#4061 |
Drives: 2018 BRZ tS
Anyone know if this broken rubber piece was just for mounting? Or if it actually feeds into anything?
Haven't noticed any performance issues, just noticed when doing a casual inspection now that things are warm out. Edit: the manual calls it an "isolator" but I have no idea what it does/isolates. Last edited by Side; 04-05-2021 at 06:47 PM. |
#4062 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
#4063 |
Drives: 2019 PP BRZ
Just double checking, is the stock pulley is about 10psi and the 3” pulley is about 15psi?
#4064 |
Stock pulley is 8 psi, 2.75 is 15 psi, at least that's what I've seen on mine.
#4065 |
Drives: 14 BSP Edelbrock BRZ
Are you at elevation B_T? I routinely saw 10.5 psi at 7k with the stock pulley.
#4066 | |
Drives: Asphalt FR-S
I've been hunting my idle problem with the Delicious tune and Dbox for months and I've seen your post only today. Did the bypass of the DBox today, and *boom*, cold car that doesn't drive like it wants to die at every corner. Can't believe that was the issue all along! I'll send a email to the guys at DT to get this replaced. ![]() ![]() ![]() ![]()
#4067 | |
Drives: 2013 frs raven
I think the d box has been phased out. Most tunes are able to compensate for it these days. Sent from my iPhone using Tapatalk |
#4068 |
Even the Delicious tune itself? Because I'll just remove it for now anyway.
#4069 |
#4070 |
#4071 |
#4072 |
More boost than expected.
Anyone here get more than the advertised boost on the stock pulley? I am seeing well over 9, usually high 11s or 12s today I seen it almost at 14.
I am wondering if this is some sort of internal issue, or if its common and they advertise way less than reality. I replaced the nose coupler before I installed it, if that's of any consequence. Thanks guys! |
#4073 |
Drives: 2023 GR86
Does anyone have any measurements on how parasitic this supercharger can get? If that's even possible to measure..? Maybe in comparison to other FI kits?
#4074 | |
Sent from my Pixel 4 XL using Tapatalk |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
