#2451 |
Drives: 10 Series #974 6m/t
Been a little over 8 years since the 10 Series was announced. How's all the 10 Series owners doing ? Still have mine currently sitting at 24K miles.
| The Following User Says Thank You to NyC Zn6 For This Useful Post: | MJones_RB (04-28-2021) |
#2452 |
520
Drives: Series 10 Fr-s #520
Wow. Not many miles on yours! Thought mine was low at 39K.
Sent from my IN2025 using Tapatalk |
| The Following User Says Thank You to czechm8 For This Useful Post: | NyC Zn6 (04-29-2021) |
#2453 |
Drives: FR-S 10 Series
Up to 54k miles, still going strong. Protective plastic from factory is finally peeling from the glow in the dark door badge.
As of now: 2nd set of tires, 2nd battery, 2nd set of brakes, 3rd dipstick O ring(?!?!), 1 replaced cam sensor -besides that same as the summer of 2013. Last edited by dnieves; 04-28-2021 at 07:58 PM. |
#2454 |
Drives: Scion FR-S Series 10 #2462
Mine is at 49k. Everything still works. 2nd set of tires. No major issues, other than a failing TOB (common.) Just passed smog. Paint still holding up. One door speaker is rattling, easy replacement. Good little car.
| The Following User Says Thank You to MJones_RB For This Useful Post: | NyC Zn6 (04-29-2021) |
#2455 |
Drives: 2013 Scion FR-S 10
Mine is just over 60k miles.
Other than the hail damage the car is in good shape only issues I have are one of the license plate lights is burned out Oh, and I had a coil pack on the passenger side die. other than that the cars been good. Last edited by KN0W; 05-03-2021 at 01:16 PM. Reason: Image not working |
| The Following User Says Thank You to KN0W For This Useful Post: | MJones_RB (05-03-2021) |
#2456 |
Drives: 2013 Scion FR-S Series 10
78K Miles.
Haven't washed the car in like 6 month. Haven't waxed it in like 3 years. Headlights are foggy and yellowed. EPS module replaced for $1400. TOB/ Clutch replaced for $1200. My only real complain is the replacement clutch has that stutter issue rolling off the clutch in 1st when it has heated up. Not sure the cause, but it sounds like other people have to deal with it. I should note I got a non-OEM replacement. Driver's side front fender is still dented (thanks moron in apartment complex.) The keyless start can be hit or miss in hot and humid weather. The keyless icon just blinks green when I push in the clutch and it won't turn over. If I hold the receiver next to the starter, sometimes it will work. Or I just push the clutch in and out a bunch. Not sure if it is a receiver issue with the car or the clutch switch. When it is cooler and dry, I never have the issue so I'm not sure WTH is up with it. The interior is quite dirty. I got a mountain bike (remove 1 pedal and front wheel) and an inflatable kayak. Everything else seems fine. Looking forward to either a 2022 BRZ or GR86 - I'll try to keep it looking nice even though it has to sit outside. After my fender got dented, I just gave up trying with the Series-10. |
#2457 |
Drives: 2013 FR-S Series 10
How bad is the dent? You can do PDR for like 100-150 bucks usually..
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#2458 |
Dent(s) are along the curve of the fender well. I think you would need to hammer the underside. You can't see all the touchup paint I used. They even scuffed my side markers.
#2459 |
Current State
#2460 |
I'm at 68k miles, still holding strong. I replaced the goofy dash with the newer one piece leather dash, am i still part of the club?
| The Following User Says Thank You to Decep For This Useful Post: | NyC Zn6 (05-11-2021) |
#2461 | |
2013 Series 10 FRS #553
#2462 |
Yeah but seems like they work on and off, when they feel like it.
#2463 |
Drives: 2023 Toyota GR86 Trueno Blue
#2464 |
Front lip - Carbon Fiber Varis Arising 1 - https://www.86worx.com/varis-arising-1-front-lip.html
Side Skirts - Carbon Fiber Evasive Motorsports Downforce - https://www.evasivemotorsports.com/s...ubaru-brz-frp/ |
| 86 Owners of New England - Registry | MannyO | New England | 247 | 10-27-2025 03:45 PM |
| **Tennessee Registry** | Xryn | Southeast | 139 | 11-02-2022 12:31 PM |
| Mid-Atlantic Owners Registry. | IloveBaldEagles | Mid-Atlantic | 366 | 10-24-2022 08:55 PM |
| Issue updating Registry. | IloveBaldEagles | Site Announcements / Questions / Issues | 1 | 03-18-2013 07:19 PM |
| First 86 Registry: 2013 Scion FR-S | Flipside909 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-18-2012 05:54 PM |
