Old 04-24-2021, 10:06 AM   #71
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It would be biennial starting this year, but no. The car may be registered in a smog exempt area of California.
Why would you drive all the way to Austin, Tx just for an exemption?
MS, CSCS, TSAC-F, CPT
Old 04-24-2021, 11:40 AM   #72
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Geez, I haven't seen a gash like that since I unwillingly lost my virginity.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 04-24-2021, 11:52 AM   #73
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
No need sir. Most of the countryside of Northern California’s 530 and 707 area codes are smog exempt. Surprisingly, CARB isn’t as unreasonable as everyone thinks. They aren’t interested in sweating the small stuff like having ten thousand people or less in a rural area smog their car. My parents lived only 30 minutes north of Santa Rosa, and they were smog exempt, when realistically, would requiring people to drive 30 minutes (or likely less) to an area with a smog shop to smog a car biennially only after eight years of ownership or during title transfers really be putting people out that much? They could, but they don’t. Now my parents are retired further up north on Clear Lake near two of my brothers, and that area is also smog exempt.
Old 04-24-2021, 11:54 AM   #74
Irace86.2.0
[Pic]
Your artistic skills are astounding
@DarkSideFRS would say, that picture is befitting.
Old 04-24-2021, 12:28 PM   #75
weederr33
weederr33's Avatar
Woah... I never knew California had locations of freedom. Well that sure makes your swap a lot easier.
Old 04-24-2021, 01:10 PM   #76
Decep
Drives: 2013 FR-S Series 10
That's interesting! I grew up in the 707 and we always had to smog. Guess i was in an unlucky zip code.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 04-24-2021, 01:52 PM   #77
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by TommyW View Post
Because for the extra 1,400 to have a motor that addressed the shortcomings of the stock motor and used much better internals it was an easy decision.
My blown motor was due to the recall
Any plans to add the rocker retainer kit ? That is my second biggest issue with this engine outside of oiling.
That is some first rate carnage @Irace86.2.0
Old 04-24-2021, 07:50 PM   #78
Irace86.2.0
Like I said, everything north of the Bay Area and Sacramento is 707 and 530, so it covers a huge area, and as you can see by the maps, the population density is fairly sparse. This means that most towns, townships and rural areas are exempt, assuming they are remote enough from a city. For instance, Sebastopol has a smaller population over a larger area than Cloverdale, and yet the residents there aren't exempt because they are 8 miles from Santa Rosa versus 40 miles, respectively. Moreover, Cloverdale has limited locations for getting a smog and the closest DMV is back in Santa Rosa or north to Ukiah. I am assuming this is how they think about it.
Old 04-24-2021, 09:45 PM   #79
TommyW
TommyW's Avatar
Drives: '13 Whiteout
No. Staying NA I’m not too concerned. Plus I keep my shift point at 7k. I have the mentality at the track that I have to drive the car home and that can be an 8 hour drive sometimes.
TommyW is offline   Reply With Quote
Old 04-25-2021, 12:05 AM   #80
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine was NA, around 6k rpm when it kicked them out.
Old 04-25-2021, 10:35 AM   #81
ML
ML's Avatar
Drives: 13 White MT FR-S
k motor + rotrex
Old 04-25-2021, 10:46 AM   #82
Irace86.2.0
If this car was lighter than what I have now like I was doing a track build on a stripped out 86 then I would consider staying NA with a K24 swap and doing a 300hp build, but as it is, this will be getting a turbo setup either initially or down the road. If this was going in a Miata RF or something just as like like a Lotus/Jannarelly then again, NA all day long, but the car is too heavy to stay NA for my preference.
Old 04-25-2021, 10:53 AM   #83
Irace86.2.0
Originally Posted by ML View Post
k motor + rotrex
I wouldn't be surprised if JR developed something for the 86 platform. I use to have turbocharged cars, and after having a PD supercharger, I would consider another, or even something that is between the two like a centrifugal supercharger. A turbo has a little more drama and screams JDM to me that I am leaning that way. If I wanted NA feel, which feels great, than I would do a NA build or stick to a LS3. Naw, I will turbo.
Old 04-26-2021, 12:28 AM   #84
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Ouch! I know you had a lot into that build. Sorry man. But at least I know now not to move up to the 75mm pulley.
You could always keep the twin and wait until there's a crate electric motor available.
Just do a crate k20c1 swap. 300hp and 295lb of tq. And no having to worry about the engine blowing up.
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Dustin's UltraMarine FR-S (Engine Blew - LS3 Time) DustinS Member's Car Journals 800 04-13-2024 09:23 AM
Engine Blew, any shop recommendations? tian105 Southern California 11 08-16-2020 11:35 PM
Engine blew on 4psi? Causes? soccerk18 Software Tuning 26 08-10-2019 11:18 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
