone point for the next turn'...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Blighty (05-02-2021), HKz (05-03-2021)
Old 05-02-2021, 10:36 AM   #123
ls1ac
ls1ac's Avatar
I too wonder about the value of a speedo on the track. Several of my track cars had NO speedo. Reviewing telemetry after a race or practice run was instructive but not while driving. Too much else going on to be looking at a speedo.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Dake (05-03-2021), mazeroni (05-03-2021), soundman98 (05-02-2021)
Old 05-03-2021, 01:23 PM   #124
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
OP is professional driver from italy.
HKz is offline   Reply With Quote
Old 05-03-2021, 03:28 PM   #125
Kronk
Nope, I’m just a software analyst in love with cars and technologies.
But you must to be a pro comedian, thank you for your contribution.
The Following User Says Thank You to Kronk For This Useful Post:
HKz (05-04-2021)
Old 05-03-2021, 03:33 PM   #126
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I believe on our cars it uses the ABS sensors integrated into the wheel hub assemblies.
In-dash digital speedometer vaer Electronics | Audio | NAV | Infotainment 4 04-14-2020 10:19 AM
Does the BRZ get same refresh? snezze21 BRZ First-Gen (2012+) — General Topics 74 03-24-2016 01:51 PM
Convert the digital speedometer from Kmh to MPH? Jastation Electronics | Audio | NAV | Infotainment 10 09-28-2015 05:46 AM
Digital speedometer in base GT86? rhysmcinerney Electronics | Audio | NAV | Infotainment 25 01-22-2014 06:18 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
