04-29-2021, 11:28 AM | #99 |
Drives: TBD
04-29-2021, 11:38 AM | #100 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
04-29-2021, 12:12 PM | #101 |
Drives: '14 BRZ 6MT
Awesome! thats the goal. I am only familiar with the early gen 1 cluster so was not sure if that was an option.
04-29-2021, 01:16 PM | #102 | |
Pavement Grey
Obviously the additional gauges or the trip computer items would be far more useful than the other stuff, so those would be the most likely to be shown all the time. I think the gen 2 cluster scrolls through the same things on the left side with the right side having fixed temp and fuel gauges. |
04-29-2021, 03:03 PM | #103 |
Drives: 18' 50th An. BRZ, 79' RX7
Hopefully the G meter isn't so hopelessly useless in North America like it is on my 2018 BRZ.
04-29-2021, 03:30 PM | #104 | |
Drives: 2022 GR86
It's like some people have outdoor thermometers at home and some don't need them. "Seat of pants" and all that stuff. Personally I think it's important for a speedometer to be precise not only in what speed they're showing, but when they're showing it. I don't care what speed I was going up to 0.25 seconds ago, I care about what speed I'm going now. If it's up to 0.25 seconds late, it also means that it's up to 3 mph wrong when I'm braking; whether on the track, or on a highway when I spot a police car. |
04-29-2021, 03:35 PM | #105 |
Drives: 2022 GR86
But I do agree that this is not worth 8 pages of a discussion lol.
I just hope that it's ~10 Hz from the factory, or at least that someone comes up with an easy tweak for the software. In the worst case, I'll try to I find time to make a DIY speedo with blackjack and HUDers. |
04-29-2021, 03:47 PM | #106 |
Drives: '04 STi, '12 Mazda 3 Hatch
Unfortunately Colorado cops are much better at hiding and tend to do it on downhills and in acceleration zones. If I'm accelerating I'm watching the speedo out of the corner of my eye so I let off near the speed limit. Any time I'm driving along and not using cruise control I check it every 30 seconds or so. Too bad cops around here aren't as vigilant about turn signal use as speeding. They could probably make more money and I could relax and keep my eyes entirely on the road.
04-29-2021, 04:01 PM | #107 | |
Sent from my SM-G975U using Tapatalk |
04-29-2021, 06:40 PM | #108 | |
You're talking about quarter-second accuracy on a display that is legally allowed to be off by as much as 4 mph. This is combined with the fact that in any spirited driving, the speedo is pretty much the last thing you need to be spending enough time staring at to determine that it's a quarter-second behind. So yeah, we all like what we like and we all have our weird things and I'm down with that too. It's not about kink-shaming here. I'm still just trying to understand in what way this level of expected precision is a) necessary and b) actually noticeable in anything outside of a laboratory environment. |
04-29-2021, 07:47 PM | #109 | ||
Drives: 2022 GR86
I don't mind if a Camry I rent on a business trip has a digital speedometer with a slow refresh rate. We're talking about a sport car though, that is advertised as being able to carry four spare tires for a track day. Quote:
When I track out from T6 at Laguna Seca and I see 78 mph on the speedometer, does it mean that I've nailed that corner (that's a pretty decent exit speed for GT Radial SX2s I use in 86DC) or does it mean it's still showing the speed I had before the corner? Any learning process accelerates by having high quality positive/negative reinforcement delivered ASAP (as opposed to data analysis after the session, or even at home). When it comes to track driving, in in certain types of corners the exit speed is a very high quality signal. Definitely higher quality than seat of pants of most people I've talked to, if we exclude for very experienced track drivers and actual racers. In some longer corners (such as T2 at Thunderhill), knowing your typical speed can help quickly you sanity-check how close your are (or the driver is, if you're the coach) to the limit. |
04-29-2021, 08:15 PM | #110 | |
1st86 Driver!
You then have, on top of that, the fact that your speedometer is likely calibrated for a medium-wear tire of the size shipped on your car. This introduces further error. So, in the end, all a faster refresh rate give you is the approximate speed at a theoretical faster rate. But hey, you want what you want, and I hope you get it. I'd be good with a faster rate as well, but I truly had never thought about it until you brought it up.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Dake (04-29-2021) |
04-29-2021, 08:46 PM | #111 | |
04-29-2021, 09:14 PM | #112 | |
Drives: 2022 GR86
I don't think a bald tire vs new tire will generate more than 1 mph off up to ~100 mph. I actually did check my speedo against GPS a few times when debugging some other data longs, along with the underlying data sent over the OBD and CAN bus. Surprisingly on that occasion it was 100% accurate when driving at constant speed on a straight flat highway. I'm not talking about a single sample, I'm talking about hundreds of samples across multiple drives on different sets of same spec tires. |
The Following User Says Thank You to timurrrr For This Useful Post: | Dadhawk (04-29-2021) |
Similar Threads | ||||
In-dash digital speedometer | vaer | Electronics | Audio | NAV | Infotainment | 4 | 04-14-2020 10:19 AM |
Does the BRZ get same refresh? | snezze21 | BRZ First-Gen (2012+) -- General Topics | 74 | 03-24-2016 01:51 PM |
Convert the digital speedometer from Kmh to MPH? | Jastation | Electronics | Audio | NAV | Infotainment | 10 | 09-28-2015 05:46 AM |
Digital speedometer in base GT86? | rhysmcinerney | Electronics | Audio | NAV | Infotainment | 25 | 01-22-2014 06:18 PM |
Fast car Fast driver vinyl decal I need help | francosolracer | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 10-20-2012 03:43 AM |
